Question about W-KIDI KID W-kidi R600 Auto Pick Place Bga Rework Station
W-KIDI KID R600 Auto Pick & Place BGA Rework Station with free shipping Worldwide, Exclusive W-Kidi Agents in the U.K Imported Tax may be payable by The BGA Store. (contact us to ask how)
For more information about this product: http://www.thebgastore.com/W-KIDI-KID-R600-Auto-Pick-Place-BGA-Station
    Welcome Back:
    Visited the website for 2 consecutive days.
Hello. Tell me, please, could you send me the exact settings for Bga Rework Station W-KIDI KID R600. The machine is, the guide and the drive is lost. If possible, please send, settings. Thank you in advance. I will be very grateful for the help.Please help solve the problem of professional settings
Posted on Feb 23, 2016
How to choose the best BGA rework stations in India?
To choose the right BGA rework station, you need to know complete details about it. BGA rework is an important part of the procedures at electronic assembly and repair houses across the world. An enormously challenging procedure, the BGA rework involves high skill levels, as well as a touch of creativity displayed by the technician executing it.
The equipment with which an electronics assembly and repair technician conducts the BGA repair is called a BGA work station.
Actual rework involved in the BGA rework station is basically conducted following the assembly of electronic printed circuit boards or PCB. PCB assembly involves a long procedure of detail oriented and careful work execution involving steps such as soldering and desoldering of joints to assemble the perfect PCB. See more http://www.sumitron.com/products/automatic-soldering-for-pcba/bga-rework-station
Apr 13, 2016 | Boating
How to set temperature and time on a bga rework station?
It depends on the type of solder being used, different temperatures for different metals. Keep pre heat temperature to 10degrees below melting point of the solder used and the BGA will lift off with the correct heat on it without reworking the whole board.
Dec 10, 2014 | Computers & Internet
Compaq presario cq60 the caps lock blink constantly
You may try this fix. No guaranties though. Remove the battery and unplug power cable. Then hold down the "power" button for about 10 seconds. After that plug it back in and try turning it on. Again, this may NOT work but it has for others.
Sep 08, 2014 | Compaq Presario CQ60-220US PC Laptop
Replace intel graphics chip directions
you need a new Chip and BGA rework station for replacing graphics chips
Jun 20, 2014 | Dell Latitude E6410 Laptop
Removing a burnt out north north bridge chip
First find the replacement Northbridge chip, then remove the old one, and install the new one.
The Northbridge chip is installed on a motherboard, using a BGA surface mount.
Ball Grid Array,
http://en.wikipedia.org/wiki/Ball_Grid_Array
To explain the BGA surface mount, allow me to compare to an older Intel Pentium 4 CPU, (Processor), that uses a Socket 478 processor socket,
http://en.wikipedia.org/wiki/Socket_478
478 contact pins on the bottom of the Processor.
Also 478 socket holes in the processor socket.
With a BGA surface mount there are no contact pins, nor socket holes.
In place of the contact pins, are Solder Balls on the bottom of the chipset.
In place of the socket holes are Copper Pads on the motherboard.
(The pads are also gold plated)
The chipset is set down onto the motherboard, with the Solder Balls lining up on the matching Copper Pads.
Heat is then applied at a SPECIFIC temperature, and length of time.
This action melts the Solder Balls, and creates solder joints; soldering the chipset TO the Copper Pads.
Which in turn solders the chipset TO the motherboard.
The best, and Proper method of removing, and replacing a chipset; is done with an SMD/BGA Rework Station.
View a short video explaining the Solder Balls, and BGA surface mount; while showing an SMD/BGA Rework Station at work,
http://ersa.com/art-ir-pl-650-346-1472.html
Scroll down, click on the Red ->
Take a few minutes to view the IR 650 demo video
(Notice how the Solder Ball only partially melts?
PROPER temperature, and length of time )
Other methods are only temporary.
Heating in an oven is du-mb. You are also heating all the other chipsets.
http://www.youtube.com/watch?v=JEpnqhRYGLw
Another temporary repair.
HOWEVER, in all of the temporary repair solutions that I have seen, this one IMHO comes the closest to a real repair.
In all fairness, I can see that perhaps if PROPERLY performed, the repair could last.
This gentleman uses a proper thermometer, to Constantly test the temperatures all over the chipset, while heating.
Keeps it at a constant temperature EVENLY, all over the chipset.
Heats it to the Proper time needed.
Also backs the heat away slowly, to allow the chipset to slowly cool down.
Cool it down too fast, and you'll fracture the solder joints made by the Solder Balls.
In otherwords a Cold Solder Joint.
{Which makes a poor contact}
I do like the adding of more surface area, for cooling the graphics chipset.
This, along with using an SMD/BGA Rework Station, IS the proper solution to an overheating graphics chipset.
No.
Not a proper solution for an overheating Northbridge chip.
Use Thermal Glue, and a small cooling fan; mounted right on the Northbridge chip.
(Or if it clips on suggest Thermal Paste)
There are shops you can take it to, or send it to; that perform reflowing a chipset. (Have SMD/BGA Rework Station)
For additional questions please post in a Comment.
Regards,
joecoolvette
http://www.alibaba.com/showroom/northbridge-chip.html
http://www.ebay.com/sch/sis.html?_nkw=Northbridge+Chipset+
Mar 08, 2013 | Computers & Internet
How can I replace south bridge chip on asus
http://www.ersa.com/art-ir-pl-650-346-1472.html
Use a BGA Rework Station like the above.
Going to use a good Southbridge chip from another motherboard, that is the same?
