Question about Kitchen Appliances - Others
My bread man tr440 wont release the bread pan Is there a way to get it out when its stuck
4 Suggested Answers
Noggin
  • 944 Answers
SOURCE: Blades stuck inside bread
Unfortunately trying to stick the paddles in the pan just tends to leave half the loaf in the bottom with them. The best method i have found is to cut the crust around the outside of the paddles, carefully avoiding the bit where the actual paddle blade is, then you insert a rod into the centre of the paddle and tilt it towards the blade. They normally come free pretty easily. Another method you can use if you are around the machine when it is making bread, is to remove the paddles at the end of the mixing/kneading cycle, just before the baking cycle starts. Most machines have a small pause allowing you to do this - sometimes with a "beep" or screen message to tell you that you can do this. Sorry i couldn't find the exact info for your model, it will vary for different baking programs also. If you check the cycle to determine at which stage it starts actually baking, then you can do this quite safely so long as you are careful of the machine heating up while you are removing the paddles - usually you would have around 20 minutes at least to remove the paddles before baking. Hope this helps :)
Posted on Apr 20, 2007
  • 11 Answers
SOURCE: Bread sticks to pan
May be that the coating on the pan is just wearing off. Had the same problem several years ago and it was just that the poor old machine was over used and the simplest solution was to buy a new pan. That machine went though 2 of them before it died its self.
- Neil
Posted on May 25, 2008
SOURCE: pan is stuck in my cuisinart cbk-200 breadmaker.
Just pull it.
I had the same problem few moments ago until I read someone's answer.
It really worked and it won't brake.
Posted on Dec 25, 2009
I cannot get my bread pan out of the bread maker, no matter how I try to lift it! The instructions say to tilt it to the left and then pull- which did not work then I followed the suggestion of lifting it...
Most bread machines are held in by 2 little spring clips...one on each side.
They are under tension when the pan is in the oven and that is how it stays stable when kneading is taking place. So to get it out you have to release that tension and that is going take what I call the stern "pop". Grab the handle of the pan right in the center with both hands and put a little slack in it by lowering the handle down about an inch and then "pop" it straight up the little clips will release ther hold on your pan......magic!!
Sep 11, 2011 | Cuisinart CBK-200 Bread Maker
Bread pan stuck-brand new machine Model CBK200WS
They are under tension when the pan is in the oven and that is how it stays stable when kneading is taking place. So to get it out you have to release that tension and that is going take what I call the little "pop". Grab the handle of the pan right in the center with both hands and put a little slack in it by lowering the handle down about an inch and then "pop" it straight up the little clips will release ther hold on your pan......magic!!
Apr 18, 2011 | Cuisinart CBK-200 Bread Maker
The bread pan is stuck in machine at the bottom. How can it be removed?
Feb 23, 2011 | Cuisinart CBK-200 Bread Maker
My tr440 will time, rise and bake, but not mix/knead. I think it is the motor switch and am trying to find a replacement switch. Where can I find one?
Try a couple of things first. 1) take the bread pan out of the machine and put the paddle in it. If you can turn the paddle by hand then this is good. If you can't turn it by hand then the sealed bearing is frozen. Try filling the pan with warm water to try and free it. If you can't then bread pan needs to be replaced. 2) Take the bread pan out of the machine and start a kneading cycle. Look through the window on the lid and see if the motor spindle shaft is turning. If not then the motor is bad or the belt snapped or fell off the pulley.
Just trying to help! Happy Holidays...Hank
Nov 25, 2009 | Kitchen Appliances - Others
Need a Breadman TR440 paddle
Put this number (390128697545) into an ebay search and it will pull one up. Please be advised this will fit the TR440 but will Not fir the TR440C. They are different. If you need the C model, that same seller has the TR440C paddle in another listing.
Oct 06, 2009 | Breadman TR2200C Ultimate Bread Maker
Lost manual chefmate tr440
You can get one here. There is a $1.85 charge for the whole manual but you get the manual instantly. Hope this helps.
http://www.scribd.com/doc/18027869/Chefmate-Bakery-Oven-Model-TR440-Instruction-Manual-Recipes-TR-440
Aug 15, 2009 | Chefmate TR 7000 Bread Maker
Chefmate Automatic Bread Maker TR 440
I have the manual, found your note because I need a new pan (non-stick surface now sticks). Anyway, I could send you copies if you can't find the manual - for Chefmate TR440, printed 8/95.
Dec 10, 2008 | Chefmate TR 7000 Bread Maker
Can't remove the bread pan
The same thing happened to me yesterday. I made my first loaf and then I couldn't get the bread pan out. We kept pulling and yanking on the bread pan until it felt like it was going to break! This morning, my husband called Cuisinart. The man on the phone said he has the same machine at home, and that you just have to pull it really hard. He said don't worry, it won't break, just pull it. My husband pulled it again and it came out. I guess he just got the right angle on it.
It was definitely stuck from the bottom, not from the side clamp things. The man on the phone at Cuisinart said that after you use it more, it becomes easier to remove the bread pan. We put the bread pan in and then pulled it out a few times, and it seems like now it comes out easily, the way it should.
I felt obliged to respond here, because I was very discouraged after reading this thread last night. I was about to return the machine. I hope this solution helps.
By the way, my first loaf yesterday was the Rosemary Bread from the cookbook that comes with the machine. It was AMAZING.
Sep 10, 2008 | Cuisinart CBK-200 Bread Maker
Kitchen Appliances - Others Logo
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
