Question about Behringer Xenyx 1002fx Mixer 10 Input 2 Bus with Efx
How to use preset effects on 1002fx
I run karaoke. Have had this soundboard for 2 years and still dont know how to use the effects. What number is best for karaoke?
    Scholar:
    New Friend:
  • 125 Answers
I have answered this question in another post
Posted on Feb 11, 2014
  • Megasong
    Megasong Feb 11, 2014
Help behringer xenyx 1002fx !!
If you registered your mixer there will be a three year warranty so get it back to your local Behringer service depot. If not check the output from the PSU, if that's OK then I'm afraid it is very unlikey to be economical to repair. Sell it as spares and repairs on eBay.
May 25, 2014 | Behringer Xenyx 1002fx Mixer 10 Input 2...
What preset effect number is best for karaoke?
Always use echo and reverb, or just reverb for inexperienced singers. If I remember right this is from effect 19 but this is a very inflexible set-up with no control over the effects, just presets. You'll need to listen and decide what is best. You may also try chorus as with a decent effects unit this can be very effective plus a bit of reverb and echo.
Different songs like different effects and we will chop and change even in a single track when live mixing professional acts.
Dec 26, 2013 | Behringer Xenyx 1002fx Mixer 10 Input 2...
How do i wire up an effects unit for the eurorack pro RX1602? It only has a mono/FX output socket.
In your user manual on page 7 is figure 3.2 wire your effects unit like the Virtualizer they show... driven by that mono/fx send and the the effects return returns coming back into unused channels...
Sep 13, 2011 | Behringer Xenyx 1002fx Mixer 10 Input 2...
The meter that shows the effects number that is set only shows part of the number. Can that device be changed?
The segments are driven by transistors and it may be one of those has failed OR there is bad soldering.
Here is the schematic for the Xenyx 1622 which will have very similar effects display... it is on page 10 of the drawing:
http://elektrotanya.com/behringer_xenyx_1622fx.pdf/download.html
Scroll down to "Get manual" and click to download. IGNORE other download links.
Note that the display is SCANNED and you will not be able to take readings with a meter, only an oscilloscope. But if you know what part of the display is out, you should be able to analyze what part of the drive is missing. There is a digit select strobe and then decoded segment drivers.
Aug 30, 2011 | Behringer Xenyx 1002fx Mixer 10 Input 2...
I have a Fender Cyber Twin (1st edition, dont have serial number to hand) which I purchased 2nd hand from Ebay. Lately it has had a fault which started off as quite intermittent but has got worse. When...
Check for degradation of C144 a 2200mfd/16volt cap.
This is power source for the 5 volt digital hardware. Check for excess ripple with a scope. The voltage should NOT go below 8 volts. If the voltage dips, the DSP will go nut-case.
Sep 30, 2010 | Music
My beringer europowered 800w mixer blew a fuse ,replaced it ,has blown several more fuse's since,i used a lower 5 amp fuse did not last - 10 amp is standard > is it time to trash this unit?
I don't understand because the Xenyx 1002fx draws only 16 Watts so the fuse should be well less than 1 amp why would you put a 5 amp?
And your 800 Watt mixer???... There is something wrong with this model number as the 1002fx certainly is not 800 Watts. Please supply the correct model numbers so we can help you.
The unit is repairable I am sure.
Aug 21, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
Xenyx 1002fx Mixer 10 Input 2 Bus with Efx: behringer mixer power goes off after running about...
Problem is likely thermal. Open unit carefully and use freeze mist (circuit cooler) to find bad component.
With that long a time period, it is possibly a component mounted on a heatsink.
May 18, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
Im try'n to hook a ''Duel fex pro'' multiband sound enhancement processor model ex 220, to my berhinger xenyx 1222fx mixer?
Use four (4) TRS cables. Connect from the
AUX "send" (left and right) to the input of the effects unit with two of the cables. Use the other two cables to connect from teh effects out jacks to the AUX "returns" left and right.
Mar 23, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
How do i hook 1202fx to computer?
just connect a baby plug to rca from the pc to the mixer respectively
Feb 14, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
Open Questions:
See all Behringer Xenyx 1002fx Mixer 10 Input 2 Bus with Questions
Behringer Xenyx 1002fx Mixer 10 Input 2 Bus with Efx Logo
93 people viewed this question
Top Behringer Music Experts
Vito Vacirca Jr.
Matthew Spark
Matthew Spark
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
