Question about Samsung S24A300B Monitor
Flickering The power light will remain on but while I'm gaming (no more than 50 fps) the screen will shut off for 10 seconds (+/- 5 seconds). I've checked the power cable for any possible cuts, I've also checked the DVI cable as well and no problems there. I'm curious if this is a common problem with this model of monitor. Also, the problem only occurs during game play.
viziks
  • 220 Answers
SOURCE: Samsung SyncMaster 510N LCD TFT Monitor
Does the monitor remain on does it switch off?
Problem seems to be hardware related ie monitor itself is defective.Try connecting to another known working system.If monitor is defective it could be a power/inverter related issue or panel could be defective.
Please provide feedback and rate the solution.
Samir
Posted on Jun 16, 2008
  • 34 Answers
SOURCE: samsung SyncMaster 510N Monitor is flickering and blinking
rahul
Posted on Feb 22, 2009
SOURCE: Flickers on start up and very slow going to normal viewing colors and lighting
FIXED: I took the advice to replace C110 and C111 with 1000uF 35V electrolytics (http://www.radioshack.com/product/index.jsp?productId=2102511). $3.18 and a pretty easy time prying open the case with a medium-small flathead screwdriver, disconnecting a few connectors, 4 silver screws (2 on the left & 2 on the right of the LCD), 2 black screws on the back of the metal case, 3 black and one brass screw on the PC board, and it works like new.
HINT: Be sure to insert your new capacitors correctly (positive and negative sides). The capacitor has + and - sides (the - side was marked on mine). The bottom of the PC board (where you apply solder) has a + marked on the positive side.
For the faint of heart: I am an inexperienced and HORRIBLE solderer and know close to nothing about capacitors, resistors, etc. So, if I can do it you can too!!!
Posted on Mar 03, 2009
  • 148 Answers
SOURCE: Samsung 931 B - Dual monitor setup. one monitor
The caps (capacitors) in the powerboard are going out. This is a very common problem in all class and price ranges of modern lcd and plasma tv's/ monitor's. I don't know if this problem has been like this for awhile or it just started, but either way, if the tv takes an abnormal amount of time to "warm" up then it most likely will go out all the way sometime in the (near) future. If you have a tiny bit of will and knowledge ypou can open the unit and get to the print board. Examine this for "popped" capacitors, they will have a buldging top instead of a flat one. Im gonna try to include a pic of them here, if i can get it this time, I've tried bfore lol. But you can google image a "popped" or "bad" capacitor and you would be able, with ease, to diagnose if you have any of these. Usually only one or two. Radioshack sells capacitors (couple anyway) for $1.59 each. MAKE SURE the replacement is of the SAME voltage or HIGHER, or you will be right back replacing those 2. Every capacitor has a negative pole marked with an (-) on the side of the capacitor(by one of the "legs", always puit the negative (-) "leg" of the new capacitor in the same hole in the printboard as where the previous negative (-) "leg" of the capacitor was ( a capacitor with the negative and positive "legs" put in backwards will result in the new piece "popping" as sson as you turn it on!!) make sure the "uf" rating (for example the most common popped capacitor is the 1000 uf) is the same as the one you are replacing. I needed 1000 uf, 105 c and 26v (volt) ratings for the 1 capacitor I needed to replace to fix my LG 19" lcd panel monitor I found by the trash that the light came on off, but it didn't come on. I replaced that capacitor with ; 1000uf, 85 c and 36 v (volts0...It works fine eventhough the volts and the temperature rating (36v and 85c) was not the same as the (26v(volt) and 105c ) capacitor I removed !! Further, I've replaced capacitors that had the celcius rating of 105 with the only ones Radioshack had, namely 85 c(celsius) they have been working great, but I'm not sure about any effect, nor have I heard or read (yet?) about that making an urgent difference. Many threads that I've read people have done the same, so we should be ok (my stuff has been running good for a while longer then most brand new ones!.............(all these ratings ; 'uf ' and 'c' etc are on the side of the capacitor you are replacing and on the side of the ones you are replacing them with)...For all this all you need is the cheapest solder gun u can find (I bought one for $7.99 at Radioshack), a camera (to take pictures as you go to remember how to reassemble the unit) and, once you have your materials, 20 minutes to replace 2 or 3 capacitors and you are good to go...Most monitors and tvs (lcd/plasma) I've seen you have to lay flat on the ground/bed/blanket etc, to work on (screen side down). Usually there are 2 or 3 screws (or a few more) to remove, then you will have to carefully (its comes off easily most times)insert a flat screwdriver inbetween the casing and gently pry it up as you go around the whole frame. Sometimes you have to remove the little washer arouind the cable input orso, just be gentle and you cant go wrong. Once inside there will be a box with wires running to the sides etc...unplug, gently, these wires and open the box. Inside you will find 2 or 3 circuitboards, check them all for "popped" capacitors, replace, reassemble and plug it in....Have fun becoming an overnight tv mechanic lol! The other screen/monitor blinking(surging) is prob caused by the other monitors faillure and should stop when you replace/fix the broken monitor.
