Question about Sierra Print Artist Platinum
Printing labels unable to fill the avery 8160 label page,how do you get the text from one box to all 30 labels
How to make address labels
Get the Avery plug in for word from the Avery web site. It makes things so easy if you do.
Aug 18, 2014 | Avery 5160/8160 compatible (100 White...
I have an Access file with 132 names with addresses. I want to print them on Avery labels. How can it be done?
Avery labels have an ID# that when entered into the Avery site will supply you with the page format for your Msoft Office software.
Dec 14, 2011 | Avery 5160/8160 compatible (100 White...
Will not feed Avery 8160 labels
While that printer's specifications (http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00718670&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&lang=en&product=1153754#N415) allow up to 30 labels in its paper tray & up to 25 in its output tray, Avery® often recommends (if not instructs) only feeding one sheet in at a time.
Jan 11, 2011 | HP Photosmart C7180 All-In-One InkJet...
I have a Kodak ESP 5200 series printer. When I try to print Avery 8160 address labels the sheet comes out not printed.
Hi
You can try and download the label again from below link--
Avery 8160 label download
Click the "Download Template" button. Enter your info and click "Submit". Follow the prompts to download the file. After you download your Avery template, be sure to remember where you saved the file on your computer and the file name. Open Microsoft® Word or an Adobe® program for your template and select File > Open to navigate to the drive and folder to open your template. Use the program's formatting and printing features to edit and save your template. For Microsoft® Word users - If the template looks like a blank page, select Table > Show Gridlines to view the template layout.
Hope this helps... Please post back if you need more information.
Daniel
Dec 18, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
How may I format 10 labels / page using Avery 8163
right click your printer. go properties. select printimg preferences. select features. find page selections & choose
Jul 25, 2010 | Computers & Internet
Photosmart C4280 all-in-one. Problem is only with label paper. It prints 3/8" too high throwing everything out. If I change the original, it is fine for three or four sheets but then changes again. It...
You've probably tried this, but I did have success today with Avery 8160 labels. I had been using 5260 labels. There is a difference at the top of the page in the way the backing lines up with the labels.
Nancy
Nov 30, 2008 | Office Equipment & Supplies
How do I Print Address Mailing Labels from Avery 300-Easy Peel White Mailing Labels, on Windows XP,CP?
You'll need the actual Avery code for this, or at least the correct measurements.
Open up Microsoft Word. Go to 'Tools' and find 'Letters and Mailings' in the list. Then off of that is 'Envelopes and Labels'. Click on that one and a box will pop up. If you click on 'Options'. From here you can find the correct label settings by the code which will be on the Avery pack. If you haven't got the code, you can scroll through the lists and highlight options to see the measurements but this will take you a while.
Once you chosen your labels, click on ok. Now you can enter your address in the box and print a whole page of the same address or click on 'New Document' and that will give you a page set out correctly for that label sheet.
Nov 19, 2008 | Computers & Internet
I can't get Avery 8160 labels to print on our HP computer with Vista microsoft; it would print out one column but not the three that are on the label sheet. Help!
Its possible that you are trying to use software designed for windows XP or such, Vista will not normally work with earlier software. Check to see if there is vista compatable software available.
Aug 29, 2008 | Avery Office Equipment & Supplies
Avery laser addressing labels l7160
What software are you using? I use Microsoft Word to print my Avery labels, and quite often have to tweak their templates by simply adjusting my margins on the page. I do a 'select all' and then add one tenth of an inch at a time until the proof sheet looks just right. If the labels are a bit off, you can also adjust the pitch in the label options dialoge.
Oct 08, 2007 | Avery DesignPro 2000 for PC
Sierra Print Artist Platinum  Logo
22 people viewed this question
Top Sierra Computers & Internet Experts
Glenn
Glenn
Jacqueline
Are you a Sierra Computer and Internet Expert? Answer questions, earn points and help others
