Question about Pioneer DEH-P6900UB CD Player
Display colour I bought my stereo about 3 months ago. My display has always been black with blue text and blue graphics. a few days ago it started switching to blue display and black text and i dont like that. What do i need to do so that display colours dont change but stay as they were originally?
Mine would do the same thing. What you need to do is turn the unit off and it should go into demo mode. There is an option for "reverse mode on or off" make sure it is turned off. I beleive you will have to hit the band button to change it.
Posted on Jun 07, 2008
With the stereo off, press and hold the button. go through the setting until you see reverse mode.... turn it off
Posted on Feb 27, 2008
  • 26 Answers
Is there a demo button?
Posted on Nov 09, 2007
I bought a Logik car radio but every time I switch my car on I have to set the station and the time all over gain.. I dont even bother to set the time because it changes back to Midnight every time I
you forgot to hook up wire to fuse box with all time connection to power even when car is off.if u connected thw stereo red wire positive black ground theres always another wire yellow/blue/orange that needs to be connected to constant power that wire once connected will have all ur memories stations set and clock.ned to check wiring
Mar 03, 2014 | Car Audio & Video
How to disarm or reset an alarm system for a 1996 Jeep Cherokee?
Hope this helps:- Factory Disarm Purple/Yellow (-) Driver's Kick Panel Black Connector at ECM -slice into this wire, & wire it to ground, this disables the alarm.
Cavity/Fuse Diagram (1996 Grand Cherokee, passenger side kick plate to find, Owner's Manual pgs 205-206): 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22
Row 1: 1-6 (left to right) Row 2: 7-12 Row 3: 13-18 Row 4: 19-22
1996 Jeep Grand Cherokee Fuse Panel (Passenger Side kick panel) Reply
CAVITY FUSE DESCRIPTION 1 -10 amp (RED) Radio 2 -15 amp (Lt Blue) Cigarette Lighter 3 -10 amp (RED) Rear Washer Switch, Body Controller 4 -10 amp (RED) Airbag 5 -10 amp (RED) Lamp Out Module, Overdrive Switch, OBD II 6 -15 amp (Lt Blue) Vehicle Information Center/Graphic Display Module Park & Side Lamps, Overhead Console Lighted Visor, Automatic Dimming Mirror 7 -20 amp (Yellow) Body Amp, Cluster, Body Controller 8 -20 amp (Yellow) Rear Wiper Motor, Flipper Glass Solenoid, Cargo Lamp, Trailer Tow 9 -15 amp (Lt Blue) Brake Switch 10- 10 amp (RED) Rear Window Defroster 11 -10 amp (RED) ABS Module 12 -10 amp (RED) Heater-Ventilation-A/C Control & Recirculation Motor 13 -15 amp (Lt Blue) Hazard Switch, Turn Signal Switch 14 -15 amp (Lt Blue) Spare 15 -15 amp (Lt Blue) Spare 16 -10 amp (RED) Right & Left Courtesy Lamp, Glove Box Lamp, Halo Lamp Cargo Lamp, Underhood Lamp, Dome/Read Lamp Right & Left Visor, Automatic Dimming Mirror 17 -15 amp (Lt Blue) Radio Illumination, Tail Lamp, Graphic Display Module, Park & Side Lamps, Headlamp Switch, Body Controller 18 -20 amp (Yellow) Spare 19 -15 amp (Lt Blue) Passing Light 20 -15 amp (Lt Blue) Radio, Heater-Ventilation-A/C, Vehicle Information Center 21 -15 amp (Lt Blue) Power Outlet 22 -10 amp (Blue) Airbag Module -------------------------------------------------------------------------------------
1996 Jeep Grand Cherokee Alarm, Remote Starter, Keyless Entry Wiring Information Constant 12V+ Pink/Black Ignition Switch Harness Starter Yellow Ignition Switch Harness Ignition Dark Blue/Gray Ignition Switch Harness Ignition 2 Red/Black Ignition Switch Harness (for AC) Accessory Black/Orange Ignition Switch Harness Tach Gray/White Coil Brake Switch White/Tan Brake Switch Trunk Pin n/a Works with Dome Light Parking Lights Blue/Red (+) Left of Steering Column or Light Switch Head Lamp Tan/Black Light Switch Factory Disarm Purple/Yellow (-) Driver's Kick Panel Black Connector at ECM -slice into this wire, & wire it to ground, this disables the alarm. Door Trigger Yellow (-) Driver's Kick Panel see notes Door Lock 5/Wire in Driver's Inside Driver's Door Orange/Purple Lock Pink/Black Unlock Door Unlock and Passenger's Doors Inside Passenger's Door Black/White L Pink/Black Unlock Horn Wire Gray/Orange (-) Steering Column Windows Up LF=Light Blue, RF=Brown/White, LR=Blue/White, RR=Gray/Black Doors Windows Down LF=White, RF=Purple/White, LR=Red/Black, RR=Green/White
• Cruise Control Information • Stereo Information • View all Jeep Vehicles
Dec 18, 2010 | 1996 Jeep Grand Cherokee
Distorted screen
Turns out it is a defect in the phone. I traded for another Lotus; it doesn't happen to all of them and hopefully it won't happen with my new one.
Jul 07, 2009 | LG Lotus Cell Phone
Color and other problems with SyncMaster 910 MP monitor
Go to =>
Type 910mp in the search dialog box.
Select Download English Manual. It's about 20mb.
The manual has instructions for setup including adjusting your monitor. There is even a section troubleshooting and a self-test. Good Luck.
Dec 12, 2008 | Samsung SyncMaster 910MP 19" LCD Monitor
OSD not working (black screen)
Your 635 will not display the OSD screen through component. You must use either s-video or rca. It won't upconvert the screen menu this route.
I had one up until a week ago. There are two outputs on the back specifically for the OSD screen. I used a separate old 13" TV with s-video to do my setups. Hope this helps.
Sep 04, 2008 | Harman Kardon AVR 635 Receiver
2001 S60 Air blowing hot
There may be a problem with the AC compressor pressure cycling switch, it turns the AC compressor on and off as required to maintain proper pressure in the system, it is located in the low side line (large AC line) under the hood, it will have 2 or 3 wires going to it.
Aug 28, 2008 | 2001 Volvo S60
Clock frozen
It certainly sounds like a defect and I believe would qualify as a warranty repair. Talk to the store where you purchased it to see what their warranty procedure is before it is out of warranty, which can be as little as 90 days. Good luck.
Nov 26, 2005 | RCA RS2650 Shelf System
Pioneer DEH-P6900UB CD Player Logo
194 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
