Question about Motorola Mobility MOTORIZR Z3 Cellular Phone
Entering new phone number
How do you enter pauses in a new number?
  • tigerpaws Oct 17, 2007
    I want to enter a phone number for my voice mail.  That means I 'dial' the first number and then I have to wait for a prompt before I enter the mailbox number.  So I need there to be a pause of about 5 seconds between the first number and the second number.
  • tigerpaws Oct 18, 2007
    Here is the solution I got from Motorola:  Regarding your concern, in order to add pauses to a contact number, please follow the steps below:
    the OK key > Contacts > New Contacts > Press the OK key >
    Enter a name for your entry > Scroll to Mobile 1(or the appropriate
    option), then enter the number for your entry > Press Options, then
    press the OK key > Press Add or insert Pause.
    Pause (p):
    The phone will pause for 3 seconds and then proceed with the next set
    of numbers. Multiple pauses can be entered to allow for more time. Most
    used for voicemail and other automated systems.
  • 94 Answers
I dont get what you mean do you mean like spaces inbetween numbers ? because im not sure if you can do that or not . if for example you want to type to a landline number . e.g 01204 311 321 then  you just simply type 01204311321 . Hope i helped
Posted on Oct 17, 2007
How do I save phone numbers in the phone book. Nothing mentioned in instructions on how to finish the entering of numbers.
adding phone book entries
with the phone in standby mode, open the phone book
press menu/select and select create new
enter a name and number
enter the phone number ( up to 20 digits exactly as you would dial it )
if you need the phone to wait before sending the next of digits press redial/pause to insert a2 second pause
You can insert multiple pauses , but each one counts as a digit ( you will see P in the display)
the save mode is the menu button after each entry
Aug 06, 2017 | Cell Phones
How to store numbers using panasonic KX-T7630
Hello Jd,
For storing numbers in panasonic KX-T7630
While on-hook Enter phone number(max. 32 digits). AUTO DIALSTORE OR Press STORE or ENTER. Enter name(max. 20 characters). AUTO DIAL Store or Pres STORE or ENTER.Press Exit or Pause.
Aug 18, 2011 | Panasonic KX-T7630 Corded Phone
I have just purchased a DECT3035 and am having difficulty putting in phone book entries
Adding Phonebook Entries
With the phone in standby, open the phonebook. Press Menu/se lect and select Create New. Enter a name & number and select a personal ring.Enter the phone number (up to 20 digits) exactly as you would dial ♦♦ l it.♦♦If you need the phone to wait before sending the next set of digits,press Re dial/pause to insert a 2-second pause. You can insert multiple pauses, but each one counts as a digit (you'll see P in the display).
More information read the manual
Jun 22, 2011 | Cell Phones
Dialing speedial 1 does not access my voiemail even tho it says it is dialing it a greeting comes on asking for an access code. the nly way to get voicemail is dialing manually and the icon onscreen does...
OK, usually one cannot use the speed dial feature unless you insert, pauses in the number, IE: you must add 1 second, "Pauses", after and before the number you dial... also you can then add, your access code too, well theoretically anyway..
So, you pause, for 1 sec, then dial the number, pause for 2 - 3, 4, maybe 5 seconds, seconds, then enter your access code and Enter code.
This should then be able you to then speed dial and connect and enter your PIN, all at the same time, if your PIN isn't recognized, try adding more pauses before entering.
If NONE of it works, then you simply have a network/phone that will not do it.
Aug 11, 2010 | Cell Phones
How can I enter a soft (2 sec.) pause in a contact number on A766
1) From the Home screen, go to Start > Contacts
2) Select the desired phone number
3) Press the Menu soft key and select Edit.
4) Use the Left or Right navigation key to place the cursor at the place where the pause needs to be added.
5) Press the Menu soft key and select Insert Pause to add a two-second pause. The letter ‘p‘ will appear where the pause has been set.
6) Use the keypad to enter any additional numbers if desired.
Tip: You can create pauses longer than two seconds by entering multiple pauses.
