Washing Machines Logo
D
Don Pelletier Posted on Dec 26, 2013
Bosch Washer model WFR 2460 door lock engaged and regardless of trouble shooting issue the door lock remains engaged. Even though the display says door lock off and is followed by a loud click
WFR 2460UC/01 door lock engaged tried power off/on cycle child lock disengaged as well, spin/drain cycle completed as well. Display says door lock is open but its remains locked. Manual plastic tab just came off when pulled to manually disengage the lock.
5 Related Answers
douglas smith
  • 1462 Answers
  • Posted on Jun 22, 2007
SOURCE: Door locked,wont spin or drain.
humming noise suggests a foreign object in the pump. crack open filter and drain water into a shallow tray. repeat till empty. remove filter completely and clean it. check if something stuck in pump impellor. this should be visible by looking into the filter hole
douglas smith
  • 1462 Answers
  • Posted on Oct 16, 2008
SOURCE: Bosch WFR 2460 washer - Drum does not move during wash/spin cycles
possibly the motor brushes.
take back panel off and motor is held in by bolts which undo - also disconnect electrical plug and socket.
check condition of brushes
barkencoa
Barry Coates
  • 3463 Answers
  • Posted on Nov 11, 2009
SOURCE: I have a bosch WFR 2460 washer. Er:15 error code.
You need to check and clean pump filter, normally located behind a removeable plastic cover at bottom front of washer right hand side.
If no filter found there remove rear panel of washer, and clean pump from rear of washer.
Please rate my solution.
Thanks.
Testimonial: "Thank you so much. There were some wood splinters and a nail stuck in there! No wonder it wasn't working!"
cpldw48
Dw Wooten
  • 227 Answers
  • Posted on Apr 25, 2010
SOURCE: Kenmore He 2 Plus washer door is locked and unable to open
unplug the washer an the door will open
Anonymous
  • 3 Answers
  • Posted on Feb 04, 2011
SOURCE: We have a Bosch Nexxt 100 Series Washer. The door
Getting the door open is the easy part. Finding out why it won't open might take a little doing -- though replacing the door latch is also easy. To get the door open, Take an awl or something pointy and place it in the hole on the small round cover in the lower left front of the machine. Now use this to turn the cover, unscrewing it from the machine. Once the cover is off, you should see a plastic rod hanging down. Pull this rod and it will unlock the door. You can now remove your wet clothes from the machine and investigate the cause of the problem.
Bosch WFR2460 washer---we also had the matching AXXIS dryer until recently--it died. Replaced the dryer with a new LG. In old system, the washer plugged into the dryer via an outlet in the 220 box on the...
Hi joecci,
It looks like the Door Lock may be faulty, but here is a few things you should consider looking at first:
1) Is the door closed properly?
2) Have you tried giving it power straight from the mains, the door lock needs the correct power before it functions correctly?
I believe one of the above things will resolve the problem, let me know if it does?
Regards
JEDEMEYER1
Door will not open. Have tried emergency lock release on p. 29. Still does not open. Have unplugged for 1 hr. Does not open.
emergency lock as in the release mechanism inside the access door on the lower right corner of the face of the washer? try pushing in on the door with force will doing this
Hello, I just placed a load of laundry in my Bosch Axxis washer and set the dial to the cycle I always use. However, the water will not come into the washer, and now all of my clothes are stuck inside from...
Try selecting the spin prog, if there is any water in the washer, this will drain it, and you should be able to open the door.
Please leave comment as to whether this solved your prob or not.
Thankyou.
5helpful
Thanks.
Door handle is loose and door can't be openBosh washer WFR 2460
Remove the top cover, and release the door catch from inside the front of washer.
Thanks.
5helpful
Bosch 2460 won't spin
only brushes in motor ,he taking the mikey motor only 236.00 from bosch
Bosch Axxis WFR 2460 Front Washer Drum/Cycles Not Working
hi sounds like the motor brushs are worn down,some bosch models you can change them without removing the motor ,but others its best to remove it,they just twist out,and to refit use a small blade flat blade screwdriver to tuck tab in,thanks
1helpful
1helpful
Door open? is displayed
Exact same problem happened to me (door open? when start button pressed); was not the machine, it was the wrong volts. An electrician tested the wall plug (it was 110) and changed the fuse in the fuse box to 220 volts and has ben running smoothly.
3helpful
Display field
Not sure if the 2450 is compatible with the 2460, but here is a parts diagram that shows the display module, part #AP3854652, for $97.69 from AppliancePartsPros.com. I ordered replacement carbon brushes and a drain pump from them and have been happy with their service.
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
