Question about Dometic Refrigerators
Fix coolant leak - Dometic Refrigerators
    Top Expert:
  • Dometic Master
  • 5,080 Answers
No fix replace cooling unit
Posted on May 30, 2016
Coolant leak
Most likely cause would be a leaky coolant hose near the engine block. When the car is warmed up and you turn it off, open the hood and look and listen for a hissing or a stream of coolant coming from one of the coolant hoses. If you can't see the source from above, you might need to look from underneath. If you can see where it's leaking, it might be as easy to fix as a hose change. Or it might be something a little harder to fix. But you need to start by finding the source of the leak.
May 09, 2016 | Cars & Trucks
Coolant leaking above altenator on 1991 mr2
gasket leaking it cost to fix $1000.00.Now it is stuff to fix leak from $30.00 to 50.00.head gasket fix.
Feb 23, 2013 | Cars & Trucks
How do you fix the knockin in the engine?
To fix an engine coolant leak buy an anti-leak product and add it to the coolant. Next solder or use a high-temperature epoxy to fix the leak, and replace any broken hoses.------------------------------------------------------------------------
Renault CAN Clip Diagnostic Interface
Dec 05, 2012 | Cars & Trucks
Coolant leaking from heater hose
If you do not fix the leak you can damaged your engine, water pump, which will mess up our engine. If you have a leak and can fix it, do it to help yourself. It may be that you have other leaks but fix what you can see and check for other leaks. Change the hose and hose clamp, it is a cheep fix to keep your vehicle on the road.
Aug 05, 2017 | 1999 Volkswagen Jetta
I have a 2001 buick lesabre from 2days ago it was getting cold , i founnd leak the coolant but after driving for a while leaking stopped but it get cold coolant leak again? should i replace something or...
When the motor heats up it is expanding thus stopping the leak. You need to have it checked by someone or put in some radiator dye from your local auto parts store and use a black light to determine where the leak is. Is is not hard to warp a hot engine lacking coolant and then we are talking major work to fix it. You could use some radiator stop leak found at your local auto part store such as a product called BARS LEAK which could cure the problem or make it worse by plugging the flow of coolant.You really need to know where the leak is at and get it fixed.
Nov 20, 2011 | 2001 Buick LeSabre
Losing coolant in my 2000 gmc sierra
These motors are famous for the intake manifolds leaking coolant.Have a pressure test put on the coolant system and look for a leak around the intake manifold corners.Check all four corners i've fixed many of these.
Nov 11, 2011 | 2000 GMC Sierra
My coolant is leaking and its a big possibility it might be the water pupm or radiator but i think its just a hole in the container that holds the coolant, is ok if i put water in there constant to keep...
Stop leak is a temporary solution and never a long term fix. You need to locate the source of the leak and replace the faulty part. I also doubt that the coolant overflow reservoir is leaking unless something has been done to the vehicle to damage it.
Using water rather than the correct spec coolant mix as a top up is NOT recommended (even for a short period) because, among other things, the coolant mix provides lubrication for the water pump. Constantly adding water rather than the correct coolant mix dilutes the coolant mix and it becomes ineffective.
Your engine needs an efficient cooling system to survive so have the leak investigated and fixed saspo.
If you allow the engine to overheat you will cause very expensive engine damage and end up with a car you will not be able to drive. It is always cheaper to fix the problem.
Sep 08, 2011 | Dodge Stratus Cars & Trucks
Coolant leaked out; how do i repair?
TO FIX COOLANT LEAK.YOU HAVE TO LOCATE IT.BEST TIME FIND COOLANT LEAK WAIT UNTIL MORNING.ADD COOLANT UNTIL COOLANT LEVEL IN RADIATOR CORRECT. START THE ENGINE LET IDLE UNTIL START GETTING HOT.THEN TURN OFF ENGINE.COOLANT PRESSURE WILL PUSH COOLANT OUT WHERE LEAKS ARE.CHECK TOP RADIATOR HOSE AND BOTTOM RADIATOR HOSE.CHECK AROUND RADIATOR LOOK DOWN BELOW COOLANT FAN AREA BEHIND RADIATOR.LOOK FOR LEAKS AT RADIATOR CORES AND SIDE CONTAINERS.CHECK FOR COOLANT LEAKS AROUND WATER PUMP GASKET OR WEEP HOLE.CHECK FOR COOLANT LEAKS AROUND HEATER HOSES AND HEATER CORE.CHECK ENGINE CRANKCASE FOR COOLANT LEAKS.
Dec 13, 2010 | 2001 BMW 325
How to fix a coolant on a car
How to Fix an Engine Coolant Leak Your car's coolant system consists of various components. The water pump, shaft seal, radiator, heater cores, freeze plugs, hoses and the engine itself are areas where leaks can occur. The solution for fixing a leak depends on where it's located. Read on to learn how to fix an engine coolant leak. jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); Difficulty: Moderately Challenging Instructions
  1. 1
    Locate the leak. This can be difficult, so take your time. Some leaks, such as those in the freezer plugs, are behind the engine mount or other components. You may need to inspect the car from underneath to detect this type of leak.
  2. 2
    Buy an anti-leak product and add it to the coolant to fix small radiator leaks. You can find this product at any auto shop for around $10. It's effective in 80 percent of minor leaks.
  3. 3
    Patch a small radiator leak by soldering or using a high-temperature epoxy. This is another solution to fix a small leak. Other options are to have it fixed at a specialty shop or simply to replace it. If the heater core is leaking, replacement is the best choice.
  4. 4
    Fix any cracked, busted or leaking hoses by replacing them. Simply remove both clips on the hose, pull off the hose and replace it with the new one. Make sure to put the clips back on.
  5. 5
    Remove a cracked reservoir, clean it and dry it up. Apply plumber's goop, which is a type of glue, and reinstall it. If replacement is necessary, ensure that you route the hoses correctly from the radiator to the reservoir. Additionally, it's important that they are free of kinks so the coolant can flow freely.
Read more: How to Fix an Engine Coolant Leak ' eHow.com http://www.ehow.com/how_2210804_fix-engine-coolant-leak.html#ixzz14X8VxlcK
Nov 06, 2010 | 1997 Buick Century
How do i fix my coolant leaking problem. My radiator, temp gauge switch, sensor, and hoses are all leaking coolant. I already fixed my thermostat but what should i do about the leaking problem?
Sorry to bring bad news but if all those things are leaking coolant then you will have to remove, clean, repair and possibly replace all of the parts where the leaks are occuring and reinstall being sure everything is tight.
Nov 13, 2009 | 1994 Ford Thunderbird
Refrigerators Logo
15 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
4stevetaylor
Level 1 Expert
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
