Question about Kohler Plumbing
Quick disconnect valve - Kohler Plumbing
  • Tim Hofstetter
    Tim Hofstetter Jul 26, 2014
    Your question is...?
Location of canister vent valve solenoid on 2009 f150
For a 5.4L V8 Flex...canister Purge Valve--centered right behind the throttle body. Should see a hose with a quick disconnect and an electrical connector on one side (driver's). Opposite (passenger) side has another 6-8 inch hose that runs from the valve to the engine with a quick disconnect on the engine side. The valve itselve is about 2-3" long, black cylinder (google Motorcraft CX2447 for picture)! Very easy to replace yourself (5 min job). Remove the electrical connector (push in on rear side and pull), remove the two quick connects by squeezing the gray prongs and pushing the connector outward. Hose should slide right off. Pull valve off of bracket (there is a rubber piece that holds it on--it will slide off of the metal bracket, but have to wiggle it loose), replace part, reconnect hoses/elect and you're done. Just make sure the hoses are fully seated.
The actual canister is a black box on the inside of the frame beneath the driver side (have to get under the truck pretty far to see it). It has about 3 hoses running to it from the fuel tank. On side facing the front of the vehicle, you'll see a hose that runs up through the firewall to the purge valve.
it's mounted above where your spare tire is on some of the other motors its above your spare tire
Mar 24, 2017 | Cars & Trucks
How do I remove the gas tank out of a 2006 Ford 500 no one knows
SECTION 310-01: Fuel Tank and Lines 2006 Freestyle/Five Hundred/Montego Workshop Manual REMOVAL AND INSTALLATION
All vehicles
  1. With the vehicle in NEUTRAL, position it on a hoist. For additional information, refer to Section 100-02 .
  1. Release the fuel system pressure. For additional information, refer to Section 310-00 .
  1. Drain the fuel tank. For additional information, refer to Section 310-00 .
All wheel drive vehicles
  1. Remove the rear driveshaft. For additional information, refer to Section 205-00 .
All vehicles
  1. Remove the muffler. For additional information, refer to Section 309-00 .
  1. Disconnect the fuel vapor control tube assembly valve-to-fuel vapor tube quick connect coupling. For additional information, refer to Section 310-00 .
  1. Disconnect the fuel supply tube-to-fuel filter quick connect coupling. For additional information, refer to Section 310-00 .
  1. Disconnect the fuel vapor tube-to-fuel vapor control tube assembly valve quick connect coupling. For additional information, refer to Section 310-00 .
  1. Disconnect the fuel tank wiring harness electrical connector at the rear of the fuel tank.
  1. Release the clamp and remove the fuel tank filler hose from the fuel tank.
  1. Place a suitable lifting device under the fuel tank.
  1. Remove the 2 front fuel tank strap bolts.
    • To install, tighten to 35 Nm (26 lb-ft).
  1. NOTE: Do not bend the fuel tank straps.
    Loosen the 2 rear fuel tank strap bolts and position the 2 fuel tank straps aside.
  1. Lower the fuel tank enough to move forward, clear of the fuel straps then complete the lowering procedure.
  1. To install, reverse the removal procedure.
Procedure revision date: 08/19/2009
May 03, 2016 | Ford Cars & Trucks
Purge solenoid location 2008 torent
Evaporative Emission Canister Purge Solenoid Valve Replacement
Remove the fuel injector sight shield. Refer to Fuel Injector Sight Shield Replacement. Disconnect the engine wiring harness electrical connector (4) from the evaporative emission (EVAP) purge solenoid.
Remove the oil fill cap. Lift upward and remove cover from ball studs.
The purge solenoid is under the plastic cover on top of the engine .
Disconnect the EVAP pipe quick connect fitting (1) from the EVAP purge solenoid. Refer to Plastic Collar Quick Connect Fitting Service.
Disconnect the EVAP pipe quick connect fitting (2) from the EVAP purge solenoid. Refer to Plastic Collar Quick Connect Fitting Service. Remove the EVAP purge solenoid bracket bolt (3). Remove the EVAP purge solenoid.
the purge
Sep 20, 2014 | 2008 Pontiac Torrent
Leaking fuel line at quick disconnect
Since it has a Quick Disconnect it means you don't have a petcock since it is fuel injected. There have been several people that have had problems pushing it up all the way before releasing the collar. Please try and make sure it is pushed up all the way to the max before releasing the collar. It may seem like it is up there because it is locked into place but it will lock without being completely sealed against the seal of the valve assembly.
