Question about Paradigm PDR 8 Subwoofer
Subwoffer will not power up
Does anyone have a PDR-8V.3 schematic?
    Sergeant:
  • 79 Answers
PDR-8 Specifications
Design
Single driver, bass reflex system with critically tuned resistive port and built-in amplifier Amplifier High-current, discrete output, 90 watts RMS
Amplifier Features Soft clipping, thermal protection Frequency Response On-Axis 29Hz - 150Hz Low Frequency Driver 210mm (8 in) extended travel with 38mm (1-1/2 in) voice-coil, aluminum former Low Frequency Extension 29 Hz (DIN) Finishes Black Ash, Light Cherry, Dark Cherry Inputs From A/V receiver/processor or Paradigm X-Series Subwoofer Control Unit mono-sub out or preamp left/right output;From receiver/amplifier speaker terminals or main/satellite speaker terminals Weight 25 lbs. (11 kg) Dimensions HxWxD 13.25" × 9.75" × 15"
(34cm × 25cm × 38cm)
Specifications are subject to change without notice.
© 2016 Paradigm Electronics Inc. Conditions of Use Privacy Policy Unauthorized Dealers WARNINGSouth Africa
Posted on May 25, 2016
Tip
How to connect my iPod to a Pioneer PDR-609
<p>The Pioneer PDR-609 is a personal CD recorder used in conjunction with the rest of your home audio system. The equipment has a few audio inputs, however, so you can connect external devices to play through the Pioneer PDR-609, including an Apple iPod. You need a special adapter cable, but once connected, the sound from your iPod through the speaker Pioneer system. <br /> <p><br /> <p>1. Connect the end of the cable 3.5 mm headphone of your Apple iPod. <br /> <p><br /> <p>2. Insert the red and white RCA cable ends into the "Line In" port on the back of the Pioneer PDR-609. <br /> <p><br /> <p>3. Power on the iPod and the Pioneer equipment. Select "Line In" as the display option in the Pioneer, then the song you want to listen to your iPod and press select "Play". The music now plays through the speaker system of the Pioneer system. <br />
on Aug 09, 2011 | Apple iPod touch
92 tracker ecm harness diagram
old post
want a schematic
or pin number and name
or just shapes harness runs
the FSM has all 3.
no engine stated, 8v or 16v and both are radically differnt
we have it, ask.
Apr 02, 2014 | 1992 Geo Tracker
My AVR-E400 sub woffer not working through the Denton system
AVR-E400 has an RCA subwoofer output. This is a line level signal that must be connected to an ACTIVE subwoffer (has its own power amplifier) Also the source must contain subwoffer signal (5.1, 7.1, 9.1 surround sound etc) You will not get subwoffer signal from a stereo source such as audio CD, non-dolby type TV etc. Cheers, Don.
Dec 05, 2013 | Denon Audio Players & Recorders
97 dodge neon died replaced parts and still no spark HELP.
YOU NEED TO CHECK DARK GREEN/ORANGE WIRE AT IGNITION COIL WHEN CRANKING ENGINE FOR POWER..IF NO POWER,SHUTDOWN RELAY IS NOT BEING ENERGIZED..THIS ENGINE ALSO HAS CAMSHAFT POSITION SENSOR ON END OF CYLINDER HEAD..ENGINE CONTROLLER NEEDS CAM AND CRANK SIGNALS TO ENERGIZE THE SHUTDOWN RELAY..UNPLUG CRANK SENSOR AND CHECK VOLTAGE ON ORANGE WIRE..SHOULD HAVE APPROX 8V..IF NOT..UNPLUG CAM SENSOR AND SEE IF 8V SUPPLY RETURNS..IF NO POWER TRY UNPLUGGING VEHICLE SPEED SENSOR LOCATED IN TRANS HOUSING WHERE RIGHT SIDE AXLE COMES OUT OF TRANS..IF 8V RETURNS..THE SPEED SENSOR IS SHORTED INTERNALLY..THESE 3 SENSORS SHARE THE SAME 8V SUPPLY CIRCUIT..WITH SPEED SENSOR UNPLUGGED,PLUG CRANK SENSOR BACK IN AND TRY TO START ENGINE..HAVE SEEN THIS SAME PROBLEM AT WORK RECENTLY
Jul 18, 2009 | 1997 Dodge Neon
Toshiba PDR-M65
Its an old model. Just buy a card reader that processes SMC Smart Media.
Jan 07, 2009 | Toshiba PDR-M65 Digital Camera
HTS 3450 subwoffer off
I have a similar problem. I inspected the power board and found IC901 burned completely. I cannot find out the part number and have tried to get a reply from phillips but have not heard back from them. Anyone have a schematic or can give me the part # of IC901?
Sep 06, 2008 | Philips HTS3450 System
Power Indicator Light on Front Doesn't Light
The indicator light needs to be replaced, there is a loose or poorly soldered connection on one of the led's leads, or the circuit providing the signal (voltage) for the light isn't functioning.
Sep 17, 2007 | Paradigm PDR 10 Speaker
Pioneer PDR-W839 Disc Changer Jammed
look for a small pinhole and insert a pin while powered up to reset the device
May 26, 2007 | Pioneer PD-RW839 4-Disc CD Recorder
Toshiba PDR-M61 drivers
I bought this camera (Toshiba PDR-M61) for a while now & I lost the driver cd to install it onto the PC to recognize it. Can you send me the software or route me to the location on the internet that I can get the driver for this?
Regards
Duy
Sep 15, 2005 | Toshiba PDR-M61 Digital Camera
Paradigm PDR 8 Subwoofer Logo
134 people viewed this question
Top Paradigm Audio Players & Recorders Experts
 Grubhead
Grubhead
woodzowl307
Don Hart
Are you a Paradigm Audio Player and Recorder Expert? Answer questions, earn points and help others
