Question about Barnes & Noble NOOK Tablet HD 8GB BNTV400
Only loads to 99%
Turns on and only loads to 99%
I have a HP tablet that turns on but has a big circle in the middle going around and says cyanogenmod
Your tablet's firmware has been modified with aftermarket software. (users typically do this to gain "root" access on the tablet.) If the software will not load, you will need to either load the factory firmware, or try another aftermarket firmware.
Oct 23, 2015 | HP Tablets & eReaders
99% charged. If plugged in it stays on. If unplugged it turns on for one second and turns off. Tried resetting it with paper clip as the manual states. Help
Hi ...just because a battery charges to 99 percent does not mean that it retains the charge as it did when new. Almost certainly need new batteies....nothing more
Jul 19, 2015 | Ematic 7" Touch Screen Tablet
My kurio wont finish loading how to fix
You cant factory reset it. That only works on apple.
Feb 01, 2015 | Kurio Touch 4S Handheld
How do I get my CMP759 TABLET to stop loading? I tried resetting it several times and it turns off. When I turn it back on it will only stay in the loading stage.
I don't know much about these, but my husband uses tablets and says there might be a hard reset. Sometimes a very tiny button that is reset somewhere.
Dec 31, 2014 | Tablets & eReaders
My craig tablet wont start up
Try factory reset. Press the hidden reset button while powering the unit. This should clear out everything that caused the hangup.
Apr 13, 2014 | Tablets & eReaders
Want to down load whatsapp
Turns out, WhatsApp Messenger for iOS is only available for the iPhone...
Apr 04, 2014 | Apple iPad 32 GB 3G Tablet PC
My craig tablet will not fully load up..I only get the android symbol nothing else
My criag tablet as soon I turn it on it gets stuck on the loading point what should I do?
PLEASE HELP ME:-) :-) :-) :-)
Dec 22, 2012 | Tablets & eReaders
Nextbook2 will not turn on with a full battery
1) Try to plug the AC power adapter and see if the Nextbook2 turns on - if it does, there is 99% chance that the battery is dead. You can get the replacement battery only from the Nextbook manufacturer/dealer, nobody else sells separate batteries yet, not even on eBay.
2) If the Nexbook2 DOESN'T turn on even with the AC power adapter plugged in - see whether it (1) starts to load the system or (2) merely makes a sound, but nothing appears on the screen, or (3) maybe it doesn't even make a sound. In the (1) case you could reinstall the system, but it's not that easy without a built-in CD-ROM, so I recommend to bring it to the mechanic/dealer/manufacturer. There is no better solution possible.
Dec 25, 2010 | Tablets & eReaders
Barnes & Noble NOOK Tablet HD 8GB BNTV400 Logo
55 people viewed this question
Top Barnes & Noble Tablets & eReaders Experts
John mullen
john smith
David Payne
David Payne
Are you a Barnes & Noble Tablet and eReader Expert? Answer questions, earn points and help others
