Question about Crosley CR2413A Turntable
Speakers impedance we don't know how to get the record player to activate.
  • Crosley Master
  • 5,449 Answers
The speaker has a low power output
The output of a speaker primarily depends on system design (obviously) However, perhaps you have sourced a replacement or 'upgrade' speaker for an existing system. In that case, perhaps you have an impedance mismatch. If your amplifier is designed to drive, say, an 8 ohm speaker, and you connect a speaker of 16 ohms impedance, then your sound will be softer. On the other hand, you may have connected more than one speaker to one power amplifier output. If you connected in series you add the impedances. If connect in parallel you work out the impedance using this formula:
1/Answer= 1/Speaker A impedance + 1/Speaker B impedance + 1/Speaker C impedance etc. So if you connect three speakers in parallel, each of 8 ohm impedance:
1/Answer=1/8 + 1/8 + 1/8 = 3/8
3X Answer=8
Answer = 8/3 = a little less than 3 ohms.
Reducing the load like this makes the sound louder, but risks distortion or even damage. Check your manual for amplifier tolerances. Cheers, Don.
Dec 13, 2013 | Audio Players & Recorders
Need to replace Jamo DVR-50
The impedance may be marked on the actual speakers inside the enclosures.
Jul 04, 2017 | Jamo DVR-50 System
Fixing a Denon 1705. Rear Surrounds damaged by 2ohm speakers.
Chances are that you blew your output transistors with speaker impedance that low
Apr 16, 2017 | Denon Audio Players & Recorders
Hi can you tell me that impedence on JBL TLx4 speakers- i need to know if they are compatible with my denon RCD M37 dab player thanks
hi,
Is it JBL TLX 420 then its impedance is 4OHMS. You cant connect these speakers to denon rcd m 37, because its output impedence is 6 to 16 ohms.
ok
Jul 04, 2011 | JBL PSW-D110 Speaker
My kenwood headunit is saying protect and i dont know how to reset it and no wires are touching how do i fix this
Hi, this is usually caused by a short in one of the speakers or the speaker wires. Take the connector off the head unit and use an ohmmeter on each pair of speaker wires to check impedance. If impedance is less than 2 ohms on any pair of wires, check the speaker impedance for that pair. If the speaker impedance is low, replace the speaker--otherwise replace the wires. Please let me know if you have any questions, and thanks for using FixYa.
Mar 13, 2011 | Kenwood Kdc-mp445u Car CD / USB/ MP3...
Impedance on my Bose 901 Series VI
there 12.9 ohms. there bose speakers not a wallmart if you want a lower impendance then run them in parralell brigde of a bridgeable amplifer/receiver
Nov 09, 2009 | Bose 901 VI Main / Stereo Speaker
Speakers
I hope you still have the manual that has the system specs in it. You need to find the impedance of the speakers, and the spec sheet should show it. Any speakers with the same impedance should work. If you can't find it, you may be able to find it online at the manufacturer's website. As a last resort, the audio tech at Best Buy or other audio equipment repair shop may have an impedance meter.
Oct 13, 2017 | Technics SB-CSS80 Speaker
Denon AVR3300 - Resetting activated Protection Circuit
Hi
Remove all speakers cables or wires and check all from behind the Receiver. if there are any loose terminals or any metal object in between the terminals.
though it might be a coincidence that you have a problem in the Receiver.
unplug the power cable from the wall socket and remove all cables.
after you remove the cables plug the power cable in the wall socket and try if you see the protection displayed , the receiver needs service.
Good Luck
Regards
Nov 02, 2017 | Denon AVR-3300 Receiver
Advice
How many speakers you are having and what is the impedance of the speakers, you can connect speakers to amplifier in series/paralel connection without loading the amp.impedance, please let me know the ratings ,so that further assistance could be given.
May 23, 2008 | Cyberhome CH-DVD 300 DVD Player
Crosley CR2413A Turntable Logo
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Sam Palermo
Sam Palermo
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
