Question about Samsung Galaxy Admire 4G MetroPCS
Wont charge and when charging says its full charge
Wont charge and when it is charging it says its full charge when it isnt
  • 250 Answers
Replace the charging IC
Posted on Dec 28, 2013
My pone is charging but wont turn on i have taken the battery out several times and it is full charged but still wont turn on what should i do
replace the battery with a new one. Many battery types create a 'memory' when used repeatedly without a full charge. stopping the charging process prior to full charge lowers the level the battery 'expects' a full charge to be. Do this often enough and you will create a battery that expects full charge to occur at zero charge.
Sep 20, 2014 | ZTE AT&T Avail II Z992 Unlocked GSM...
Why isnt my ipod charging?
You should change the charger
Nov 10, 2013 | google.com
My DELL streak 7 wont charge or turn on! what can i do to fix it
Use a trial and error method. try using another battery charger(power supply), if it charged then the problem might be your charger. replace it. if it still wont charge using another charger of the same output voltage,it could be the motherboard is damaged.
Jun 21, 2012 | Computers & Internet
I cant get my craig mp3 player model number cmp648f to turn on
aktsane i can't understand when is it charging... when i just connect it to my PC or i need to eject it? when i first connect it to my computer it seems to be in transfer mose, but when i click eject, it starts charging but then stops cause it's full... i waited for it for 10 hours but still not working :((
Jan 26, 2012 | Audio Players & Recorders
Battery not charging, purchase new battery but still not charging. when turning on says adapter driver not installed, followed instruction in trobleshooting but still not working......
sounds like your cord isnt giving full charge, this could also be a driver update needed, some times the batteries need to be flashed, or the bios needs to be updated, the battery is paired with the comp from the factory, sometimes if it doesnt meet all the systems ideals they wont register, go into your device manager and see if the battery has a upside down triangle with an exclamation point if it does right click and update
Jul 04, 2010 | Dell Latitude C610 Notebook
My harley 1200c sportser 2004 isnt starting after a new battery was installed. was told i didnt have to charge the battery it would charge itself in 90 mins ,one those fill cell batteries can you help
The cells are full? Check the battery with a volt meter - should read at least 11 volts on the DC scale, to be able to start your motorcycle. If it is at 11 volts, you really need to charge it.
If volts are good, check volts on the starter side of the solenoid with the run switch in the ON position and the key in start position. No volts = bad solenoid.
Jan 15, 2010 | 2005 Harley Davidson XL 1200 C Sportster...
My xbox360 controller wont take a charge. the little red light that shows its charging isnt coming on. does anyone have a solution?
Right, just keep plugging in the charger into the controller until the light stays red, the small amounts of charge put in each time will eventually give the battery enough juice for it's built in 'memory' to be clued in as to how much power is really in and will then start charging. This is usually caused by leaving your controller unused for a while usually days or so at room temperature after fully charging it in your xbox (i.e. the battery memory 'thinks' it's full and tells the xbox as much when really it's empty)
Mar 29, 2009 | Microsoft Xbox 360 Wireless Controller
Psp wont charge or hold a charger
It could be a bad battery or you can check under the psp if you can turn it on and make sure that under Settings > System Settings > USB Charge is set to on. If it is and it isn't charging then it's a bad battery.
Dec 22, 2008 | Sony PlayStation Portable (PSP) Console
Sansa Clip Mp3 Player
format it
by connecting to computer
Jun 11, 2008 | SanDisk Sansa Clip MP3 Player
Nokia 6300 wont power on
check on that battery connector isnt damaged it looks like you middle pad BSI line its not connected properly
Feb 18, 2008 | Nokia 6300 Cellular Phone
Samsung Galaxy Admire 4G MetroPCS Logo
95 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