Yes.
Removing a good Southbridge chip is redundant.
Buy one? MAY be possible.
By the time you have a BGA Rework Station used, the cost may equal, or exceed the cost of a replacement motherboard.
Oven / Torch /Heatgun method? Yeah right.
Temporary repair at best.
http://www.ebay.com/itm/1X-Intel-FW82801DB-SL66K-NH82801DB-82801DB-With-Balls-/250621692642
http://www.ebay.com/itm/1X-NEW-Intel-BD82HM65-BGA-Chipset-Solder-Balls-US-Seller-/330756256341?_trksid=p2047675.m2219&_trkparms=aid%3D222002%26algo%3DSIC.FIT%26ao%3D1%26asc%3D108%26meid%3D3854753242943376403%26pid%3D100008%26prg%3D1062%26rk%3D2%26sd%3D250621692642%26
Regards,
joecoolvette
Dec 01, 2012 | Biostar P4X266A Socket 478 Motherboard...
Hp tx2530ee
http://h10025.www1.hp.com/ewfrf/wc/product?cc=us&lc=en&dlc=en&product=3767544
The HP Pavilion TX2530ee Notebook PC uses Integrated Graphics.
Uses AMD ATI Radeon HD3200 graphics.
Which is an AMD ATI RS780G graphics chipset,
http://www.ebay.com/itm/ATI-AMD-215-0674007-Chipset-RS780-780G-BGA-Mainboard-Chips-IC-with-Balls-New-/230684694846?pt=LH_DefaultDomain_0&hash=item35b5e1193e
The Left side shows the TOP.
The Right side shows the BOTTOM.
The Right side shows the -> Solder Balls.
To digress;
Chip and Chipset are slang terms for I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Integrated_circuit
The Integrated Circuit, or chipset, for graphics; is a graphics chipset, or properly known as the G.P.U.
Graphics Processing Unit,
http://en.wikipedia.org/wiki/GPU
The chipset itself, is in the middle of the green, square small circuit board.
The small circuit board, is used to connect the chipset to the motherboard.
The AMD ATI 780G graphics chipset is mounted to the motherboard, with a BGA surface mount.
Ball Grid Array.
To explain the BGA surface mount let's compare to an older Intel Pentium 4 processor, that uses a Socket 478 processor socket.
The processor has 478 contact pins sticking down out of the bottom.
The Socket 478 processor socket has 478 matching socket holes,
With a BGA surface mount, there are no contact pins on the graphics chipset.
There are no socket holes on the motherboard.
In place of the contact pins are Solder Balls as you have seen.
In place of the socket holes on the motherboard, are Copper Pads.
The graphics chipset is set into place over the motherboard, with the Solder Balls lining up on the matching Copper Pads.
Then heat is applied at a specific temperature, and length of time.
This action melts the Solder Balls, and solders the graphics chipset, TO the Copper Pads.
(Which in turn of course, solders the graphics chipset TO the motherboard )
IF, the cooling for the graphics chipset is Inadequate, the graphics chipset will overheat.
Constant overheating, will partially melt the solder connections that were made.
When the laptop is turned off the solder connections will re-solidify.
This causes Cold solder joints, and a poor contact of graphics chipset to motherboard.
(Solder joint = solder connection)
Could be the graphics chipset just needs to be re-soldered to the motherboard, and better cooling for the graphics chipset, implemented.
Hence why the long 'tutorial' above.
Unless of course the chipset is obviously burnt. Visually checked, and seen burned.
PROPERLY re-solder, or replace, requires a BGA Rework machine.
(BGA Rework Station)
Here let me show you a BGA Rework Station in action,
Scroll the page down, click on the Red -
Take a few minutes to view the IR 650 demo video (5 minutes)
[Most of the time the shop you take it to, does not have;
A) Proper training for the techs to perform this
B) Proper machine
Want to just replace the motherboard due to the above, and also brings more $$$$$ in their pockets ]
Now who?
Depends on where you are located. I bet this guy can do it,
Regards,
joecoolvette
Aug 10, 2012 | Computers & Internet
My xbox 360 has sound but has no picture
Sound but no video could be caused by a loose or faulty Audio Video Cable. Try another cable first if one is available. Make sure the cables are connected correctly and firmly. If all else fails then you will need to have the Xbox 360 professionally repaired. The tools required are not something that most people have lying around the house ( BGA Rework Station) so i'd stay away from those rip off "guides'. My company can help you out, we offer free shipping as well. Check us out here: GATpro Repair
Jun 13, 2010 | Microsoft Xbox 360 Console
Hp nx6110 laptop keeps hanging but works well when pressed on top of touch pad or hard drive.
Only if you have knowledge on hardware Laptops you understand. The procedure go as follow:
Unscrew the motherboard completely.
Identify the North-Bridge BGA IC (BGA= ball grid arrays) under the mouse region.
Get an SMD Rework Station.
Suspend the board on a surface which cannot be affected by heat and held firmly whereby under the North-Bridge BGA IC is opened.
Use your SMD Rework Station to generate heat  evenly beneath the region North Bridge IC and press gently without being bridged.
Mind you 90% risk is involve.
Oct 07, 2009 | HP Compaq nx6110 PC Laptop
W-KIDI KID W-kidi R600 Auto Pick Place Bga Rework Station Logo
414 people viewed this question
Top W-KIDI KID Event Planning & Celebration Experts
DAVE PARTA
Level 1 Expert
samiya_jahan
Level 1 Expert
Are you a W-KIDI KID Event Planning and Celebration Expert? Answer questions, earn points and help others
