Question about Dryers
Frigidaire 7403fst dryer error code 64
Error code 64
5 Suggested Answers
ngfam1
  • 639 Answers
SOURCE: pf error code on frigidaire gleq2152es
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
Did you check the owners manual first to see about the blinking codes?
Usually the codes mean you just have to have factory service remedy the problem!!!!!!!!!!!!!!!
This is a situation that you will need service!
If this dryer is 10 years old or more do not spend any money on it!
The new ones are much more efficient! If you have to replace it buy a Speed Queen , it will do 8 loads a week for 25 years!
It's the last washer and dryer I will ever buy!!!! And less expensive than a top of the line unit!
Here is the service company I refer my appliance customers too!
A&E Factory Service
A Nation Wide Company. / Available 24 / 7 for arranging appointments! In the USA.
1(800) 905-9505
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Posted on Aug 28, 2008
  • 410 Answers
SOURCE: My Frigidaire Dryer (AEQ6000ES2) won't heat. Did
I am not a repair professional. I am just a 78 year old man who has been making his own repairs for about 50 years. Therefore the dryer ID doesn't mean
anything to me. Over the years, I haven't had much trouble with my dryers. The E56 error code means high motor current. To help you find out why, I suggest you go to www.applianceaid.com where they have very good trouble shooting and repair information on dryers and other appliances. I think you'll find what you need there. You can probably verify the meaning of the error code there. Good luck with it. If I have helped you, please rate my advice on fixya.
Posted on Nov 26, 2009
richroth
  • 9472 Answers
SOURCE: frigidaire affinity electric dryer says error E 64, what does that mean?
Heater has an open circuit and need to be replaced. Here is the part you need.
Posted on Oct 21, 2012
chrispolkele
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: My frigidaire dryer is showing E 64 error code, what does that mean?
    Hello florekedward - Typically error code E64 indicates that the dryer has detected that the heater circuit is open. If I was in your position, I will highly recommend consulting a professional to move forward accurately. The certified technician will need to check the heater coils and connections for open circuits. Depending on the diagnosis the heater or wiring may need replacing
    Posted on Mar 05, 2013
    Error code 64 comes on and dryer is not heating
    check the dryer vent lines and hose for to be clean in restart dyer to see if it work
    Apr 29, 2014 | Frigidaire Electric Dryer
    I have an error code 64 on my dryer. I am out of work doing chemo right now. can anyone tell me what the problem is
    If your Frigidaire Affinity dryer is beeping at you and giving you the "E64 CALL SERVICE" business, chances are you have a bad heating element. The good news is, with a screwdriver, a pair of pliers (a multimeter if you have one) and a new heater element you can fix this yourself and save a couple hundred bucks.
    Below I outline a step by step process to do this on the Frigidaire Affinity, but this guide may help with other dryers, as they basically all function the same way.
    A WORD OF CAUTION: You will be handling a lot of thin sheet metal components. Be careful as it is easy to cut yourself on them.
    First you'll want to unplug the dryer. Then disconnect the vent hose and the water feed (if applicable). Be sure and shut off the water valve first, or you'll have a mess!
    http://therandomfix.blogspot.com/2013/07/frigidaire-affinity-e64-error.html
    Apr 03, 2014 | Frigidaire Brand New Frigidare Dryer Motor...
    Yes, I have a 2011 Frigidaire E-Code E-64, if it is the heating element how to change it
    Hello William, thank you for your post!
    An error code E64 is associated with the heater circuit in the open position. A technician would typically check the heater coils and connections for short circuits to the cabinet to determine if it is the cause of the error code. Depending on the readings, the heater and/or wiring will need replacing. This is not a normal DIY job so you may want to connect with a local servicer to determine the exact diagnosis to help reduce the risk of unnecessary parts. I hope this helps explain the error code you are receiving.
    Sep 07, 2013 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
    Frigidaire afinity dryer E 64 service code
    According to other research (and my final diagnosis of our dryer), this is often caused by "sticking keys" on the main control board (Frigidaire AP3851145). Not usually faulty heater coils. The part is available online from $110 to $250. Not real easy to change out, but doable if you are a handyman.
    Apr 20, 2013 | Frigidaire Dryers
    Mar 05, 2013 | Frigidaire Electric Dryer
    E 64
    Hello christinwogo - Typically error code E64 indicates that the dryer has detected that the heater circuit is open. If I was in your position, I will highly recommend consulting a professional to move forward accurately. The certified technician will need to check the heater coils and connections for open circuits. Depending on the diagnosis the heater or wiring may need replacing.
    Feb 28, 2013 | Frigidaire Affinity AEQ6000WH Dryer
    Is there a place online that lists the error codes for Frigidaire
    There are several websites with error codes listed. I have not seen any codes listed for frigidaire dryers. So I checked at Frigidaire.com had no luck there either. 800-374-4432 is their customer service number. I found codes for Frigidaire cooking products but nothing for dryers. Good luck.
    Jan 05, 2009 | Frigidaire GLGQ2152ES Gas Dryer
    Frigidaire Affinity dryer error code?
    HELLO,
    I HAVE A FRIGIDAIRE AFFINITY DRYER (AEQ6000CE32). WHENEVER I PUT THE CLOTHES IN IT JUST SPINS FOR 10 TO 15 MINUTES AND SHUTS OFF BEFORE THE ALLOTTED TIME. THERE IS NO HEAT IN THE DRYER. ANY SLOUTIONS?
    Sep 16, 2007 | Frigidaire Affinity ATF7000ES Front Load...
    Dryers Logo
    110 people viewed this question
    Top Dryers Experts
