Question about Compaq Armada 1590DMT Notebook
AC Adapter The only thing I got with the Compaq Armada 1590DMT Laptop was a power cord, is it supposed to have an AC Adapter too?
The ac adapter is inside the armada 1590dmt. Only the cord is external.
Posted on Jun 19, 2009
  • 2,404 Answers
It should have the power cord as according to this page courtesy of HP:
http://partsurfer.hp.com/cgi-bin/spi/main?sel_flg=partlist&model=ARMADA1500&HP_model=291450-007&modname=Compaq+Armada+notebook+PC+1590DMT+(291450-007)&template=main&plist_sval=ALL&plist_styp=flag&dealer_id=&callingsite=&strsrch=&keysel=%3F&catsel=%3F
They don't show a part number for the ac adaptor though which in normal circumstances you should get that to when you buy it straight thru HP but they may be out of them.
You can find one off of ebay and it does exist as according to this auction:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&print=all&item=130303693439&category=31511
So definitely you can get one from Ebay if all else fails. Hope this helps you.
Posted on May 18, 2009
Purchased a Compaq Armada 7800 from a pawn shop. The power cord plugs directly into the back of the machine with no adapter. Does this machine have a built in adapter? Does it have a battery? I dont...
Hi. Yes, it has an "Integrated AC Adapter for less bulky transportation; 8-foot power cord included"
It also has a Li-ion Battery Pack on the left side which provides over 2 hours of battery life - if its OEM, but there are higher capacity batteries you can get for it at amazon or eBay .
This Link will take you to HP's page for more data and diagrams on your machine.
Take Care
Aug 26, 2010 | Compaq Armada E500 Notebook
I don't remember keys for enter in to bios Compaq Armada 1590DT
Hi
Remove the bios battery and put it back and it will not request password from you anymore.
You go to the manufacturer for them to reset it for you.
Thanks
Aug 19, 2010 | Compaq Armada 1590DMT Notebook
How can I boot to usb using compaq armada?
after pressing the on/off button immediately keep on tapping F12 and the boot menu will appear on your screen, just select the USB and press enter
Jun 12, 2010 | Compaq Armada 1590DMT Notebook
Hp compaq nx7400 - battery died and power cord will not turn comp
Some laptops will not power up with a completely discharged or faulty battery. Remove the battery from the laptop, plug in the power cord and try to boot the system. If the system boots, your battery needs to be replaced. Replace your battery as soon as you can, it's not a good idea to run the laptop for extended periods with an open battery bay.
May 07, 2009 | HP Compaq Presario V2000 Notebook
Booting problem
You need to do power drain
step1. remove battery and ac adapter from your laptop
step2. HoLD POWER BUTTON for 30secs-1mint
step3. put back battery and ac adapter
step4. power on it sud boot normally
try this hope it helps you
Feb 25, 2009 | Compaq Armada E500 Notebook
Compaq armada 1580DMT
Sound's like you've had a hsrd drive crash. The message 32768 kb ok is a memory test, this indicates that something went wrong with the operating system the last time it was shut down. It should, after the memory test, either correct the system problem or give an error code. Since it does nothing, this indicates that the hard drive has failed and, unfortunately, needs to be replaced.
Jun 20, 2008 | Compaq Armada 1590DMT Notebook
Compaq Armada M700
Always start with the simplest solution first so start by cleaning all the contacts, AC adapter laptop plug, laptop socket, laptop battery contacts and battery contacts. How have you confirmed power output from the AC adapter? have you used a voltmeter to ensure you are getting power at the laptop end? Have you used a voltmeter to test the battery? Assuming you have tried all this don't forget that almost any component can interrupt power on some laptops, however you're 2 main culprits with this kind of problem are usually power controller (voltage regulator) and in some cases, on a laptop of this vintage, the charge controller built in to the battery. Try it with a different battery if you have one.
Aug 10, 2007 | Compaq Armada M700 Notebook
Power failure
Hi Asadi Hope you doing good. Please try the following solution : 1. Disconnect the power cable. 2. Take out the battery 3. Keep holding down the power button for 60 seconds. 4. Put the battery back in. 5. Connect the power adapter 6. Make sure the Power adapter is switched on and laptop is on AC Power 7. Wait for 5 minutes and try to restart the computer 8. If it still doesn't starts. 9. Hold down the power button for 60 seconds with AC adapter and battery connected 10. Try to restart now and check. 11. If it still doesn't switch on 12. Take out the battery and run on only Ac adapter and restart. Please advise if this still doesn't helps. Regards Harry
Jun 14, 2007 | Compaq Armada M700 Notebook
Compaq Armada 1590DMT Notebook Logo
79 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
