Question about Cub Cadet Snow Blowers. 21 in. Single-Stage Electric Start Gas Snow
Snowblower wont start
I have fuel and spark but it won't fire even with starting fluid.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,632 Answers
Clean rust out from magneto
Posted on Dec 27, 2013
96 ciera 2.2 ran fine. parkedat night next morn wont start.its getting fuel and fire but sounds like its not even trying to start
Check for spark.. pull one spark plug out set it on bare metal(away from cyl hole fuel could light from spark) turn vehicle over and look for spark should be a nice lightning bolt looking spark... blue spark is weak spark.. and see if it's getting spark...,, if not,,."try new plugs.,wires,distributor cap&rotor " also first.spray a little starting fluid down the injection system turn it over and see if it fires.if it does then it's a fuel issue prob not electrical... try that.hope it helps
Dec 31, 2016 | Cars & Trucks
2.4 pt cruiser wont try to crank even with starting fluid its got good firing on all cylinders good suction at intake and fuel pumps getting fuel to motor have no way to tell how strong the fuel press
If a volatile starting fluid, typically ether, won't make it fire or even sound like it is trying to fire the problem is likely to be with the spark though if attempting to start continuously for some time hasn't caused the smell of petrol about the place and caused the spark plugs to show signs of wetness there probably isn't any injection taking place either.
In the absence of both spark and injection it could be an immobiliser problem or it could be one or both of the positional sensors (crankshaft or camshaft) or the connections or wiring or the ECU that has failed.
A code read might help.
I suggest spending some time checking the fuses first and then carry out a thorough visual inspection of all the associated pipes, wires and cables before moving on to a more in depth diagnosis.
Feb 09, 2015 | 2004 Chrysler PT Cruiser
Craftsman snowblower will not start
Dump out the old gas and put in new.Try a spray of starting fluid into the carb. If it will not fire on the starting fluid there is somthing wrong in the ignition system. Pull out the spark plug and clean it with a wire brush. If it still won't fire the points and condensor need to be replaced.
Dec 21, 2013 | Craftsman Tecumseh Snowblower 7hp...
John Deere Snowblower 1032 won't start. Obvious solution?
First dump the old gas and put in fresh. Clean or replace spark plug.
Put a squirt of starting fluid in the carb. If it fires the ignition system is good. Do this a few times because there is still old gas in the float bowl and fuel line. When the fresh gas gets to the carb it will stay running. If it did not fire with starting fluid the points and condensor will need to be replaced and maybe the coil.
Dec 14, 2013 | John Deere 826 1032 Snowblower Operators...
2001 Nissan Pathfinder won't start, fuel pressure ok, spark plugs not firing
make sure you have fire at the coil if not there will be no fire to the plugs
Feb 08, 2013 | 2001 Nissan Pathfinder
Car wont start or fire even with starting fluid
To review - - if you have spark, fuel, and compression, you should have combustion.
In this case, if the timing belt is damaged, you might not have compression or spark at the right time.
A faulty crank or cam sensor could cause you not to have spark at the right time.
The spark plugs could be worn out or fuel fouled and not able to fire under compression.
Did the car die or just not start ?
Jun 26, 2012 | 2002 Toyota Avalon
Toro snowthrower model # HSK 635 won't restart, stated first time, ran about ten minutes, then died, put brand new spark plug in, getting good spark, just won't fire up, even when I tried a li
check and make sure its getting fuel. when trying to start, spray some engine starting fluid in spark plug hole. just a little bit. replace the plug then try to start it. if it starts then quits then its a fuel problem. fuel not reaching engine. good-day !
Jan 30, 2012 | Garden
Engine wont start it is getting spark and fuel any other reason why it won't start
You need 3 things for an engine to run; spark, fuel and compression. How is the compression? Is the spark plug new? If the plug is old, it could give a nice spark when you check it but have no spark under compression. Make sure the fuel you're using is fresh. If you give it a small shot of starting fluid and it fires up, your fuel delivery is suspect. In that case, you will need to remove the carb an THOROUGHLY clean it paying close attention to jets and passages. I always give people this warning: when cleaning jets and passages, NEVER use steel instruments. Use wood, copper wire or other materials that are softer than the material you're working on or you run the risk of ruining jets or even the entire carburetor.
Jun 27, 2011 | Suzuki SV 650 Motorcycles
Tec 3.5 horse - 2 cycle - pull start - mtd snowblower - has spark and fuel - won't fire or start -
give it a shot of starting fluid, if it fires, it has a fuel problem, if it does not fire then you have a broken flywheel key.You will have spark with a broken or partially broken flywheel key, but your timing will be off and it will not run. good luck
Nov 17, 2009 | Mtd Garden
I have a 1999 gmc Yukon it is getting fuel and spark i even sprayed starter fluid in the intake but it still wont start it turns over good but wont start
ok make sure you have good fuel pressure
you must have good spark must fire a spark tester
if all that is good then check compression
and don't use STARTER FLUID on a GAS ENGINE it can blow a hole through the piston
hope this helps
Nov 12, 2009 | 1999 GMC Yukon
Cub Cadet Snow Blowers. 21 in. Single-Stage Electric Start Gas Snow Logo
199 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
roeb
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