Jan 11, 2014 | Harley Davidson XL 1200 C Sportster Custom...
How to repair quick disconnect fitting 2002 harley ultra
Hi Anonymous, for more information about your question please visit the websites below. Good luck and have nice day.
Harley Check Valve Rebuild Kit
Jul 01, 2012 | 2002 Harley Davidson FLHTCUI Electra Glide...
Where is connection
    • Locate the accumulator bolted to the firewall on your automobile. It usually bolts to the passenger side firewall but this is not a rule. However, it will be located on the passenger side of the engine bay. The accumulator is approximately 12-inches in length, 4-inches in diameter and has at least tow large hoses extending from it. These hoses are the high side and low side hoses. Locate the metal portions of the high side and low side hoses. Each hose comprises of a hard-metal line and soft-rubber line secured together. The metal portion of the hose bolts to the accumulator. Locate the low side and high side valves. They are located on the metal portion of the hose connected to the accumulator and both have black plastic caps covering them. The high side valve is a 16mm quick disconnect valve and the low side valve is a 13mm quick disconnect valve
Jun 08, 2012 | 1998 Dodge Caravan
How do you change the pvc valve
Not sure on your engine so heres both types. :-) Hope it helps. Cobra
Positive Crankcase Ventilation (PCV) Valve — 3.0L (2V) Removal and Installation
  1. Disconnect the positive crankcase ventilation (PCV) valve tube quick-connect from the PCV valve.
CAUTION: A new PCV valve must be installed if removed from the cam cover. Damage will occur to the locking mechanism on the PCV valve.
Remove the PCV valve.
  • Disconnect the PCV valve electrical connector.
  • Rotate to release and remove the PCV valve.
Positive Crankcase Ventilation (PCV) Valve — 3.0L (4V) Removal and Installation
  1. Disconnect the positive crankcase ventilation (PCV) valve tube from the PCV valve
  • CAUTION: A new PCV valve must be installed if removed from the cam cover. Damage will occur to the locking mechanism on the PCV valve.
  • Jun 13, 2010 | 2005 Ford Taurus
    Were is the low side cherging port on a 96 lincoln town car
    Should be reciever/drier pass side undehood.will be fitting with black cap their.Attach to port with charge line .Must have engine running and compressor on.
    Jun 19, 2009 | 1996 Lincoln Town Car
    I purchased the Porter Cable 20 piece accessory kit part A00438, and no idea on how to assemble this. No instructions included either. This is the kit that allows to put airpressure in your car, bikes,...
    First get some teflon thread tape, for applying 2 or 3 tightly wrapped turns around the male threaded quick-disconnect adapters, threaded end on your air hose and compressor before installation.
    Note: remember that the female quick-disconnect adapter is also a check valve that will only release air when a male quick-disconnect adapter is inserted, i.e. do not install a  male quick-disconnect adapter directly to an air compressor outlet.
    Note 2:Always remember to wear approved eye protection when operating air tools.
    Start by installing the female quick-disconnect adapters on a male threaded end of the air hose and on to the outlet port on the air compressor tighten the connections with two open end wrench's. Then install the male quick-disconnect adapters to the other end of the hose, blow-gun tool, and the air chuck tool, (tighten as described above). The other implements in the kit (wire brush attachment, inflation needle, etc...) can be threaded in to the outlet port of the blow-gun as needed.
    The operation of connecting  quick-disconnects are as follows: Grasp the tool in one hand, and with the other hand grasp the air line near the end leaving the thumb and fore finger free to operate the spring loaded outer release cylinder on the female quick-disconnect by pulling back on it. With the cylinder pulled back, insert the male quick-disconnect adapter in to the female quick-disconnect adapter, then release the thumb and fore finger from the outter release cylinder, thus locking the two together. check to be sure the lock has engaged by lightly pulling at the tool. Reversing this process will disengage the tool from the air line.
    Hope this helps Good luck
    Feb 21, 2009 | Porter Cable C2002 Wk Oil Free Umc Pancake...
    Plumbing Logo
    106 people viewed this question
    Top Kohler Plumbing Experts
    Mike
    Donni Steen
    Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
