Question about HP OfficeJet J4580 All-In-One Laser Printer
When trying to fax, it calls for an access code. Why?
The fax dials but is interupted by a phone carrier saying I must enter an access code. When we use the phone directly it goes through.
Soulvisitor
  • 1113 Answers
SOURCE: Can't receive or send faxes
Are you pressing the speaker/hook/manual dial switch (not sure of its label)?
Make sure phone line from wall is connected to fax's line socket not the ext. one
Is it in Fax mode? Can you copy OK?
Posted on Oct 21, 2007
  • 81 Answers
SOURCE: No dial tone detected
It may be a bad modem on the copier. Plug your phone into the auxillary phone port on the copier and see if you get a dial tone. Also make sure that your cord from the wall is plugged into the line port and not the phone port.
Posted on Jul 24, 2008
  • 105 Answers
SOURCE: Fax will not send or receive
Hi
You need to contact comcast for this issue and get a seperate phone line to which u need to plug in the allinone. This issue may exist most of the Comcast customers.
thx
Posted on Oct 05, 2008
leroyal
  • 2120 Answers
SOURCE: won't fax -printer message is "will dial soon"
Fax machines are ANALOG devices and will not work reliably on a DIGITAL phone line.
Posted on Feb 06, 2009
MIlfordPrint
  • 90 Answers
SOURCE: 3055 fax not working, sendng or receiving directly
Below is a link to an HP tech site. They helped me with MY hp all-in-one. It turned out I needed to download a different driver from HP's tech website (the download is free) and that is probably what you will be doing, also. God luck.
Posted on Aug 03, 2009
Can receive faxes but can't send
It almost seems your HP machine is arbitrarily denying you access to long distance numbers. Try referring this issue directly to HP for an explanation.
Dec 20, 2013 | HP Officejet Pro L7590 All-in-One InkJet...
Can fax to a toll free number but not to a local number
The easiest way to experiment with this problem is to plug in a phone in place of the fax.Take the list of numbers and try dialing them with the phone.Many local carriers now require for you do dial a "1" before the exchange,even if you are in the same area code.(I live in the D.C. area,and we have to dial "1" first).I believe adding a 1 to your local fax numbers will correct this issue.If not,try dialing another number at your location.If you can call one of your other numbers OK,but cannot dial to a local number even when dialing 1-area code-exchange-last four digits,this may be an issue with your long distance carrier.(Anytime you dial one before the other ten digits,it goes through along distance carrier,even on local calls).
Jun 12, 2012 | Brother IntelliFAX 1840C Plain Paper...
How to recieve a fax on the Canon PIXMA MX340 Wireless Office All-in-One Printer
Take your incoming phone line and plug it into the place that says "line" on your fax machine. Plug another phone cord into where it says "phone" and connect this to your telephone. Test to make sure you have chosen the right places by dialing a phone number to fax to and listen for the dial tone. If you get a dial tone, then you have set it up correctly.
On the fax machine look for the button that says "menu". Push it and use the up and down arrows to navigate the options on the display. Look for fax set up and press "ok" or "enter" on the fax machines keyboard to access this area. Look for "number of rings" and change the fax machine to a number of rings that is less then your voice mail box if you have one. Then close and save your choices.
Have someone send a test fax by dialing your phone number for the line connected to the machine. The fax machine will pick up on the number of rings set and automatically begin receiving and printing a copy of your incoming fax.
You cannot use magic jack.
You can also choose to manually answer an incoming fax if you see that your display on the fax machine says "ringing" or incoming" you can push the "start" button and this will start receiving your incoming fax.
Sep 30, 2010 | Canon imageCLASS MF7480 Laser Printer
We are having problems with our Muratex F110 fax machine. It won't send long distance faxes. the phone company says it is not on their end. any suggestions?
Well technically it's not on thier end. Let's remember that a fax uses a normal home style phone line.
So ask yourself these questions.
#1 Do I have long distance service on this phone line?
#2 If I do have long distance service do I need to do any kind of special dialing sequence to access long distance? Like a 9 or an 8 or any other number before dialing outside of your local area.
In some cases( businesses usually) a special code needs to be entered after dailling the number.
Most fax machines have a hansdset on them. Do this simple test. Lift the handset and dial a known long distance number and listen to what the operator message says. If all else fails call your phone company and ask them if this line has long distance capability.
Sep 22, 2009 | Muratec Office Equipment & Supplies
Fax problem. Trying to send international fax to France. I can hear the fax number being dialed ok, but no connection after 12 rings. Calling fax number from phone hooked up through mp530 connects ok! ...
