Question about Horizon Exercise & Fitness
Reset control board - Horizon Exercise & Fitness
I have the 60LN5400-UA I spoke with someone the other day and they suggested to order a power board. I am confused I have no red stand by light but I can see the lights through the back panel.
If the power indicator LED at its front panel is ON, then the power supply regulator section circuit board is OK. The fault should be with its digital main board itself. After power is switched ON, the poser regulator board supplies different voltages to different stage circuits inside. These voltages are controlled by the main system control IC, at its main digital board. Now it do not work, and why you can't power ON the set, either by remote control, or with the front panel control.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Jul 01, 2016 | Televison & Video
Tip
ERROR codesCanon 7050
Canon 7050 E000 Heater (Reset by unplugging machine) E001 Heater triac, DC controller, AC driver (reset by unplugging) E005 Fuser cleaner belt at end. Replace. E010 Main motor, DC controller or DC driver board E011 Any motor ( main, scan, cleaner belt, duplex, toner, lens) DC driver, DC controller, duplex driver board. E020 Toner out signal has been sent for at least 3 minutes E050 Duplex E203 Scan motor, DC driver, DC controller E210 Lens home sensor not actuated or won't deactuate E240 Controller board E241 Controller board E242 Controller board E400 DC controller, Doc. Feeder board, 24V power supply E500 DC controller, sorter board, 24V power supply
on Jan 19, 2010 | Office Equipment & Supplies
KSRT25C display doesn't work after power outage
No sorry there is no reset button. If this happened during an outage there is a possibility that there was also a surge. Electronic control boards are sensitive to sudden changes that may have swelled the tops of the capacitors on the control board. HERE=> 2303843 Dispenser Control Board
Have someone unplug the power and look over the 2303843 Dispenser Control Board Sometimes you can see damage but most times you will not see a problem with the board. . I am here should you need me, Thanks John Tripp Appliance 911
Apr 03, 2014 | KitchenAid KSRT25CRSS Stainless Steel Side...
Reset button
There is no reset button on this machine, by turning off the power for about 2 to 3 minutes the memory on the control board will clear.
Failing this, there is a problem on this control board.
Jan 01, 2014 | LG DLE2532W Electric Dryer
GeErefrigerator. Model LHSF6LGZBCBB How to reset the refrigerator I for the first and only time used the control lock button and now it will not unlock. I have unplugged the refrigerator and that still...
The manual says to hold the control lock button down for 3~5 sec to unlock the board. To remove the board, the bezel pops off from around the control. Once removed you can easily access the screws to remove the board.
Dec 10, 2013 | Washing Machines
Safety key off
You need to reset the machine. see your instr. manual where located the reset b.
see the block diagram attached. the control board can NOT be reset.Test the key magnet for repulsion attraction or repulsion againt with your magenet refrigerator and replace if necessary.
God bless you
Dec 02, 2012 | Horizon GS950T Upper Control Board
I have a frigidaire fridge model # FSC238F7DSBA I had a blinking error of " E F" on the control panel. I checked out the error codes as well as called frigidare customer service and they both led me to...
After replacing the control board did you unplugged the fridge.?There is no resetting button.Unplugging the fridge for 1 hour will reset it.If still the fridge doesn't reset then leave it over night unplugged.
Thank you
Oct 19, 2010 | Frigidaire Refrigerators
Control panel on my fridge
Pull the power cord for 5 minute to reset the control board. if this control panel malfunction still exist after the reset, replace the control circuit board.
This is a typical control fault that should be corrected by pulling power for 5 minutes. if not, this reset will confirm major damaged to the circuit board.
May 25, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
Electrical problem
Teecee, F11 is a communication error between the main board and the motor control board. The main board is on top and the motor control board is behind the lower panel. Sometimes the harness to these boards become loose causing this error. You would have to get at them and reseat the connections. F dl has to do with the door lock mechanism. You might of just had the door open when you reset the machine. To get at the main board on top you have to remove the 3 screws in back for the top. It will then slide back and off. To get at the motor control board, you will have to remove the bottom panel. The board will be in the back. Catriver..post back.
Oct 25, 2006 | Whirlpool GHW9150 Front Load Washer
Exercise & Fitness Logo
32 people viewed this question
Top Horizon Exercise & Fitness Experts
Electro Med Services...
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Are you a Horizon Exercise and Fitnes Expert? Answer questions, earn points and help others
