Question about Riso RZ220 Duplicator
Riso mz error t44 - Riso RZ220 Duplicator
How do I make my MZ 770 Riso accept a different ink so I can change its color? Thanks
These newer models use a different ink. Trying to change the color this way will have disastrous results because the machine will use certain settings for, say, blue ... if Blue is not in the tube, though, you will end up painting the inside of your Riso.
Apr 08, 2014 | Riso Office Equipment & Supplies
How do I enter the Test Mode on my RISO 790 duplicator?
Do you mean into the unprotected mode?, if so
Turning OFF Protect mode in a Riso MZ 790u (and other models I'm sure).
1. Go to Admin Tab on the main console screen and scroll to the "Protect" button.
2. Select (press) the "Protect" button on the screen; printer will go through a reset function (takes about 3-5 seconds).
3. After printer is finished "resetting", pull out one of the master disposal boxes (doesn't matter which one).
4. Press the "Protect" button again.
5. the screen should say "Protect = Off"
6. You're done and your machine should be un-locked now.
May 11, 2011 | Office Equipment & Supplies
ERROR CODE T04-513 FOR RISO RP 3790
riso rp 3790 no imprime, no copia, me dijeron que borrara errores pero no se donde, creen que sea eso
Feb 27, 2010 | Riso Office Equipment & Supplies
Riso rz230 aw has error codes d-04 -534
riso mz series has error codes D04-534 and D44-538
Jan 06, 2010 | Riso RZ220 Duplicator
Asoon as i turn on my copier sereis it displays code p-96-569
This error code means either the print drum color information or ink category information is not input. Easy fix.
Make sure the drum in the machine has ink in it. It must be the correct ink for use in an EZ. Start into test mode by turning the machine on while holding down the left and right arrows for the print position. Hit the "C" key to clear out display. Should read 0000. Type in 590, then hit start. Type in 557, then hit start.
Machine will load information from the ink bottle into the machine and rotate a few times.
Once it stops, turn off and back on to get out of test mode. All set!
Jun 12, 2009 | Riso RZ220 Duplicator
I have a Risograph 3100EP with the code T05-604 HELP ME !
Hi try resetting the machine by switcting off and then holding down 2 top right hand buttons and switching on machine, let go buttons then switch off and on to leave service mode.
Jan 20, 2009 | Riso RZ220 Duplicator
Error code E4 for riso ks800
riso ks 800 error code c-7
Dec 06, 2008 | Riso RZ390 Duplicator
44 people viewed this question
Top Riso Office Equipment & Supplies Experts
Marius Chiriac
paulfvincent
Adorjani Laszlo
Are you a Riso Office Equipment and Supply Expert? Answer questions, earn points and help others
