Question about Refrigerators
Frigidaire model PHS69EJSS0 water leaking in ice makier freezing up evaporator fan
Water is leaking in the freezer near the evaporator fan causing the fan to be stopped by the ice build up. Want to know how we can fix the source of the problem ourselves.
  • Refrigerators Master
  • 8,220 Answers
That might be a bad drain. Thaw her out. Clear the drain with hot water or blow it out best ya can and see if that fixes it. That is what you try first. If the problem still there ya might have a defrost problem. The defrost circuit consists of a heater a heater termination thermostat and a timer or defrost control. Every 8 hours or so the defrost control powers up the heater for 21 minutes or longer AND shuts down the compressor and fans.if the heater was to stay on for 21 minutes or longer it would melt the plastic ling and cook the frozen food because it is a calrod heater just like an oven element. The heater must shut down to prevent harm to the ice box so they install a small thermostat that shuts off power to the heater when the temp inside the evaporator sector is warm enuff ta melt frost. Most times the heater does not go bad if it is a metal calrod style, glass heaters do go out quite frequently however. The most likely candidate to fail in the defrost circuit is gonna be the termination thermostat. When that puppy fails the evaporator does not get the heat from heater and frost begins to build. It takes several weeks to get to the point that ice has dammed up into the evap fan and caused it to malfunction. The cheapest part is the defrost thermostat so if the heater is fine replace the stat and see if that fixes it. Other thangs to check for is loose or worn out door gasget and improper sealing doors. To make a door close tighter raise the support legs in front slightly to throw the doors tighter against the frame. That's all the smart pills I has for today. -PawPaw
Posted on Dec 27, 2013
HVACRH20
  • 237 Answers
SOURCE: leak from icemaker shorts electricity in house
It sounds like the ice in the bin is warming up enough to melt for some reason then re-freeze. Check your door gasket seal and also the ice chute door flapper seal to make sure warm room air isn't being drawn into the ice bin area. Also make sure the freezer area is VERY cold like 0 degrees F or lower, that will keep the ice hard and help stop the ice from having a liquid surface film from opening and closing the freezer door too often (then freezing again). The water down the back is from the ice cubes melting a little then re-freezing. Also, is the frige working OK? Does the compressor turn on and off normally? I ask because sometimes the compress start device is failing and the refer can warm up quite a bit while the compressor is trying to start up... eventually the compressor will start but by then the ice has melted a little then the compressor runs for a long time to bring the temps down again. Monitoring with a thermometer every hour will show if the temps are lowering in the freezer section too much.
Posted on Dec 11, 2006
SOURCE: Freezer leaking water
The drain is plugged just below the coils in the back of the freezer. My fridge had the same problem and I found the hose (which can be accessed from the rear bottom) was plugged with mold. Also, i noticed the hose was connected to the water holding pan and was too close to the bottom and easy to plug. I removed it from the connector and just let it dangle in the holding pan.
Posted on Sep 19, 2008
larryyb
  • 291 Answers
SOURCE: Water accumulation in bottom of freezer in Frigidaire FRS26ZSHB5
take out everything and at the lower inside back of the freezer you have a drain ..... pour hot water till it opens / the water comes from you evap when it goes into defrost and it cant get out the drain / Larry
Posted on Nov 25, 2008
Sea Breeze
  • 4654 Answers
SOURCE: Ice build up on bottom of freezer. Water leaks out.
Your problem is possibly one of two things. The ice maker is leaking or the defrost tray behind the rear panel inside freezer back wall is clogged with ice or something else. If you know its not the ice maker unplug the refrigerator and remove the back panel to see if the drain is blocked there, Let me know, Sea Breeze
Posted on May 21, 2009
  • 358 Answers
SOURCE: Leaking water and ice build-up in freezer
There's a drain hole in the freezer side behind the bottom drawer in the back wall that must be clogh ; put hot water into it untill melted the ice and keep pouring water to clean the drain (don't worry , the water goes to an evaporative tray) .Keep the drain clean by putting every 3/4 months half a cup of clorox or bleach.
Posted on Sep 28, 2009
Fridge leaking water and noisy fan in freezer
I'm going to guess this refrigerator has an icemaker in the freezer. The water leak may be from the ice maker filling process. If that is correct, the water sometimes gets behind the freezer back wall and re-freezes around or near the fan blades causing the noise. Just a guess with out a brand name and model number.
May 01, 2015 | Refrigerators
Water Freezing Under Evaporator Fan
Check this site for more info on where the defrost timer might be.
