Question about John Frieda JFC8 CURLING IRON
How do I turn the silly thing OFF?
Just got one for Christmas. Seems nice, heats quickly, has a bigger wand than my old one. But how do I turn it off??????
  • 17,130 Answers
If the power switch does not trigger to cut off the power all you need is to attach the heater to an power extension cord with a power switch to turn it off. The other option is to open the unit to check on the switch and the trigger to the circuit.
Posted on Jan 25, 2014
Power 740nw
seems like a very old monitor.
old things do that, they die , get weak, or just ugly.
this is called entropy.
if the screen or the screen line drivers are bad.
the fix is way more than a new monitor.
get viewsonic. get the VA2246M-LED OR BIGGER.
crisp perfect whites, and perfect colors... check it out.
nice price drop , reciently.....
Sep 28, 2013 | LG L1753T 17 inch LCD Monitor
Kenmore Progressive vacuum cleaner head continually shuts off when wand is turned. Seems to be a short in the connection between wand and vacuum head?
go to wallmart and get new one take the old one put in new box get your money back drive back home and get some vaccumeing done
Feb 04, 2013 | Vacuums
Ascaso dream wand wont heat or steam
You should descale the machine, as you may have a blockage in the steam tap.
When descaling make sure that the descaled water goes through the steam wand as well as the group. JURA descaling tablets
Mar 26, 2017 | Ascaso Dream Espresso Machine
The unit is 6 years old. Dishes on the top rack do not get cleaned. Dishes on the bottom rack are fine.
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Jan 06, 2011 | KitchenAid Dishwashers
My 5 year old Giotto has stopped working
The vent valve on the machine is stuck in the open position. Turn on the machine and open the steam wand until you hear a hiss or see small water bubbles from nozzle, let it steam out a little more then close wand, that should allow the machine to heat up correctly, then order a new vent valve for the machine.
May 03, 2010 | ECM Giotto Espresso Machine
No water flowing through steam wand
You might want to try draining the machine and filling it back up. There could be a number of different things wrong with your machine.
Mar 21, 2009 | Starbucks Barista Utopia
Top wand does not spin
You may have a water volume problem.
The water fill sequence on most washers is timed. Insufficient water at the bottom of the washer will cause the pump to cavitate.
Ensure water is filling to just under the heating element.
You can fix this by isolating the water and electricity then remove the fill solenoid. Inside the solenoid is a top hat filter screen. This screen captures sedement.
Once the sedement was removed on my washer the wands turned
My machine also had a check valve on the bottom near the back of the machine that was blocked.The valve needs to work freely in order for the pump to build pressure. The check valve can be removed from the top by turning the assembly counter clock wise.
Feb 01, 2009 | Frigidaire 24 in. FDB510LC Free-standing...
Battery exhausted
I found this happening until I decided to change to re chargeable batteries and havnt had this problem since.
Aug 19, 2007 | Nikon Coolpix 3200 Digital Camera
John Frieda JFC8 CURLING IRON Logo
591 people viewed this question
Top John Frieda Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a John Frieda Health and Beauty Expert? Answer questions, earn points and help others
