Question about Hayward Pool & Spa
Cant get the pool and spa heater to work
Pool and spa heater won't come on
  • 3 Answers
Thank you for posting about this. I have been having similar problems. I am thinking about just giving up and hiring a pool repairman!
Ruth James ' http://www.kenspool.com/
Posted on Jan 13, 2014
4 Suggested Answers
  • 5 Answers
SOURCE: I have Jandy RS4 system with 4-button poolside
Pull the cover off the control panel. You will probably find a button which would be accessible from outside the panel with a paper clip or pencil but is unlabeled. On the board itself by the button, in small letters it should say "reset". Push the button and see what happens.
Posted on Oct 09, 2009
  • 990 Answers
SOURCE: Purex Triton Minimax 400 pool/spa heater not igniting
This sounds like you have a problem with your pilot. You can check this with a small mirror to see if their is a spark when you turn it on. If you have any soot build up on the pilot that will stop the spark and keep it from lighting also. If you have a short on your pilot wire this could be the problem also. I hope this helps, good luck.
Posted on Dec 12, 2009
  • 10 Answers
SOURCE: I have a Jandy Laars LX Pool/Spa Heater...when I
If the unit is lighting then shutting off then repeating it isn't rectifying, means not sensing the flame. May have a bad flame sensor or ignition control. I'm guessing your AGS is indicated on the GUI also.
Posted on Mar 07, 2010
Heater won t stay lit
check gas pressure sounds like running out of gas meter might be too small
Jun 23, 2013 | Hayward Pool & Spa
Laars xl 400 heater off line
turn off aqualink then turn back on it should see it
Jan 25, 2013 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Pool heater won't heat water
How big a pool? You normally will not notice a temperature rise immediately. On average, swimming pools will see a one degree rise in temperature every 45 - 90 minutes.
Jan 22, 2013 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Raypak spa heater pr5 service code message
check pressure switch if no voltage both sides of switch bad switch or plugged copper line or loose wires
Oct 02, 2012 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
The heater won't light up on my Jandy LXi400n Lxi heater
make sure red light is on for calling for heat if so make sure 24 volts ac on both sides of pressure switch if ok make sure gas is on
Jul 13, 2012 | Jandy LXI400N Lxi Pool & Spa Heater -...
I have a new max-e-therm pool heater and after hookup everything seem fine but it won`t ignite they have leds to tell you the problem and it says ( ignition Lockout) but does not say more and I can`t find...
The users manual for these pool heaters is very thorough and address this problem in the flow chart. Try that and see if you get the solution you are looking for. A lot of the questions needed to troubleshoot cant be answered unless you are looking directly at the heater.
http://www.backyardcitypools.com/images/bwp/Max-E-Therm-Manual.pdf
Jul 10, 2010 | Sta Rite Sr400na Max E Therm Pool & Spa...
PLEASE HELP.....cant not get Batizime pool to heat up.
something is wrong with the voltage it should be 240 when you test the heater terminals, i think the heater relay isnt making a good contact. but i would check for 240 at the main panel and chase the wiring to find the voltage drop.
Apr 02, 2010 | Hayward Comfort Zone Electric Spa Heater...
Pool & Spa Logo
214 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
