Question about Coby Audio Players & Recorders
Surround sound Only had product for a year and it stopped playing any sound.
Our new lg 5.1 surround sound system will only play full surround sound on some new release blu ray films and the rest will only play through the front 3 speakers as dolby stops as soon as you get past the...
Dolby will only activate when it has information for all 5 channels. For normal stereo only left, right and bass boost speakers work, so you lose center and rear speakers. The system should have an option to play SIMULATED surround sound, to activate all speakers. In many systems, this option is called dolby prologic, simulated or some other fancy name.
Jan 17, 2010 | Audio Players & Recorders
Surround sound not playing TV audio
you need to run red and white from your tv to the surround sound and the same from your dvd to surround sound
May 02, 2017 | Sony Audio Players & Recorders
JVC home theatre system DVD/CD player has stopped working.
Please check the dvd layer lense. When there is lense problem this issue will occur.
Apr 03, 2009 | Audio Players & Recorders
DVD player and receiver will not play a dvd in surround sound ?
The dvd player is responsible for reading the surround sound track, and sending it to the receiver. First make sure you are playing the surround sound track on the dvd, many have a stereo track too. Next, try another dvd and see if you can play surround sound on that one. If you can't play surround on ANY dvd I would start looking at the audio connection from dvd to receiver. Are you using an optical cable? Red, white, and yellow RCA cables? Optical will transmit any sound over only one cable, RCA cables need one cable for each channel (LF, C, RF, LR, RR, sub.) If your connections are correct, is the receiver set to play a surround sound track? Is it set in 2 channel mode?
Dec 28, 2008 | Harman Kardon AVR 35 Receiver
Surround sound hookup question?
It looks like all you'll need to do is hook up audio out from DirecTV to audio in on the surround sound system. Sony has an interesting hookup recommendation guide on the product support site:
http://esupport.sony.com/US/perl/model-home.pl?mdl=DAVC700&LOC=3
That should give you the connection options. The short answer, though, is to connect the best audio out from DirecTV to an audio in on the surround sound and then choose that option in the surround sound system when you want to watch TV.
Jul 16, 2008 | Sony DAV-X1 System
High-pitched sound when using surround sound
THANK YOU Guest (4/10/08)!!!
That was exactly what I needed! We have had our system for 4.5 years and suddenly, the FM feedback on everything, but DVD and Radio! Your fix helped. Once I set all my presets (at least the current one) to a clear station, the feedback stopped. Hallelujah!! We can enjoy this piece of junk once again! ;)
Amanda - San Antonio, TX
Mar 02, 2008 | Sony DAV-FC7 System
No sound from TV only when playing DVD
Check carefully the RCA conections or others.Sometimes this conections break inwards end cause this problems.Check also the lead and the Set up from surround sound.Verify if the TV has settings for this kind of operation. A strong hug !!!
Jan 16, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Not playing voice but playing music/surround
sounds like you may have a dodgy scart lead.check that none of the pins are loose/damaged. Also check the sound settings on the tv, it may have reset itself to the default sound setting. Or it might just be the audio settings on your dvd player have been adjusted,almost all dvd movies have there own audio adjustments.
Jan 13, 2008 | Audio Players & Recorders
Panasonic SC-HT900-problems with surround sound mode and digital input
i have the same probelm when playing a dvd does it work then when u press the surround sound button it goes slient ???
Oct 16, 2006 | Panasonic SC-HT900 System
15 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
