Question about 2-Way Remote Starter
Pro start LCPro 1 troubleshoot
LCPro 1 remote press and here relays click but no start on 2008 dodge caravan. EVO has red and yellow light lit
Can a no start in 2008 dodge grand caravan fuse issue?
be looking at the auto shutoff relay ,it controls the fuel and ignition..may be bad..14 dollar part for my car..
Dec 15, 2013 | 2008 Dodge Grand Caravan
2007 dodge grand caravan sxt solid red dash light
Turn on the key and leave it on for a long time(up to four hrs) use a battery charger if it's available
Nov 22, 2013 | 2007 Dodge Grand Caravan SXT Minivan
Locate a/c relay switch on 2008 dodge caravan
A have problem for my van 2008 caravan my problems is when start the a/c the fan do not aplicate the high velocity thank you for help
May 11, 2012 | 2008 Dodge Grand Caravan
What does the yellow wrench light indicate on a 2008 dodge caravan. THANK YOU!
a yellow light indicates maintenance interval has passed whether it b oil change maintenance or egr maintenance,(exhaust gas recirculation valve) can b reset as per ur owners manual.theirs specific instruction in ther on how to reset ur light. maintenance is recommended though,not a good idea to reset an keep driving w/o required maintenance.. hope this helps
May 01, 2011 | 2008 Dodge Grand Caravan
Radio wiring diagram for 2000 dodge grand caravan
2000 Dodge Caravan Stereo Wiring Constant 12V+ Pink Switched 12V+ Red/White Ground Ground/Back Strap Illumination Black/Yellow Dimmer n/a Antenna Right Front Front Speakers 5 1/4" Dash Left Front (+) Green Left Front (-) Brown/Red Right Front (+) Purple Right Front (-) Blue/Red Rear Speakers 6" x 9" Side Panels Left Rear (+) Brown/Yellow Left Rear (-) Brown/Light Blue Right Rear (+) Blue/Orange Right Rear (-) Blue/White
Dec 22, 2010 | Car Audio & Video
How do i get my change oil light reset on my 2008 dodge gr. caravan sxt
turn key on with out starting it and press gas pedal all the way to the floor 3 times then start the car
Oct 20, 2010 | 2008 Dodge Grand Caravan
Driving 2002 ES Grand Caravan and abs light light came on and trac off light stays lit. Not sure if safe to drive. Thanks.
if its an orange-yellow light ,you wont have abs operation,but will still have traditional brakes,but if its a red light ,you might want to take it in,
Aug 01, 2010 | Dodge Grand Caravan Cars & Trucks
2008 dodge grand caravan - wont engage park
check fuel pump and relay, remove cap listen for whirling sound in tank, listen for click under hood for realy
Sep 20, 2009 | 2002 Dodge Caravan
2-Way Remote Starter Logo
103 people viewed this question
Top Crime Stopper Vehicle Parts & Accessories Experts
Colin Stickland
Colin Stickland
John
John
Steve
Steve
Are you a Crime Stopper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
