Question about Electrolux Microwave Ovens
Microwave makes sounds like a whale - Electrolux Microwave Ovens
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
Feb 03, 2016 | Whirlpool Accuwave Microwave Oven
Microwave makes noise when on
All microwaves make some noise when running. Cooling fans, exhaust fans, turntable motor, transformer, and magnetron all make noise. I assume you mean some unusual noise. I need to know more about what kind of noise it is - a loud roar, a rattling sound, a high-pitch squealing sound, a "clunk-clunk" sound or what? By the way, a "klunk-klunk" sound is frequently caused by small debris stuck to the wheels of the turntable support tray. Try cleaning those wheels and the track they roll in.
Oct 21, 2014 | Whirlpool Accuwave Microwave Oven
Bosch integrated microwave doesnt start/close
Door latch settings are out because door slamming and abuse of unit
Dec 02, 2013 | Bosch Microwave Ovens
My microwave turns on but the food doesn't cook
If the microwave is making a humming sound, the diode s bad and needs to be changed. If the microwave sounds normal, the magnetron is bad and needs to be replaced.
Feb 08, 2011 | Whirlpool MH2175XS Microwave Oven
The microwave makes a " beeping" sound every
check if the door is surely close
replace front pannel.
Jan 05, 2011 | Maytag MMV1153A Microwave Oven
My microwave is making a cracking sound like if it had metal in it but i took everything out and its still making the cracking sound. What could be causing this sounds if microwave is empty?
A contaminated wave guide cover will crackle and spark.
They should be periodically checked, cleaned or replaced.
Contact Maytag for replacement parts.
Hope this fixes your noise.
Nov 27, 2010 | Maytag MMV5207AAS Microwave Oven
My microwave makes a loud buzzing sound
Magnitron is going out. Suggest discarding microwave it will possibly go completely out in the near future. Good luck hope this helped
Dave
Nov 02, 2009 | Jenn-Air JMV8208AAS Microwave Oven
Emerson 1000 Watt Microwave
There is a good possibility that microwave energy is leaking near the magnetron tube, or some other high voltage electrical problem is occurring. I would recommend having it tested by qualified microwave repair technician. A few things you can do....
-Make sure the door seal is clean and no corrosion.
-Check the interior for rust spots or holes and make sure it's clean inside.
Jan 16, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
Microwave Ovens Logo
265 people viewed this question
Top Electrolux Microwave Ovens Experts
William Miller
William Miller
Paul Bade
Are you an Electrolux Microwave Oven Expert? Answer questions, earn points and help others
