Question about Jandy Laars Lt 250,000 Btu Heater
Jandy LT/LX 400,000 btu leaking water from high limit
Jandy LT/LX 400,000 btu in ground pool heater is leaking water from 150 degree high limit sensing port. I removed the cover plate to the limit switch and noticed that there are 2 ports where this sensor can be installed, the sensor was installed on the right side port, and the left side port has a small brass piece that looks like a slotted screw head, this brass head came off the manifold and I believe that this is where the water is leaking from. After carefully examining the part, it appears to be some type of transducer that the high limit makes contact with while sitting in the chamber. It does not have any threads but I can't understand what was holding this piece in as the other side of the brass piece has pump pressure on it (heat exchanger side), perhaps it was some type of adhesive). anyway does anyone know whether this can be replace or does the whole manifold have to be replaced?
    Top Expert:
  • Jandy Master
  • 5,056 Answers
Need new header
Posted on Jan 30, 2016
3 Suggested Answers
  • 760 Answers
SOURCE: My Jandy Laars LX 400,000 BTU heater flashes "low pressure"
Once you try to ignite three times in succession, and the heater doesn't sense the presence of flame, the heater goes into "lockout" mode and must be reset to fire. This can be done by pressing and releasing the mode button so that the heater is turned off then returned to the desired mode. So if you were going to "jumper" the pressure switch, (connecting two wires together) make sure you do the reset also. Make sure you don't operate like this, if your pump quit, you could have a melt down. Also If you have anything connected to the fireman switch, it is in series with the pressure switch,and woud display the same thing. There is a terminal with two white wires, if there is a jumper there, then nothing conected, but if there is something connected, make sure it is closed. Also be sure your code was for Water pressure and not air pressure switch. You can download manuals at: www.jandy.com
Posted on Jul 27, 2010
  • 19 Answers
SOURCE: My jandy LT heater leaks water out of the
I have the 250000BTU version but I believe they are the same in this regard.
It is far more likely to be simply that the low pressure detection copper line sprung a leak or is loose and perhaps dripping onto the limit switches. In and around the same area as the 2 hi-limit plugs is a small flexible copper tube (like for a refrigerator water line). Check that connection for a leak. The other end of that pipe is in the wire chase above the front panel. If you need directions on how to open either panels just ask.
Posted on Sep 20, 2010
Jandy Lars LT fans doe not turn on and error flashes hi limit
check safety circuit and see if high limits are corroded also see if fusible links are tripped
Nov 27, 2013 | Jandy Laars LX Pool Heater / 400,000 BTU /...
How do u remove hi limit switch from a Jandy LX 400N-L heater model#LX400N-L
high limits are located at header where pipes go in underneath
if those are ok check fusible link maybe 2 one at bottom one at top under top cover
Aug 15, 2013 | Jandy Laars LX Pool Heater / 400,000 BTU /...
High limit service light
check to see if high limits are ok also check fusible links then check gas pressure if too low heater will overheat
Sep 19, 2012 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Jandy LAARS LT pool heater blows out the fusible link. What could be the cause?
check for a heater that is leaking current to the water jacket and this would be a ground and if enough current leaks to ground it will open this link you can check this by undoing the heater,then if its ok then you know its the heater or by checking with an ohmmeter
Mar 23, 2011 | Jandy Laars Lt 400,000 Btu Heater
Laars LT - "red" light
means calling for heat if heater doesn't come on check safety circuits
Feb 12, 2011 | Jandy Laars LX Pool Heater / 400,000 BTU /...
My jandy lxi say's fault high limit switch..is there a test or bypass i can try
Yes you can jump past the limit switches one at a time. That will tell you which one is bad. Then you will need to replace it.
Sep 26, 2010 | Jandy Laars LX Pool Heater / 400,000 BTU /...
My jandy LT heater leaks water out of the HI-LIMIT 150 degree plug/switch, behind that there is two screws. Both screws are tight ? what do I look for next ? clueless .. Thanks Dave
Aug 09, 2010 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Noticed water leaking a lot from bottom of unit. Looked like a pretty good leak. Unit is 9 years old. Leaks when Pump is running
More than likely the heat exchanger. Has the pH and Total Alkalinity been low? Check the Pressure/Temp relief valve, thermostat probe, high limit switches, etc. first though...
Jun 12, 2010 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Where is the hi temp limit switch located?
where is the high temp limit switch located on my laars 44000 pool heater
Jun 02, 2010 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Jandy Laars Lt 250,000 Btu Heater Logo
313 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