May 05, 2008 | GE PTC22SBMR Top Freezer Refrigerator
2005 Whirlpool Refrigerator GS5SHAXNL cycling on and off and fan has gotten louder. Is this normal?
When the water solenoid valve leaks by initially, the water overflows into the freezer evaporator and I have seen an ice stalagmite up to 2 feet high form near the evaporator fan. The ice is probably inpinging on the evaporator fan blades. If not corrected, the fan motor will burn out and will need to be replaced. Take you model number to searspartsdirect.com and get an new water solenoid valve and install it.
Sep 28, 2014 | Refrigerators
The freezer isn't making alot of ice. Can the hose behind the ice maker freeze?
Hi and welcome to FixYa, I am Kelly.
When a refrigerator slows down ice production it is usually the result of poor air-flow through the evaporator coils. The poor air-flow is due to ice build up on the evaporator coils. The ice build up happens because the unit is not defrosting properly or the evaporator fan is not running at full speed.
To answer your question "Can an Ice-maker tube freeze?" Yes, they can and do freeze but when they do freeze that is caused by a defective inlet water valve that is leaking water by when it is supposed to be shut off. It can freeze if some one set the temp control to MAX cold. Additionally when they do freeze and the Ice-maker cycles the plastic hose on the back of the unit pops out of the ice maker tube and each cycle starts porting ice maker fill water on the floor.
This may sound odd.. but. Perform a manual defrost by removing the freezer contents and directing a fan into the freezer compartment for just over 2 hours. (Makes a water mess so do not leave it unattended) The return the unit to normal service and after 8 hours start watching the amount of ice produced. (Should be normal for 2 days!) If after 2 days the ice production slows again you have an automatic defrosting problem that is causing the ice build up on the evaporator coils.
If you need any more assistance please include your complete model number in any future responses.
Thanks for choosing FixYa,
Kelly
Feb 15, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
What is causing the items in the vegetable bin to freeze and the ice maker is not working,(ice melted in the bin) and the water dispenser is not working and the filter was just replaced a week ago /
Sounds like the source of your refrigerator freezer temperature problem is due to a faulty evaporator fan motor. This fan circulates the air from the freezer to the refrigerator and back to the freezer. When it fails, temps are warm at the top, cold at the bottom, so the ice melts, and the water tank inside the fridge, near the bottom, freezes. I looked up your model #, but it shows no results so i cannot give you a part number.
Also, its possible if you have a control board microcomputer, its bad as well. Some model GE refrigerators the fan burns out part of the computer, necessitating replacing both.
Oct 05, 2010 | GE Adora DSS25KSTSS Stainless Steel Side...
My frigidaire side by side freezer freezes up and the filter in the refrigerator leaks water. It makes ice fine but will not freeze ice cream. theres a big clump of ice in the back which is under a cover...
the leaking water is the problem. it needs to be fixed, but till then defrost again, use a fan it speeds the process, SHUT OF WTER to ice maker. restart fridge it will work normally. now find parts needed to fix the ice maker water feed.
the leaking water overwhelms the defroster. and causes a coil freeze up, this impedes cooling and air circulation over the evaporator coils
Jun 15, 2017 | Frigidaire FRS23KF7AB Side by Side...
Side by Side Freezer ice build up and water in the
Either the drain hose is plugged up with ice and not dripping into evaporator tray, or the defrost unit needs to be replaced.
Aug 04, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Water collecting and freezing in bottom of freezer
Hi, Remove the rear inside panel of the freezer and locate the drain hole under the evaporator coil. Remove the ice and flush the drain hole with hot water to make sure it is free. You can try running a soft wire through the drain also.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jul 04, 2009 | Frigidaire FRS26R4A Side by Side...
MY BROTHER HAS A FRIGIDAIRE REFRIDGERATOR MODEL NUMBER. FRS3HR5HW3 AND IT IS MAKING A GRINDING SOUND KIND OF IN THE FREEZER. WAS WONDERING WHAT IT CUD BE AND HOW TO FIX IT.
I am having the same problem. I had a technician check it out and he replaced the evaporator fan motor. A month later the noise returned. The technician came again and said the cause was the water valve freezing and the ice buildup hitting the evaporator fan. I am having my brother repair it this weekend. The cost for the tech. was nearly $300, almost a third the value of the fridge. I, personally think there is a design flaw in the refrigeration system.
Apr 29, 2009 | Frigidaire Model: FRS3HR5HW
Fridgidare, freezer cold fridge warm
sounds like you may have gotten a refridgerant leak causing a low charge condition. some refridgerators have a evaporator fan if this quit working it will cause it to freeze up .thus the freezer does not use a fan and it will still get cold
Jan 05, 2009 | Frigidaire FRS26ZSG
Refrigerators Logo
93 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
