Our leapfrog leap reader(tag read and write pen) shows a green light when coonected via USB but won't turn on.....what to do?
When I plug it in to a wall charger via usb cable it will turn on, but is unresponsive when plugged in to either of our computers or when it's not plugged in. it has charged overnight, and appears charged when plugged in
SOURCE: my samsung blackjack 2 will
If the Red Led stays turned on it is as simple as this.....the solder connecting your power on button to the system board in your phone has worn off..... you must pop the power button at the top of your phone off and you will be able to see where the soldering paste has simply worn off. At my job I have a soldering machine so it was not problem for me. I simply took pasted it back to the board with tin.....now this may require some work. just pop off the top section of you phone with a flathead screw driver and pop out the power button. look closely and you should be able to see where the botton has lifted from the little greenish system board..... Find someone to solder it, put it back together and it works like new.........SEE YA
Posted on Nov 18, 2008
SOURCE: Jazz DV-179
YOU PEOPLE IT IS JUST THE BATTERY THAT IS IN IT!.. BECAUSE THAT BATTERY IS NOT ONLY FOR AFTER IT IS CHARGED IT ALSO WORKS TO SHOW THE DISPLAY SCREEN! BECAUSE IF YOU TAKE OUT THE BATTERY THE LIGHT STAYS ON WHILE ITS PLUGGED INTO THE COMPUTER! MY BF IS HAVING THE SAME PROBLEM TRY BUYING A NEW BATTERY!! ITS THE SOLUTION! the battery is caput!
Posted on Apr 06, 2009
jws8118
  • 27 Answers
SOURCE: i phone non responsive wont charge or turn on
Based on your description, it sounds like this iPhone logic board isn't working properly. It could be related to the power management unit, or the battery could have simply become desoldered if you dropped the unit.
Another cause for this problem could be from water damage which may have fried the PMU chip. If this is the case and you're not experienced with BGA removal/replacing then you're best bet is probably to sell the unit AS IS for parts or repair on eBay, Craigslist, or you could sell it to me.
Hope this helps!
Posted on Jul 08, 2009
  • 8 Answers
SOURCE: IPod Nano will not turn on unless plugged in to
I would send it in to get repaired or replaced if the toggle is broken since there is probably not much you can do to fix it yourself.
Posted on Aug 18, 2009
SOURCE: Cannot turn my i pod touch on
your ipod seems to be having problem like damaged system software. you can reinstall your ipod software but will erase anything on your ipod, don't worry you can sync them again. here's how to do it.
make sure itunes is open and connected to the internet.
Hold down your ipod power button, then hold down the home button too, this will force the ipod to restart and in restore mode.
the screen will go dark and restart, now release the POWER BUTTON while still holding down the HOME BUTTON.
It will show an itunes icon and a USB icon saying connect to itunes.
NOTE: you might have to do this procedure many times in order to show the itunes and usb icon.
Now release the HOME BUTTON and connect to itunes, it will erase your ipod and download software from apple to install on your ipod.
this might take some time, wait for it to complete the task and now you are ready to use your ipod again.
Please rate. Thank you
Posted on Sep 17, 2009
Leap frog scribble and write. Pen wont work
it only works for the specific leap reader pen paper
Jan 19, 2014 | LeapFrog Tag Reading System
Leap reader won't turn on
I'm having the same problem with mine but on the faq on the leap frog connect i read that the product was defective and to contact customer support with it
Dec 26, 2013 | LeapFrog Toys
I installed my leapfrog connect for my Tag reader. It says to plug in the Tag with the USB cable to the computer ( which i did) and turned it on. For some reason its not picking up so i cant go to the...
it depends on what Operating system your using, if xp then goto devices in the control panel and click on detect new devices, also check there if the usb drivers are installed, sometimes you have to install the software before plugin it in. if it's win7 then again click on devices and also check my computer when the usb is connected, and again install the software before plugin it in. best regards.
Oct 30, 2013 | LeapFrog Tag Reading System
Tag will not update
try downloading it on another system and transfer it to yours.
Aug 11, 2012 | LeapFrog Tag Reading System
The Save to Tag button on the leapfrog connact application does not do anything and so none of the audio will download from the library to the actual tag device
mine is doing the same thing. it's brand new. my daughter got it for christmas yesterday. i've even tried it on my husband's macbook. both our macbooks are up to date and her leap pad works. i'm about ready to take this stupid thing back to the store. it synced all the books except for her tangled book and will not sync again. i've even tried to restore back to factory settings and it won't even do that. i've deleted and reinstalled the leapfrog connect app 3 times. also seems that the stupid pen sucks down battery juice. i've put brand new lithium batteries in the pen and after 2 hours the pen is acting like it's dying and the only thing we've been doing is trying to sync it.
Dec 25, 2011 | LeapFrog Tag Reading System
Leap frog tag pen won't work any longer.
You can purchase new one from amazon LeapTV Educational Active Video Gaming for Kids. I hope this was helpful. cheers
Mar 03, 2010 | LeapFrog Tag Reading System
My daughter's Leap Frog Tag reader pen will simply not turn on. I bought new batteries nd tried them all. What should I try?!
Hello I will try to help you. If the pen was working up until the batteries died then the problem logically would be solved by putting in new batteries. That said, remove the "new" batteries and install them in another device to be sure that they are good. Some new batteries die in the package before being used.
Then make sure you are putting the batteries in correctly, pay attention to the + and -.
Finally, you can clean the ends of the battery chamber by using a pencil eraser and rubbing it on the metal contacts.
Let me know if one of these things fixes your problem as I have additional ideas.
Jun 08, 2009 | LeapFrog Tag Reading System
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
