Question about GE JTP45 Electric Double Oven
Ge jtp45 display is very dim
Everything is working but cannot see display.
    Problem Solver:
Cover over display has a film that darkens with age. you can cut the film off.
Posted on Dec 05, 2014
Jtp45 lower oven hot heating on any cycle
Possibly a tripped thermal fuse. Should be located behind the panel in between the upper and lower ovens. Might have a red reset button on it you can push down. If it clicks and then works again, look for possible cooling fan problems.
May 12, 2014 | GE JTP45 Electric Double Oven
Electrical panel goes out when top oven gets hot jtp45
Sorry dearest
We in the wilderness are not familiar with that brand, sorry
Kolbrun
Apr 09, 2012 | GE JTP45 Electric Double Oven
Digital display fading GE JTP45
Hello
You will need to replace the digital display, it will be part of the control circuit board if it is a typical design. Without specific make and model information that is about as much information as i can offer.
Dec 14, 2011 | KitchenAid Ovens
Oven won't heat up past 200 degrees
The temperature sensor needs to be checked.It must not working properly. thanks.
Oct 11, 2011 | GE JTP45 Electric Double Oven
Display panel is dim.
first check the power then if shows to be good replace clock assy
May 26, 2010 | GE JTP45 Electric Double Oven
I have a 326B1230P001 GE Double oven that displays ?F7? and beeps?..have cut power to it to try to reset it but it comes back beeping and the display goes through different changes by itself?.what is wrong...
F7 stuck keypad
Stuck keypad may mean relay is turned on.
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Jul 30, 2009 | GE JTP45 Electric Double Oven
F7 appears on GE double oven JT950SA
f7 is a stuck keypad or overlay all you can do is replace it
Jun 30, 2009 | GE JTP45 Electric Double Oven
I have a F0 on the display of my double oven JTP45 model
Giggles01: I wish I had an answer other than calling GE. We are about to install a used oven of the same model/same vintage. I've been unable to locate a manual and need some information from it. Would you be willing to tell me the cut-out size the manual calls for regarding the installation of the oven? Most 30" ovens require a 28.5" cut-out, and I need to confirm that for the JTP45. Thank you!
Mar 09, 2009 | GE JTP45 Electric Double Oven
Oven Clock
You are correct about replacing a part. there is no adjustment for the brightness. The control board will have to be replaced.
To look up parts for your oven you have to drop the 0 from the number. Try JTP45WW2WW. No one at GE has been able to explain to me why they put the zero in the model number when it is not used to look up parts. But if you leave it out on a warranty claim, they will reject it because the model number is incorrect. Go figure.
I looked it up on sears.com and repairclinic.com.
The part number for the original board is WB27K5301, but that will change to WB27T10292 that has replaced the original.
Post back if you have any questions.
Thanks/Mike
Nov 29, 2007 | GE JTP45 Electric Double Oven
GE JTP45 Electric Double Oven Logo
133 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
