Question about HP LaserJet Office Equipment & Supplies
HP m410n laserjet pro banding gray vertical lines
Our office has an HP laserjet pro that started printing grey vertical lines a few months ago. The lines started out about 1 inch thick on the left side of the document, but have grown to take up about half of the document. We tried replacing the toner cartridge... which oddly fixes the problem for about 3 pages, and then any subsequent pages print out increasingly large grey vertical lines again. The orientation is now in the middle of the page after our last toner change instead of on the left as it started.
    Problem Solver:
  • 33 Answers
The two places to look is transfer roller and the fuser unnit.
i think there is a problem with the transfer roller it is under the toner and it needs to be spring loaded. The paper passes between the toner an the transfer roller to charge the paper en let the toner stick to the paper and if it doesn't make correct contact then it wont work
Posted on Dec 27, 2013
  • 82 Answers
SOURCE: HP Color LaserJet 2600n - Thin White Line on Print Out
Which color is this line? Try changing respective cartridge..
Posted on Sep 09, 2007
Soulvisitor
  • 1113 Answers
SOURCE: Print quality bad
To clear white vertical lines from printed documents follow the steps listed below:
NOTE: The use of non-Brother or generic toner may cause white vertical lines.
Brother strongly recommends that customers do not use generic drum units and/or toner cartridges, or refill their Brother toner cartridge. Each Brother laser printer is designed to work at pre-set temperatures that are matched exactly to each of our individual toner formulations. Each individual component is designed to work with the other to ensure quality and reliability. Using non-Brother supplies may affect the hardware performance, print quality and machine reliability.
The Brotherlimited warranty does not apply to any problem that is caused by the useof unauthorized third party drum units, toner cartridges or toner.
1. First, power OFF the unit for safety. The ON/OFF switch is located on the left, rear side of the unit.
2. Open the scanner cover by pulling the blue lever located below the control panel toward you and lifting the cover. Make sure the cover is completely open.
3. Remove the drum unit by holding each side of the drum by its handles and gently lifting the drum forward (toward) you.
4. Place the drum unit on a drop cloth or large piece of disposablepaper to avoid spilling and scattering the toner. Make sure thedirections and DR-250 stickers are facing you.
5. With the drum removed from the Brother machine, clean the laser glass. The laser glass is located inside the Brother machine where the drum was located. It is a piece of glass, about 1/2 inch wide and approximately 8 inches long, located on the bottom of the inside. Gently wipe the glass with a clean soft DRY cloth. DO NOT use isopropyl alcoholor any liquid to clean the glass.
6. Gently pull up on the mauve lever to turn the toner cartridge toward you until it stops. Remove the toner cartridge from the drum unit by gently sliding it out of the drum unit. ***Handle the toner cartridge carefully. If toner scatters on your hands or clothes, immediately wipe it off or wash it with cold water.
7. Gently rock the toner cartridge from side to side five or six times to distribute the toner evenly inside the cartridge. Then, reset the toner into the drum (be sure it clicks into place). Gently push on the mauve lever to turn the toner cartridge away from you until it stops.
8. With the DR-250 sticker facing you turn the drum upside down. There is a blue tab located on the right side. Slide the blue tab back and forth seven times to clean the corona wire. When finished, make sure the blue tab is locked to the right side of the drum.
9. Reset drum unit in Brother machine. Close the cover securely.
Print the help list to test the unit by pressing the REPORTS key located on the control panel and then (1) on the dial pad.
If the white vertical lines still continue, the drum unit will need to
be replaced.
If the purchase date of the original drum or replacement drum is less than 90 days (within the warranty of the drum), contact Brother Customer Service Center at 1-877-Brother (1-877-276-8437) . The center is open Monday-Friday, 9:00am to 7:00 pm EST, excluding holidays.
Posted on Dec 27, 2007
IB4G2008
  • 3587 Answers
SOURCE: Full ink cartriges print a few lines and skip a few lines
well..did you run a test page?
or clean the print heads?
or recalibrate them?
recommend all these steps for you
and as my 2200th solution, you are entitled to a FREE tuneup for good. find out more about that service here
Posted on Mar 24, 2008
  • 25 Answers
SOURCE: HP LaserJet 2100tn prints ok but with 3 lines of strange characters over image
Is your transfer roller clean?
How does the drum look on the toner cart?
Is the fuser getting bad?
Would you consider this an old image that is ghosting?
Posted on Aug 14, 2008
  • 5 Answers
SOURCE: HP Laserjet 1100, band of unprinted area after new toner install
Hi Friend,
You have mentioned this is a 2nd hand printer,
you have to service the printer,(fuser unit)
if the problem exists after fuser service check Laser Scanner also,
Thanks
Lux5
Posted on Nov 28, 2008
Hp 2420 leaves vertical line across the page. we changed the fuser 7 months ago
It sounds like you may need to change it again. These printers use a Teflon coated heat roller in the fuser. If you print envelopes that will scar the heat rolller, this can also happen if there is a piece of paper jammed in the fuser assembly and it scraped the fuser roller. Open the back of the printer and look at the roller in the fuser. I would bet that you see the roller is damaged. Here is a link to a post about the Laserjet 2100 printer with the same issue. It has pictures of the roller and what to look for, the fuser is different but the principle is the same.
http://www.ccl-la.com/blog/index.php/how-to-fix-hp-laserjet-2100-vertical-lines-on-print/
I hope this helps, if so please rate my solution.
BuddyMc
Sep 20, 2011 | HP LaserJet 2420dn Printer
Hp laserjet printer is printing a large vertical
if the band is white, you may have a problem in your laser scanner assembly, if the band is black, you may have a problem in your fuser assembly
Mar 30, 2010 | HP LaserJet 1012 Printer
HP 1020 produces 2 grey lines at edges of page
it is the problem humadity or laser mirror is dirt clean it and then solve your problem
Jul 05, 2009 | HP LaserJet 1020 Printer
HP LaserJet 2430 prints vertical grey bands
It is a bad Toner Cartridge or Fuser. Most likey a bad toner cart.
Mar 07, 2009 | HP LaserJet 2430n Printer
Smudged Printing
replace the toner. many remanufactured cartridges will do this due to leaks during/after refill.
Nov 07, 2008 | HP LaserJet 4 plus Printer
99% of printed page has light grey water mark-as if water-washed
Are you saying it is this problem?
Gray Background Print Quality Defect
Here's another error that might fit the bill:
Vertical Lines Print Quality Defect
If these documents don't quite describe the issue, please post back with more details. Thanks.
Oct 14, 2008 | HP LaserJet 1020 Printer
Printing
check your toner/drum cartridge. lift the flap, do not touch roller (usually green), is the same grey band on the roller, if so replace cartridge.
May 06, 2008 | HP LaserJet 3050 All-In-One Printer
Grey band on left side of printed page.
replace toner drum or replace cartridge
Mar 19, 2008 | HP LaserJet 4 plus Printer
Grey lines on printout
90% chance its the Cartridge or 10 % chance its the fuser
Nov 26, 2007 | HP LaserJet 4 plus Printer
242 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
