Question about Microsoft Windows XP Home Edition
Deleted by mistake 3 rundll modules
At startup, I get 3 RUNDLL alerts that all say specified module could not be found. They are
C:windowssystem32mipisifo.dll
C:windowssystem32kadageko.dll
C:windowssystem32 uneyevi.dll
I don’t think a restore disc came with my emachines M5405. Any help available?
    Sergeant:
  • 186 Answers
You needs to restore Your OS or format entire Disk Partition and install fresh OS.But be carefully fresh OS will deleted entire data of UR partition.
Posted on May 18, 2009
  • LORILEE GORDON Apr 20, 2013
    no i still can not fix my problem i dont understand computers imnew
Is the module RunDLL very useful?
It is essential to run many windows programs.
More info required to give an answer
Jul 09, 2014 | Acer Aspire Computers & Internet
After starting the laptop it showing amessage like this ''RUNLL There was a problem starting winpxs32.rom The specified module could not be found...
just found this on the internet not sure if it will work for you but have a read up about it.
Rundll problem issues are caused by misconfigured system files. Rundll problem usually happen when the computer's registry system overloads with to much data, or when certain system files become missing or broken.
The Rundll problem issues are easy to repair. By downloading and running the registry repair tool System Optimizer, you can quickly and effectively fix this problem and prevent others from occuring. Simply click the links below for your download.
Download & Install System Optimizer.
Note:If the download link doesn't work you may need to Download it from a mirror
  • Step 2:
    Click the "Quick Scan" button.
  • Step 3:
    Click the 'Repair All' Button to Repair Your PC.
  • or try this link first..
  • RUNDLL There was problem starting winpxs32 rom The specified module could...
    Oct 28, 2017 | Acer 4220-2346 Notebook
    Everytime I start up Windows I an error message.
    Well, the reason causing Rundll Error is probably that when you are surfing on line, some Trojan and malware attack your PC and modify the registry for malicious purpose. Though the anti-virus and anti-spyware can remove those Trojans and malware, they cann't repair the destroyed registry. So, Rundll Error happens! Of course, Rundll Error is not only caused by Trojans and malware. According to our research, mis-deleting registry entries, downloading dubious files, hard shutdown PC etc can also cause Rundll Error.
    Thru serious test of our expert team, Perfect Optimizer can fix Rundll Error 100%, much higher than other registry products.Because Perfect Optimizer uses a high-performance detection algorithm that will quickly identify missing and invalid references in your Windows registry. With a few easy steps Perfect Optimizer will entirely scan your Windows registry for any invalid or obsolete entries and provide a list of the registry errors found. After that you can choose to clean list items with selection or automatically repair them all.
    So when your PC got Rundll Error, it's highly recommended that you download Perfect Optimizer and repair Rundll Error. Anyone can do it like a computer guru within 5 minutes!
    Jul 14, 2010 | Toshiba Satellite P105-S6227 Notebook
    When I start up Windows XP I get three error boxes each of them say: Rundll Error Loading C:windowssystem3whnoherd.dll Rundll Error Loading C:windowssystem32cryakfuvzxugjh.dll Rundll Error Loading...
    Rundll.exe files are systems process directly related to your computer's Windows Registry All Dll files are a part of vast library that contains code and data that is shared by many programs. This helps to produce speed and memory efficiency in your operating system by reusing the same code or file to run many functions by various programs. An error occurs when program aren't allowed to access this code.
    Now, if you able to access the XP in safe mode, You could go to :-
    Start > Programs > Accessories > System Tools > Restore.
    Select a restore point and it's all done.
    Unless, the only User Fixable option is to Repair the Windows. Put the XP disk in tray and run Repair. Once repaired, it would fix the problem.
    Let me know, if needed assistance.
    Hope i helped you.
    Thanks for using ' Fixya ' and have a nice day!!
    Nov 08, 2009 | Microsoft Windows XP Home Edition
    RUNDLL
    It appears that a program has been removed (not uninstalled) from the computer and XP can no longer locate the removed files while references to the files still exist. So, we need to find what is referring to this file. The easiest way would be to download, install and run a registry cleaner such as CCleaner (from www.download.com), but this can also cause more problems than it solves. The other way is to use the msconfig utility to disable all of the extras that are loading and then enable them one by one and rebooting each time until the problem appears again. Then just disable the last one enabled (that caused the problem to reappear), and continue on until all other programs and processes have been reenabled.
    Apr 07, 2009 | Microsoft Windows XP Professional With...
    In start up RunnDLL pops up saying ERROR (please help)
    this problem is due to missing of dll file from your system, click on Start> Run, type msconfig> tab startup from top and find out the file name above which you just mention and uncheck it now click apply and Ok after restart you will get some messege check mark on it.
    Mar 29, 2009 | Microsoft Computers & Internet
    M3plugin.dll
    When I start My PC the RUNDLL error occursError loading C:\program~1\Mywebs~1\bar\1.bin\m3plugin.dll The specified module could not be found.  Solve my this problem as soon as possible.
    Aug 26, 2008 | Computers & Internet
    RUNDLL Error loading c:/PROGR-1/MYWEB-1/bar/2.bin/M3PLUGIN.DLL The specified module could not be found Can you please help me how to get rid of this at the start up please. Thax Tracie
    This is a virus download " Malwarebytes " and install and run it will delete all virus files
    Usually picked up downloading cracks
    Get a decent antivirus suite to protect your computer
    A lot of them have a free 15 to 30 day period
    Aug 20, 2008 | Intel Motherboard
    When starting my laptop alert window pops up RUNDLL and it says C:\PROGRA~1\MYWEBS~1\bar\3.bin\M3PLUGIN.DLL specified module could not be found
    That is a module used by the popular spyware program mywebsearch. If you've recently run a virus or spyware scan, it was deleted however the startup still remains. To clear this:
    Click on start, then run.
    In the box type msconfig
    In the startups box, uncheck the box that corresponds to the mywebs.
    Click okay, then restart. When it restarts, click the box and click ok again. The error should be gone.
    Thanks and please take a moment to rate this as fixya.
    Jul 06, 2008 | Toshiba Computers & Internet
    Microsoft Windows XP Home Edition Logo
    102 people viewed this question
    Top Microsoft Computers & Internet Experts
    micky dee
    Piyal Perera
    Piyal Perera
    Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