Aug 01, 2009 | Samsung Propel A767 Cell Phone
Forgot how to add new phone numbers and names to my phone
Creating Phonebook Entries To store names and numbers in your Phonebook, please follow these steps: When the phone is in standby mode, press [phonebook icon] (on the left side of the four-way key). To create a new phonebook entry, press the NEW soft key. Edit Name appears. Enter the name for this entry (Edit Name). Use the keypad to enter a name for this entry; the name can contain up to 1 6 characters. (See page 1 1 for instructions on entering text.) If you do not want to enter a name for this entry, your phone will store this entry as No Name. Press the OK soft key when you are finished. Enter the number for this entry (Edit Number 1). Once you have stored a name, EDIT NUMBER1 appears next. Use the number keypad, [right] or [left] on the four-way function key, or the DELETE soft key to enter the phone number 1 ; the phone number can contain up to 32 digits. If you need the phone to pause between digits when it’s dialing (for example, to enter an extension or an access code), press [redial/pause] to insert a two-second pause. You will see a P in the display. You can also use more than one pause together if two seconds is not long enough. Each pause counts as one digit. Press the OK soft key when you are finished. EDIT NUMBER 2 appears next. Use the same procedure when entering the phone number 1 to enter the phone number 2. Press the OK soft key when you are finished. Assign a personal ring tone for this entry (Personal Ring). You can attach a personalized ring tone to each phonebook entry; the phone will use this ring tone when this person calls. Move the cursor to highlight one of the 20 different ring tone options. As you highlight each ring tone, you will hear a sample of that tone. When you hear the ring tone you want to use, press the OK soft key. If you do not want to use a personal ring tone for this phonebook entry, select the NO SELECTION option, and the phone will use your standard ring tone setting. Assign this entry to a Speed Dial number (Speed Dial). Your phone has 1 0 speed dial numbers, 0 to 9. Move the cursor to select the speed dial number you want to assign to this phonebook entry, and press the OK soft key. Select NO SELECTION if you do not want to assign this entry to a speed dial number. Press the OK soft key. You will hear a tone confirming that the new phonebook entry has been stored, and DONE! appears in the display. Note: When the shared memory is full, the oldest Caller ID message is overwritten.
Jul 19, 2009 | Uniden 5.8GHz Dual Cordless Phone
Enter memory data
Here are the commands to run the phones memory dial (speed-dial).  I have included the instructions for deleting and changing numbers as well.  It is listed below.  I hope this helps you out.
MEMORY DIAL INSTRUCTIONS Store up to ten 20-digit numbers in memory for quick dialing. Storing a Number in Memory 1. Make sure the phone is OFF (not in TALK mode). 2. Press the MEMORY button. 3. Press a number (0-9) to store the dialed number in that memory location. 4. Press the MEMORY button again. 5. Use the handset number keypad to enter the telephone number (up to 20 digits, including pauses) and press the MEMORY button again to save the number. The unit beeps to confirm. 6. To enter another number in a different memory location, return to step 1 and repeat the process.
Storing a Redial Number 1. Repeat steps 1 through 4 in Storing a Number in Memory. 2. Press the REDIAL button. 3. Press the MEMORY button to store the number. You will hear a confirmation tone.
Changing a Stored Number 1. Repeat steps 1 through 6 in Storing a Number in Memory. 2. Press the MEMORY button to store the number. You will hear a confirmation tone. The old number will be overwritten with the new number.
Dialing a Stored Number 1. Make sure the phone is ON by pressing the TALK button. 2. Press the MEMORY button. 3. Press the number (0-9) for the desired memory location. The number dials automatically. Inserting a Pause in the Dialing Sequence Press the PAUSE# button once to insert a delay in the dialing sequence of a stored telephone number. A pause is needed to wait for a dial tone (for example after you dial 9 for an outside line, or to wait for a computer access tone). Each pause counts as 1 digit in the dialing sequence. If you need a longer pause, press the PAUSE# button twice.
Deleting Stored Numbers 1. Press the MEMORY button. 2. Press the desired memory location (0-9). 3. Press the MEMORY button twice to delete the entry. 4. You will hear a confirmation tone.
Jan 08, 2009 | GE 27928GE5 Cordless Phone
Phone numbers
Hi gt,
Just enter the letter p, which will pause.
HTH, ;-)
Aug 22, 2008 | Motorola Mobility RAZR V3
Uniden 900MHz phone model EX17960A
Using the Speed Dial Memory
Storing Numbers in Speed Dial Memory
Your cordless phone can store up to ten numbers in the speed dial memory.
1) When the phone is in standby mode, press the memory key. The talk/batt low LED flashes.
2) Use the keypad to enter the phone number; each number can be up to 20 digits.
3) If you need the phone to pause during the dialing sequence, press
the redial/p key to insert a two-second delay between the
numbers. You can enter multiple pauses to increase the delay.
Each pause counts as a digit.
4) Press the memory key again.
5) To store this number as one of the ten speed dial numbers, enter a
digit from 0 to 9. If there is already a number in that speed dial
setting, it will overwrite the previously stored number without
warning. You will hear a confirmation tone indicating that the
number has been stored.
NOTE: When storing numbers into memory, if the handset is idle
(i.e., no key is pressed) for more than 30 seconds, it will beep rapidly, and the phone
will return to standby mode.
1) When the phone is in standby mode, press the talk key, and listen for a dial tone.
2) Press the memory key and enter the speed dial entry (0-9) that has the stored number you
want to dial. (If you enter a digit that does not contain a stored number, the handset will
beep rapidly, and the phone will not dial.)
Nov 13, 2007 | Lands Phones
Motorola Mobility MOTORIZR Z3 Cellular Phone Logo
88 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
