Question about Horizon Elite 507 Folding Treadmill
Treadmill wont run
The console still lights up put the treadmill wont move you here a small clicking sound as if its going move but it just clicks once that,s it.the incline part of the treadmill still works fine i was thinking it could be the motor control board i don't know much about electronics would be great full for any help i could get
4 Suggested Answers
AJIN G
  • 6694 Answers
SOURCE: There is a clicking sound
hi,
check the motor, may be its bearing have some problem. if u can see the motor then put some oil on its bearing. take care open treadmill only after removing the power.
ok
Posted on Dec 24, 2010
Joed911
  • 4338 Answers
SOURCE: when you push the start
Unplug treadmill from wall outlet. Wait 60 seconds, allowing lower board to discharge built up energy.
Then reseat the 12 pin connector.
I had same issue, but mine was under warranty and they sent me a board. Have you tried a calibration?
http://www.horizonfitness.com/uploadedFiles/Customer_Support/Horizon_Fitness/Troubleshooting/Treadmill/Universal_Calibration_Instructions.pdf
Call T/S, good techs there.
Horizon Fitness Tech Support a call, toll free, at 1-800-244-4192. We're open Monday through Friday, 8:00 am to 5:00 pm Central Time
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Thanks, Joe
Posted on Jan 21, 2011
  • 84 Answers
SOURCE: My T81 treadmill quit working. All of the lights
you need to check voltage going to the motors. no power ,the contoller board is not working. check the connections on the boardmake sure they are in all the way,also the power connections
Posted on Mar 18, 2011
Testimonial: "Thank you soooo much! Now I have somewhere to start and try to figure this out!"
I have a Proform 1026 EXP treadmill that began running at full speed whenever it is turned on. The incline controls function normally but the belt speed is incredibly high. When set to 1.5 MPH (the slowest...
please run the Software calibration see the instruction.
GOD BLESS you
The Steps for Newer Style Console Calibration
1. Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
2. Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
3. Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
4. If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
5. Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
6. Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
7. Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
8. Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
9. Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
10. Press ENTER. You should see "SS" or "55" in the console.
11.Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
12. Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
13. When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
14. Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
Sep 18, 2013 | Proform 1026 Exp Treadmill Motor Control...
Proform 560 HR , lights up but walking belt wont move , can it be fixed ? Help please :) thanks in advance
Sounds like a lower motor controller, that would be the first part I'd replace. Be aware that treadmills have a high power draw and if you are also running other power suckers on the same circuit, the low voltage tends to short out the console or the control board.
The control board is easy to get to, and cheaper to replace than a console, but not cheap. You can also call the 800 number on the front of your owner's manual and they may help you diagnose it.
Jan 31, 2013 | Proform CrossTrainer Treadmill
Milestone 1200 series
RUN the software calibration see the steps.
However lube+clean the elevation motor, shaft and gear, and adjust the small POTentiomenter for fix it.
God bless you
  11. Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
  15. If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
Jan 09, 2013 | Exercise & Fitness
Treadmill wont speed up
RUN the software calibration for diagnose, and fix it.
God bless you
The Steps for Newer Style Console Calibration:
Jan 06, 2013 | Exercise & Fitness
My Golds Gym trainer 480 treadmill wont start and none of the buttons work except for the up and down arrows for the incline.
my gold,s gym trainer 480 will ot run,everthing light up on console. could it be a fuse?
Oct 20, 2012 | Exercise & Fitness
When the treadmill is running, there is a noticeable ding or click sound from under the treadmill.
locate the sound by using long screw driver
put tip of screw driver into roller while treadmill workin
it is mostly cases one or twi of the roller bearings are bad
Nov 23, 2010 | Life Fitness T3 Treadmill with Advanced...
Horizon Elite 507 Folding Treadmill Logo
76 people viewed this question
Top Horizon Exercise & Fitness Experts
Electro Med Services...
Matt Olenzek
Matt Olenzek
Jerry Kramer
Jerry Kramer
Are you a Horizon Exercise and Fitnes Expert? Answer questions, earn points and help others
