Question about LG 50PA5500
How to take stand off - LG 50PA5500
Is universal TV stand #3755BB a wall mount as well as a just a stand?
Hi Jo,
this is designed to be a stand not a wall mount, here are the spec's for it:
MISC STAND 3755BB 37 55 Lcd led plasma Stand
Jan 23, 2016 | Televison & Video
How to attach kick stand spring on 2006 street glide
With the full weight of the motorcycle resting on the jiffy or side stand when it is placed in the full forward and down position it will lock into this position when the bike is leaned over the left side. If it is not in the fully down and forward position and on a flat/level and firm/solid surface when it is leaned over to the left side the bike may fall down.
To Remove the Jiffy Stand
WWAARRNNININGG
Block and support the motorcycle under frame to be sure that it is securely upright and level and so that the jiffy stand can be moved throughout its full range of travel and so that it will not fall down or onto the repair person when the jiffy stand is removed.
Then move the jiffy stand to the retracted i.e. up position and remove the ****** nut and leg stop from the threaded end of the jiffy stand leg and then move the jiffy stand leg to the full forward position which is the full down position and grasp the end of the jiffy stand spring as close to the frame tube as possible, and then twist and turn the end with needle nose pliers to unhook it from the frame hole. THEN remove the jiffy stand leg from its bracket, inspect the entire jiffy stand assembly for worn or damaged parts and replace them as found necessary.
To Install the Jiffy Stand
First lubricate the jiffy stand leg with an Aerosol Anti-Seize Lubricant but only in the area of the jiffy stand leg part that rotates within the bracket. THEN insert the threaded end of the jiffy stand up through the bottom of the bracket and with the jiffy stand in the full forward position, partially install the spring end into the frame hole and with a rap to the spring with a rubber mallet fully seat it in its hole. Be careful to insert the end of the spring into the hole at the front of the jiffy stand leg piece in front of the jiffy stand leg piece weldment because if it is inserted from the rear of the hole in the leg piece the coil of the spring will interfere with and rub on the leg piece when the jiffy stand is used and if it is installed incorrectly over time it will wear and the motorcycle could fall over due to this wear. THEN while holding the jiffy stand leg at the full forward position, install the leg stop over the threaded end with the stamped side down, install the ****** nut and tighten it to 43-53 ft-lbs which is 58-72 Nm. NOW verify that the longer side of the leg stop faces towards the rear of the motorcycle, extend and retract the jiffy stand leg several times to verify that it operates properly, freely moving to both the full up and the full down positions with no spring or other interference or contact and verify that the rubber stop is correctly in place on the jiffy stand prong because without the rubber stop correctly in place the stand will make improper contact with the lower frame tube when the jiffy stand is retracted and will then likely chip and/or nick the powder coat. AND, of course if the rubber stop is deteriorated or missing. Replace it with a new one. FINALLY carefully remove the support blocking from beneath the motorcycle frame and let the motorcycle rest on the fully extended jiffy stand leg.
Sep 15, 2014 | Motorcycles
How do i change the brushes in my kitchenaid mixer?
Solution for these KitchenAid Stand Mixer Models
  • KitchenAid Stand Mixer Service Manual - K45SS
  • KitchenAid Stand Mixer Service Manual - K5SS
  • KitchenAid Stand Mixer Service Manual - KP50P
  • KitchenAid Stand Mixer Service Manual - KSM50P
  • KitchenAid Stand Mixer Service Manual - KPM5
  • KitchenAid Stand Mixer Service Manual - KPM50
  • KitchenAid Stand Mixer Service Manual - KSM75
  • KitchenAid Stand Mixer Service Manual - KSM90
  • KitchenAid Stand Mixer Service Manual - KSM103
  • KitchenAid Stand Mixer Service Manual - KSM110
  • KitchenAid Stand Mixer Service Manual - KSM150
  • KitchenAid Stand Mixer Service Manual - KSM151
  • KitchenAid Stand Mixer Service Manual - KSM156
  • KitchenAid Stand Mixer Service Manual - KSMC50
Fix KitchenAid Stand Mixer Workshop Service Repair Manual Download
Jun 18, 2014 | KitchenAid KSM90 Ultra Power Series Stand...
Looking for table top stand for Sony LED TV
Just try by any authorized dealers for Sony. If not available, check www.alibaba.com
Nov 27, 2013 | Televison & Video
I can't remove the stand off the tv
Hi, i have instruction on removing your base stand.
Removing the Pedestal Stand
1) Carefully lay the front of the unit face down on a flat,
cushioned surface such as a quilt or blanket. Leave the stand
protruding over the edge of the surface.
Note: Extreme care should always be used when removing
the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose
the pedestal stand screws. The jack pack cover can be removed
without tools.
3) Remove the four screws shown in the diagram below. This will
allow removal of the pedestal stand.
4) Once you have removed all four screws holding the pedestal
stand in place, remove the pedestal stand from the TV by
sliding the pedestal stand away from the TV.
Feb 12, 2011 | Toshiba REGZA 52RV530U LCD TV
Taking stand off toshiba regza tv
forget the four holes on the bottom of the stand. Remove the five allen bolts on the back bottom of the tv-not the stand. Yank on stand and metal plate slides out with stand.
Jan 25, 2009 | Toshiba REGZA 47HL167 TV
Side stand
but no part number associated with it. I was thinking possibly that the side stand on a scarabeo was from previous years and not applicable to my 08. Would anyone have any information on this? It would be great to just drop a side stand lean the bike and walk away.... rather than step off balance the bike find proper footing on the center stand lever and stomp. ,I've been wanting the side stand as well (Aprilia Lateral Stand part# 853489), but according to AF1, it is not available yet. , ,,
Nov 10, 2008 | 2003 Aprilia Atlantic 200
Mounting to TV Stand
there are two types of stands, some are wall type which needs to be mounted using rawl bolts, nuts are suppose to hold a stand, some are ground stands which are suppose to be put on a flat surface in order to balance.
Jul 29, 2008 | Panasonic TH-50PZ77U 50" Class Plasma HDTV
LG 50PA5500 Logo
18 people viewed this question
Computer Repairing
Computer Repairing