Hi ...
It might be possible that the line is loose or the long distance calling code is incorrect. Follow the below instructions which might resolve the problem.
Sending Using a Long Distance Calling Code The telephone company or PBX system may use long distance calling codes on a phone line as a means to manage long distance calls. This service may extend to a fax phone line and for local phone calls as well. To use a calling code for faxing, enter a pause (or pauses, as necessary) in the dialing sequence to allow time for the phone system to distinguish between the phone number and the calling code. For example, if the calling code has to be entered after the phone number, press <Redial/Pause> after the long distance number and then enter the calling code.
Here is an example of a couple of variations that may be used by the phone company / PBX system. (For details on time sequence between the long distance number and when you must enter the calling code, please contact your phone company or telecommunications specialist.)
Long distance number: 212.555.1212
Calling code: 123456
Scenario One: 12125551212p123456 Scenario Two: 123456p12125551212
Note: The above scenarios include a pause (p) in between the dialing sequence. This pause may be necessary to allow the phone system to detect each set of dialing sequences. The pause length can be adjusted from one to nine seconds, the default is two seconds.
Tips to help you send a fax using a calling code.
  1. To send a fax using a calling code, it may be necessary to add a pause(s) before the next string of dialing digits. The above example shows how a calling code is used to dial a long distance fax number. To provide time before the calling code number is dialed and avoid misdialing, a pause should be added.
    Example: 12125551212p123456
    The number of pauses will depend on the phone / PBX system.
    It is suggested to confirm if the time before the next set of digits is dialed will always be constant. This way you can always use the same number of pauses for that dialing sequence. If needed, you can also change the pause [Pause time] length from its default 2 seconds.
  2. Connect a telephone to the fax machine.
    1. Connect a line cord from the telephone wall jack to the [L] jack (or item <1>) on the fax machine.
    2. Connect a line cord from the extension telephone port on the fax machine (top jack (or item <2>)) to an external telephone.
  3. To send a fax using a calling code, it is recommended to dial using the attached telephone.
    1. Press the <FAX> button on the operator panel.
    2. Insert the documents face-up on the ADF.
    3. Pick up the handset of the attached telephone and confirm you hear a dial tone.
    4. Dial the fax destination number on the attached telephone.
    5. When you are prompted to enter your calling code, dial it on the attached phone.
    6. When you hear the remote fax machine's high-pitched receive tones, press <Color> to send a color fax or <Black> to send a black and white fax. The audio signal heard from the handset will be cut off.
    7. Hang up the handset.
    8. When the transaction is complete, the fax machine will return to standby mode.
Don't forget to vote if this helps ... Cheers :)
Jul 17, 2009 | Canon PIXMA® MP530 All-In-One Printer
My Epson bx300f cannot send faxes, just says no dial tone?!!!
ALL fax machines are ANALOG devices and will not work on a DIGITAL PHONE LINE.
Jul 06, 2009 | Epson Stylus Multifunction Printer/...
Hp L7580 fax machine
set up the fax driver in windows printers and faxes menu with the calling card prompts. you can use commas between sets of numbers for 2 second pauses. such as (example) 9,,1800callmci,,,2,,3,,cardnumber,,,4digitpin,,3685551212, - in this fashion, you can edit the fax number here before sending the fax.
Sep 24, 2008 | HP Pavilion dv6000z Notebook
Need to program access code into phone line for long distance numbers
Does it work when you press speaker/hook and manual dial same fax number you are trying to program
It sounds like you are adding digit needed for outside line when it is in fact a direct/dedicated fax line, that needs it not (or vise versa).
Are you printing a report of rapid/speed dials that you set to ensure the number you put in is correct?
Nov 05, 2007 | Brother IntelliFax-1860C All-In-One InkJet...
Fax
An access code is normally set up by a person or company to prevent long distance faxes or phone calls by unauthorized users. The access code is a series of numbers to access long distance service. Check with your employer for the long distance code or check with you carrier to make sure that this service has not been put on your line by mistake.
Oct 08, 2007 | Brother IntelliFax-2820 Laser Fax
Only lets me enter 7 digit number
Use the chain dialling feature. Program the 1-800 into a quick dial key and chain dial using it.
Sep 05, 2007 | Canon CFX-L4000 Plain Paper Laser Fax
HP OfficeJet J4580 All-In-One Laser Printer Logo
148 people viewed this question
Seeker5211
Seeker5211
