Question about Maytag (MFI2568AEW) Bottom Freezer French Door Refrigerator
Maytag mfi2568aew not cooling
Cleaned condensor coils, fans are running evaporator line freezes no frost on back freezer panel
SOURCE: Maytag fridge made some clicking noises and then stopped cooling
For what it is worth. I had this problem twice and both times the compressor ad to be replaced. Ton this day it sounds like a pin pong game whenever it runs. No it is not the fans or the ice maker.
Posted on Feb 13, 2008
  • 143 Answers
SOURCE: Maytag Model MZD2766GEW iced coils
This sounds like a defrosting problem. There is a defrost timer, a heater element, and a therm-o- disk thing that shuts the heater off when the frost is melted. These are the things to check, but it's usually the heater that is burnt out.
Posted on Jul 23, 2008
  • 22 Answers
SOURCE: Refrig not cooling Freezer has frost build up on coils
Frost on the coils won't allow air to pass to the fresh food section, thus resulting in insufficient cooling. To eliminate this problem, you will have to get a new adaptive defrost timer ( small board ), and a defrost heater assembly.
Posted on May 04, 2009
  • 363 Answers
SOURCE: maytag mff2557hew fridge not cooling. Freezer ok.
Sounds like the Freezer Fan is wearing out or is worn out. This fan problem is very hard to detect. The reason is that when the motor is starting to wear out the fan will spin, but at a much lower rpm. This is enough to keep the freezer cold. but will not ciculate enough air thru the freezer and the refrigerator to prevent freezer from and refrigerator from cooler. The cost to repair/replace this fan is a minimum of $300.00
Posted on Jul 28, 2009
Testimonial: "Your solution was right on the mark! The fan was spinning but not fast enough (according to my repair guy). Thanks again!"
SOURCE: maytag refridgerator model MSD2651HEW refridge not cooling properly
my water dispencer has a low flow after an initial regular flow. why?
Posted on Sep 05, 2009
Where is the evaporator fan motor? My Freezer and fridge would quit cooling/freezing. I took the back panel off in the freezer a week ago and the evaporator coils were completely frozen over with ice. I...
I do not believe the problem is the fan. sounds like the frig. is low on Freon this is what will cause the ice build up. you need to find the leak, you can do this by spraying soapy water on coil tubes & watch for bubbles. repair leak & recharge.
May 25, 2015 | Samsung RS261MDBP Side by Side...
My LG bottom freezer refrigerator is not cooling
check in the ducting in between the freezer and fridge compartment for obstructions such as an ice ball or collapsed lining
Apr 05, 2014 | Refrigerators
Kelvinator fridge compressor running constantly, but freezer section barely freezing
CHECK THE CONDENSER COILS UNDER THE UNIT. THEY PROBABLY ARE DIRTY AND CANT REJECT THE HEAT.
Oct 18, 2012 | Kelvinator Refrigerators
Side by side thermostat set low seems like it runs a lot more than it use to freezer and fridge are boyh cold
Check your coils underneath the fridge to be sure they are clean.
Check your condensor fan (bottom rear of fridge) to make sure it is blowing air freely.
Make sure you have a good supply in the freezer, All of your cooling comes from the freezer section and a mostly empty freezer will result in more frequent running as ther is not enough stock to help maintian and hold freezing temperatures.
Check your freezer section to make sure there is no visible frost on the back wall of the freezer (down low on the panels behind and slightly above the lowest freezer basket. If you see frost starting to develop it means you have a defrost issue starting and will want to adress it rather quickly. Either a problem with the defrost control board (inside fridge/freezer control compartment) or the defrost thermostat (behind the freezer back panel on top of the evaporator coils).
Hopefully this helps!
Jun 14, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
The evaporator fan is not blowing
The evaporator fan should be running. A light frost is what you want to see. Just no heavy frost, that would indicate a defrost problem. Check the fan for power if it has power and it is not running replace it.
Jun 11, 2010 | Frigidaire FRS6R5ESB
Maytag Model RSW24EOD. Not cooling. Frost on freezer back wall
Low on freon or there may be accumulation of dust and dirt on the coils of the condensor. To check to see if the coils are dirty you need to remove the bottom panel of the fridge just below the frige door. Once you pop off this panel take a flashlight and look under the unit. You will see what looks like a radiator with a fan and fan motor in front of it. If these coils are blocked the unit will not cool since this is where the heat goes from the fridge to be dispersed. Clean the coils with a coil brush (purchased at any hardware store) and use a wet/dry vacuum to remove the debris. Once these coils are cleaned it will take about 12 hours for the unit to operate properly.
If the coils are clean already then you possibly have a compressor that is low on freon. I would check the coils first since most of the time this is the cause of the problem.
Good luck on your repair hope this helped you some
Dave
Jan 29, 2010 | Refrigerators
I have a 20 year old sub-zero refrigerator. For the last two weeks the refrigerator is so cold that everything is freezing. If I turn down the thermostat the freezer warms up.
It sounds like the freezer side is losing its capacity......All cooling done on the refrigerator side is done by air flow of the fan in the freezer compartment by the evaporator coils(aluminum fins looks like a radiator)
You might want to pull the back panel of the freezer section and look at it.
Normally it is fully frosted when running(whitish snow covering on evaporator) If it is only partially frosted it has a freon leak or compressor problem. If it is engulfed in frost and there is no air flow possible through it your defrost system has failed.My guess is it is partially frosted and you have a freon leak.
Also check the fan by the compressor is running on the outside and the condensor coils on the outside on the bottom are clean.( fan runs when compressor runs)
A
Jan 14, 2010 | Frigidaire FRS266ZDSB Side by Side...
Condensor line has frost on it and the fridge part isn't cold but the freezer works
A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
Evaporator coils
Condenser
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
Aug 03, 2009 | Refrigerators
Freezer not freezing
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Jul 11, 2009 | GE Refrigerators
TRUE under counter FREEZER TU2-27F
Are both evaporator fan and condensor fan running?You stated that you topped off the charge.Assuming the charge is ok, the next thing to check would be the expansion valve.May not be metering the freon properly.A faulty expansion valve can trick you into thinking the unit is undercharged.It may be partially open and starving the evaporator.(Not freezing the water totally)You should have a even coating of frost on the evaporator coil when running.Hope this helps,let me know if i can assist you any further.
Dec 10, 2007 | True 12 cu. ft. / 340 liter Commercial...
Maytag (MFI2568AEW) Bottom Freezer French Door Refrigerator Logo
24 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
