Question about Philips 60P8342 60" Rear Projection Television
Blurry picture I had to take the back of my cover off my tv and clean because It kept shuting off on me so I was told it need to be cleaned because of all the dust on the components so I cleaned it now it stays on but now my picture is very blurry and I don't know what is causing it and it never did that before.It is a 60in. projection philips tv please help!
  • Justin Rubsam
    Justin Rubsam May 11, 2010
    What do you mean by blurry exactly? a problem with the convergence correction circuitry will cause the set to shutdown but it will also appear that the colors on your screen do not 'line up' properly. Another common problem with these sets is for algae to grow in the coolant inside the blue gun and will cause the picture to look 'hazy.'
  • 41 Answers
With the back off and if you can get a small mirror above the blue and the green tube, look at the picture coming out of the tube. If it looks like you're looking through fog then you probably have contaminated coolant. Compare them to the red tube for reference because the red one is very seldom affected.
If contaminated, the fluid will have to be changed and the chamber cleaned out by someone that knows what they are doing.
Be careful reaching in there. Wear gloves to help protect your hands.
Posted on May 18, 2009
Vizio picture
you may have a dry joint on the screen controller board or a lose connection on to the screen. clean the board on the back of the screen. but take it out first and clean the copper parts on the screen cable.
Sep 15, 2013 | Televison & Video
Blurry picture
Just a shot in the dark but the first thing i do when i get a blurry rptv in my shop is clean the mirror. Dust can accumulate and create a blurred image. You must be careful however as some of the mirrors are Front Surface mirrors and require special cleaning solutions/techniques. If thats the case using a damp cloth could ruin the mirror. I hope this was helpful.
Jun 05, 2009 | Sony Televison & Video
Can I clean the color bulbs on my 52'' RCA television?
To clean these lenses is easy with a clean soft cotton cloth in a kindly way. BUT wait a minute: To get access to those lenses is the really hard job. something as you want to see the core of an onion but tobe there you have to take a cover at the time. Trust me: Literally. Step by Step, at least 40 screws. the front screen is the last step, and then you can see those lenses. If the tv is working OK and is the only job needed, ask a technician for a regular cleanning and adjustment you can get surprised about the service cost (NOT REALLY HIGH i mean). make sure he cleans the back mirror also.
Apr 13, 2009 | RCA HD52W56 52" Rear Projection HDTV
Sony rear projestion TV has blurry picture.
sounds as if your convergence needs to be set. either through the menu on the tv or remote you need to get to the convergence set screen and you need to line up the crosshairs. this usually happens when the tv is moved or bumped.
Dec 31, 2008 | Televison & Video
Blurry picture
You need to clean the projector lens on the optical engine using a soft cotton or, better yet, a chamois cloth. Also clean the mirror mounted inside the rear cabinet and also the front and rear of the screen itself.
If picture is still blurred then your the optical engine is most probably defective.
Dec 10, 2008 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Can I clean projection tubes myself?
First unplug set and remove back cover then you should see the three picture tubes . Using a soft cloth spray windex on the cloth then clean your lens and use the dry side to wipe away . Do not press hard as the lens are plastic . If you cannot see the tubes thru the back side you must enter thru the front . Would need to know make and model # of your set located on the if you need more assistance . If you are a smoker this could very well improve your picture . Good luck
Mar 01, 2008 | Sony KP-57WS510 57" Rear Projection HDTV
Sony KP-61HS10 61 in. Rear Projection Television, dirty innerscreen
The important thing here is cleaning the refelective mirror inside you tv .We have noticed in dirty areas the dirt on mirror makes blurry picture.THerefore you have to open back cover and than tp cover to clean mirror and also dont forget to claen c.r.t lenses ,sisnce they are mounted facing upward ,lot of dust sit on c.r.t lens there fore clean 3 of them r.g.b..And you will notice on picture diffrence.
Dec 18, 2007 | Sony KP-61HS10 61" Rear Projection...
Dull screen
http://www.ehow.com/how_2036563_clean-lens-tv.html
Dec 11, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Blurry picture
1)Remove rear cover = clean RGB lens with soft cloth
2)Remove front speaker grill cover and access panel
Locate screen / focus block = adjust RGB focus controls
3)Last,if needed, unlock each focus lens cap = adjust then lock
................................................T.
Dec 01, 2007 | Sony KP-51HW40 51" Rear Projection...
Philips 60P8342 60" Rear Projection Television Logo
128 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