Posted on Feb 01, 2010
Testimonial: "exceptional answer and very detailed. I already got it fixed professionally but if i read this first - i could have done it myself and saved $50"
mace1mace
  • 1138 Answers
SOURCE: screen says check signal cable - have check my cables....
Not really...
First check if the cable connected from the monitor is secured and properly connected to the video card of the CPU.
"Check signal cable" will only be display if there is no signal coming from the CPU.. that signal Passes through the video card..
Check the status of your video card.....and see also if the CPU is working and not dead set.
Hope this help...
Much appreciated if you rate this help.. thanks
Posted on May 21, 2010
Fps drops from 2 to 5 seconds while gaming
if you have installled the game the virus may be cd.just opt for an antivirus.
Feb 08, 2013 | Acer Aspire 5742G
My Sharp 32 inc turn off suddenly, power green light turn to red, went turn on again screen ok for 5 to 10 second and start blink 3 time and screen turn off and power light change back to red. What...
sounds like something is shorting and the safety on the psu is kicking in.is the backlight behind your screen flickering prior to it cutting out. if so sunds like a cft has gone faulty. can be fixed though
Jun 08, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
We were playing a game and the tv screen went black then we ejected the game and the wii console will not shut off and now it wont play a game or nothind then we tried to unhook it and the light stayed...
Power light is green or orange - TV screen is blank
    If the power light is green or orange and your screen remains blank, follow these steps.
    1. Completely power down your system by pressing the power button for 10 seconds. If that doesn't work, unplug the AC Adapter from the Wii for a moment, then plug it back in.
    2. Make sure your Wii console has the most current Wii system menu. Download the latest update (how to), and then test your Wii console to determine if the problem has been resolved.
    If you continue to experience this issue, there is a problem with the Wii console and it will need to be repaired.
Jan 27, 2011 | Nintendo Wii Console
Samsung HLR5067W: Screen goes black - Audio Remains. Several months back my 5 years old HLR5067W started displaying the following behavior: - Launches OK - After running for a while (anywhere between...
When was last time you replaced Lamp? Ballast Board is what powers the lamp on.
Lamp Fan, if it is defective it will shut lamp off to protect it, if it is Not cooling the Lamp.
Mats has Lamps for $99.00 1-800-628-1118
Encompass Parts Distribution has 10 Ballast Boards in Stock for $68.96 they also list Service Manual Free for this Model# 1-800-638-3328
Nov 03, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
Wii Console will not turn off. After pressing the Power off button the console light goes from green to yellow (not red.) After about 5-10 minutes the blue light will start to cycle on and off and the game...
try turning it off on the console and not with the controller. turning it off with controller turns it yellow. press and hold the power button on console for 5 seconds it should turn red.
Jun 30, 2009 | Nintendo Wii Console
HP nc8000 shuts down after 10 seconds
try pushing on the upper right corner of your laptop, above the home key, does it start up again?
If so its the maxim chip
if not take one so dimm out and dissable wireless.
Could also be your battery not charging because a battery or power cord malfunction.
Oct 21, 2008 | HP Business Notebook NC8000
Red power button & "lamp" indicator blinks
Having similar issue with my PT-44LCX65. Lamp blew and replaced it (last month), never figured out how to reset timer. Now red indicator light blinks once every 5 seconds and after about 4 minutes TV goes black.... Any ideas?
Dec 26, 2007 | Panasonic PT-50LC13 50" Rear Projection...
Tv problem
I just serviced this model, same problem as noted. I did a resolder job on the power/drive PC board. This was NOT the problem! The problem acts like an electrolytic capacitor issue or horizontal drive amp. Once I get my hands a service manual & schematics, we'll resolve it. I'll post my results AFTER Super Bowl.
Rick Macy
BC Electronics
Macy41@aol.com
Dec 18, 2007 | Toshiba 50H72 50" Rear Projection...
Acer AL2021
I fixed my AL2021 by replacing the output caps on the power board. $4 repair. Pull the thing apart and replace the 1000uF, 680uF and 470uF caps on the end of the power board.
Jul 10, 2006 | Acer AL2032WD 20" Flat Panel LCD Monitor
Samsung S24A300B Monitor Logo
44 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
