How do i know if my prongs are bent
Are they supposed to be sticking straight out or bent towards the bottom of the usb port
    Sergeant:
  • 233 Answers
If your talking about the USB connector (Inside) it should be straight.
The male and female will look like they on on opposite sides.
Like the image below:
how do i know if my prongs are bent - bb40c7c9-8842-4fdc-b98c-2ea29fc7ca0d.jpg
Posted on Mar 29, 2014
Usb port prongs are bent how to fix
You will have to take the tablet apart and solder a new usb charging port. They can be bought cheaply on Amazon and eBay. Best you know how to solder and use the correct glue. YouTube is a great help on telling how to take apart a tablet with guitar picks
Mar 12, 2015 | Tablets & eReaders
Prongs inside mini usb port on camera nikon d40 bent
best thing to do is send it in for repairs but if your confident in opening it up then just make sure you take note of exactly how you opened up so you are able to put it back together again and then carefully bend the pins straight or how ever they were originally remember if over bent you run the risk of snapping the pins and then you will have to (and this is not often very easy to do)source the unit and then have the skills of soldering and this is also not very easy
Apr 12, 2014 | Nikon COOLPIX L18 Digital Camera
Wher are the USB ports on Advent DT1308
Advent Advance DT1308 Desktop PC?
http://www.pcpro.co.uk/reviews/desktops/370084/advent-dt1308
Look at the Back of your Advent computer tower.
Look at the lower left.
This rectangular area is the I/O area.
Input/Output area.
This is where Input and Output devices are attached.
Look at the Purple round PS/2 port all the way at the right bottom.
It's where the Keyboard plugs in.
Right above it are four USB ports.
http://en.wikipedia.org/wiki/USB
There are several styles of USB ports. This style is a USB female type A,
http://en.wikipedia.org/wiki/File:USB.svg
(Standard A )
According to the review (Specs tab), there is supposed to be two USB ports in the Front. (Front Panel)
I do not see them.
Could be behind a door that swings open.
Looking at the Side View, with the Side Panel of the computer case removed, the USB cables going to these front ports, are going towards the bottom/front.
Regards,
joecoolvette
Apr 25, 2012 | Computers & Internet
I simply do not know where the sandisk cruzer 4 GB is suppose to be inserted. I tried a USB 2.0 connector, but the sandisk does not fit.
The sandisck cruzer fits in any standard USB port. Make sure there is nothing jammed in the USB port or that the cruzer's socket is not damaged - (Like if the metal is bent or our of shape.)
Jan 10, 2011 | Computers & Internet
2 problems loss of power a xbox 360 console
Check to see if any prongs are touching or bent in the USB ports. When the USB port prongs are bent they sometimes wind up touching the receiver tips of where the USB makes contact with any devices that you plug in. If they are bent just bend them up so they arent touching the metal receivers and that should solve the no power to xbox360.
May 09, 2010 | Microsoft Xbox 360 Console
Bent prongs in USB port on the m-audio keyboard
Sadly, not too much can be done. You COULD try to get in there with a small tool and bend them back, but I don't know how extensive then damage is. If you really know what you are doing, you could find an old device with a USB port on it, de-solder that port off, and solder it onto the keyboard. But If you try that, I really hope you know what you are doing. If not- time for a new keyboard. Or- get yourself a USB 2.0 hub and place it next to your keyboard. I have one stuck to the side of my PC with velcro tape.
Apr 29, 2009 | M-Audio Session KeyStudio USB Keyboard
1 ice cube gets stuck when the maker dumps ice
Look at the 2 blades where the cube sticks carefully.
My bet is that the blades are ever-so-slightly bent toward one another - or the factory remove-before-use lable remmnants are still on one of the facing blades.
If label is there, remove with edge of credit card. Don't force, USE NO TOOLS
If they are metal and bent, simply bend very slightly beyond parallel and check again until straight
If they are plastic and bent, bend farther than needed and let slowly loose. Check and repeat
Good Luck!
Jan 16, 2009 | Frigidaire FRS3R5EMB Side by Side...
Front usb port of xbox looks broken, unit does nothing now
Simple. Just solved it with advice from this site. If you see any of the gold prongs touching the side (or possibly each other) then find a thing tool and try to hook the gold prongs so they point direct upwards. how bad they get bent doesnt matter, just get them all standing up and not touching the sides. you probably cant use the port again but atleast it turns on.
Oct 16, 2008 | Microsoft Xbox 360 Console
My xbox won't turn on
hey guys i was freakin out because i had that same problem.  i didnt want to pay an extra 1000$ just because the stupid repair guys wouldnt tell me the answer.  So look inside your broken usb port, there should be like golden prongs in there.  if they are bent, straighten them and you can turn your xbox back on.  Now this might not be the case with you, but that is how i just solved my problem.  if you have any questions ill try to keep posted and see if i can help further. also you can get me at my gamertag for xbox live.  its volcomxskater37
Jul 05, 2008 | Microsoft Xbox 360 Console
Usb port
yes you are but you may not have done it properly so you should take it to a professional service center or technician and have them do the repair for you.
Aug 23, 2007 | Motorola Mobility RAZR V3
Computers & Internet Logo
David Payne
David Payne
