Question about Denon AVR688
I have a Denon AVR-688 and recently I haven't been able to use any of the surround modes at all. The only mode that works, regardless of the component, is Direct mode. Any suggestions?
  • 1 more comment
  • mike880 May 18, 2009
    Yes, no sounds are produced when using any surround mode. It only produces sound when using "Direct" mode, regardless of the source selected. I was told to respond to your Clarification request here, but the form wants me to select whether this is a Solution or I have the Same problem, I'm selecting solution since this is a clarafication regarding a possible solution
  • mike880 May 19, 2009
    Yes I've already reset the unti and the problem persists. It looks like a bad dsp board.
  • David Dunn
    David Dunn May 11, 2010
    What do you mean by "works"? No sound? When a digital source is selected do the panel indicators indicate its presence and qualities, such as "5.1", "DTS", "Dolby Digital"??
    Have you checked the Tape Monitor? It would effectively cancel all Digital Sound Processing.
  • 163 Answers
Try to reset the unit: hold "speaker A" and "Speaker B" buttons and power on the unit. Display will be flashing, release the buttons after 3 seconds. If the problem still there, most likely you have bad digital signal processing (DSP) board - send the unit to repair facility.
Posted on May 19, 2009
No sound
check speaker conections. disconnect all the speaker wires and use one speaker that you know that works and connect it to each channel one at a time. most surround sound stereos will not go into surround mode unless all the speakers are connected so make sure stereo is in 2 channel mode to start testing. check all fuses sometimes amp fuse is seperate from power circuit and denon uses relays in 99% of thier units.
Dec 23, 2010 | Denon AVR-2802
Can't get the sound to work on my TV using the Denon AVR-2807
In the 2807 the HDMI out is a video out only. Audio is not processed through the HDMI output.
If you are using speakers it is best to adjust the playback modes to stereo if you are annoyed with surround sound modes.
Please comment if I helped.
Oct 04, 2009 | Denon AVR-2807 Receiver
Denon avr-688
I have the same problem with my AVR-688, were you able to find a help?
Sep 18, 2009 | Denon AVR688
Avr 688 shuts down immediately after powering on
Internal problem with power supply or one of the channels. Bring it to a repair facility.
Aug 09, 2009 | Denon AVR-685 6.1 Channels Receiver
Denon receiver AVR-3300: Unstable source selection
Go over here: http://denon.custhelp.com/cgi-bin/denon.cfg/php/enduser/std_alp.php?p_sid=1NlVrsDj
I have some Denon components myself and had some problems. Ask them here, and within a day you should have solution for this problem.
Probably you have to reset the device to factory settings.
Jul 22, 2009 | Denon AVR-3300 Receiver
My Denon AVR-1802 is permanently stuck in tone defeat. The display actually shows that the tone defeat can be turned off and on, but the tone controls, ie. bass and treble do not alter the sound in any...
Is this only when using external inputs? The manual says the Tone Control will not function in Direct Mode. Try Stereo and various DSP surround modes to see if the Tone Control works.
Apr 21, 2009 | Denon AVR-1802 Receiver
No surround on Denon AVR-485
Hi you must put the amp into prolgic mode this is fed by a stereo siganal the rears will sound vague and hollow that's all you will get this willnot work with 5.1 or 7.1 good luck
Feb 22, 2009 | Denon AVR-485 Receiver
5ch/7ch stereo in 5 channel mode
Front panel button engaged for 5 or 7 channel operation? Also check front panel rear surround speakers button is engaged. Should get you back to 7.1 unless you have changed the rear surround speaker setup for a 2nd zone, also be sure you have a 7.1 DSP setting enabled.
Feb 22, 2009 | Denon AVR-2105 Receiver
Denon AVR-2803 Zone 2 sound source
You have to switch your remote into Zone 2 Mode. It will be an option on your remote. Once you put it in that mode, you can change the source just as you would Zone one.
Jan 25, 2009 | Denon AVR-2803 Receiver
Denon AVR-688 Dolby Digital issues
IT IS ALWAYS BEST TO CONNECT ANALOG AUDIO IN ADDITION TO THE OPTICAL, COAXIAL OR HDMI AUDIO CONNECTION. IF USING OPTICAL OR COAXIAL CONNECTIONS BE SURE TO CONFIGURE IT IN THE RECEIVERS DIGITAL ASSIGNMENT AREA IN SETUP.
ALSO, ON THE FRONT OF THE RECEIVER IS AN INPUT MODE BUTTON, PRESS THIS BUTTON UNTIL AUTO IS DISPLAYED
Jan 03, 2009 | Denon AVR688
Denon AVR688 Logo
1,250 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
