Question about Human Touch Ijoy 100 Robotic Massage Chair Camel
Panasonic massage lounger model EP l1260 set of belts
I want a belt sets for model EP1260 urgent please
Panasonic electric massage chair EP-1001: NEED A NEW SHAFT... CAN YOU HELP WITH PARTS ?? IF SO..COST ALSO. THANKS.. JACK SOKOLOWSKI nightmanmi@aol.com
All parts and service manuals can be obtained by calling the Panasonic National Parts Center directly at 1-800-332-5368 9am-8pm EST during weekdays.
Oct 20, 2013 | Furniture
Need power cord for shiatsu model 8173
where can I find a cord for my shiatsu recliner, model #8173, thank you
Oct 10, 2013 | Panasonic Shiatsu Massage Lounger with...
PANASONIC EP 1004 MASSAGE CHAIR : ROLLERS WORK BUT ARE STUCK AT THE TOP OF THE CHAIR. WHAT DO I DO?
I have one of these chairs, and it quit on me last week. The problem is that the up/down clutch is getting stuck. First, download the service manual here:
http://www.nodevice.com/manual/newmans/panasonic/EP1004NASIMPzip/get25127.html
After opening it up, locate the up/down clutch. It is on the bottom right of the control module. Use a 10mm socket to remove the bolt that holds the belt pulley on. Remove the belt pulley and under it is another big metal disc - the clutch. The problem is that there is a black rubber gasket under the clutch disc that decomposes and makes the clutch stick to it. I scraped the black rubber off and reassembled, and now, it works perfectly. In my case, the rollers didn't even work. This is because the massage clutch, which operates the rollers, also had the same problem.
Feb 23, 2012 | Health & Beauty
My i joy massage chair stays in middle position one of the buttons allows it to come on for just a few minutes then it turns off.what can i do to fix it?it does not go up and down
sounds like the drive treads are clogged with fabric from the chair. Unzip front fabrics to expose mechanism and check for a jam. Unplug unit and carefully remove jam with pliers
Aug 07, 2010 | Human Touch HT 2620 iJoy Massage Chair
Finding KSI owner
I found the guy by basically google it.
Sep 18, 2009 | Panasonic Shiatsu Massage Lounger with...
I HAVE PANASONIC MODEL NO. KX-FLB802. THE PROBLEM
In this order, press:
menu - # - 9000 - * - 550 - set - menu
then also:
menu - # - 459 - 1 - set - set - menu
Jun 14, 2009 | Panasonic KX-FLB801 All-In-One Laser...
Instruction manuel for massage lounger panasonic ep 1260
Hi, Went to Google and instruction manuals. From there, I made the proper selection.
Jan 30, 2009 | Panasonic Shiatsu Massage Lounger with...
Human Touch Ijoy 100 Robotic Massage Chair Camel Logo
46 people viewed this question
Top Human Touch Furniture Experts
ray gallant
Michael Vincent Cruz
Are you a Human Touch Furniture Expert? Answer questions, earn points and help others
