Question about Jacuzzi Pool & Spa
We have too much preasure - Jacuzzi Pool & Spa
  • 65 Answers
If u have too much pressure on ur pump it might b the wrong pump or u could have grass leaves ect... stuck in the pump and causeing a blockage which would cause too much pressure try taking the inlet of the pump off and see for blockage or try getting ahold of the manufacture of the pool or spa and see what they recommend
Posted on May 18, 2009
Fuel preasure specs
Engine running: 28 - 50 psi
Key on, engine off: 35 - 45 psi
Nov 01, 2014 | Cars & Trucks
After putting the correct preasure on the tire and resetting the tire preasure light it's still on
Don't spend money taking it to a mechanic or dealer. Lower the spare a correct the pressure in it. Then reset the pressure light. All these Lexus tire sensors are little transmitters sending a signal to your car's receiver. Had the same problem and solved it this way.
Jan 05, 2012 | 2007 Lexus RX 350 FWD
Replaced al of the valves but still will not operate on high preasure. Will build to high preasure only for a couple of seconds then back to low preasure.
your bypass pressure valve is weak and needs replacing,its letting water pressure bypass the pump going to the pressure gun
Aug 05, 2010 | Northstar Pressure Washer 3000 PSI
My runs fine for a little while then starts to spit and sputter like it is starving for fuel.
Hook a fuel preasure gauge to it and run it until it acts up then check the preasure, if the preasure goes low ,replace the fuelpump.
Jun 09, 2010 | 1993 Jeep Wrangler
Cannot find main relaysomewhere around brake pedal. problem fuel rail will not pressurise
faulty preasure regulator replace unit. also check pump out put preasure and hold preasure
Aug 19, 2009 | 1991 Honda Accord
I have a 1998 Jeep Cherokee with a 4.0L engine. The oil pressure gauge usually stays around 40 on the highway but when I come to a stop it drops down to 10. Is this normal or is my oil pump getting ready...
No this is normal. As an engine wears then oil preasure will be less this is not due to a weak oil pump but wear in crank shaft bearing's. When an engine is new and bearings are tight then oil preasure wont fall a lot from reved up to idle as the engine wear's oil escapes quicker from the crank shaft bearings. Reved up oil preasure increases idle it drops off. If the oil light stays out then their is enough preasure to lubricate the engine. In fact in an older engine high oil preasure is a worse complaint as this means the oil system is clogging. All is ok with your pump. If the oil preasure is moving up and down at constant rev.'s then the oil pump is faulty. Hope this put's your mind to rest.
Aug 11, 2009 | 1998 Jeep Cherokee
1999 Silverado a/c problem
check your high preasure switch,check your preasures,if your preasure on the high side if it high the preasure switch is protecting your compressor,to be honest if your not trained in this you need to take to some one who has a license
Jul 27, 2009 | Chevrolet Tahoe Cars & Trucks
ADMIRAL LSD2615HEZ
Pls.check the unit if does have a low and high preasure switch,posible the system is in the low preasure that switch to cut off the unit.check system preasure,if low preasure found,you need to recharge the system.
Nov 19, 2007 | Admiral 26 cu. ft. Side-By-Side...
Pool & Spa Logo
43 people viewed this question
Top Jacuzzi Pool & Spa Experts
Jay Finke
Jay Finke
Mike
john h
Are you a Jacuzzi Pool and Spa Expert? Answer questions, earn points and help others
