Question about Marvel 30WC Wine Cooler
Best operating tempurature
What is the best temperature to run the cooler
Adding freon to a commercial beverage air mm14ge cooler
If it needs gas it has a leak. These coolers generally don't come with gauge access ports and need to be silver brazed into place. These systems have a critical charge and will not operate right unless the exact ounces of refrigerant are in the system. The temperature controls measure coil temperature instead of cabinet temperature. The wrong charge makes them run and run and they cant control temperature. Hope this helped.
May 25, 2014 | Beverage-Air Refrigerators
Compressor problems
probably a bad discharge temp sensor or a bad thermo valve which is really a thermostat you need to take the temperature of the running unit when it is running best way is to use a inferred temp gun at the discharge of the pump or watch you temp guage if it jumps around or is erratic the sensor is bad .compressor usually will shut off on high temp at 230f
Mar 11, 2014 | Air Tools & Compressors
Transmission fuild in radator
Replace the radiator as the oil cooler in the radiator is split allowing transmission oil to get into the radiator. Best option is to use an air cooled transmission cooler mounted before the radiator. Cools the transmission to below ambient temperature ( not engine temperature) , helps the engine to run cooler ( no heat from the transmission) and no risk of oil in the coolant system. The cost of the system will be close to the price of a new radiator
Nov 29, 2013 | 2000 Dodge Grand Caravan
Runs hot low power
Hi Anonymous, and the usual suspects are:
1. Insufficient oil supply or oil not circulating.
2. Leaking valves.
3. Heavy carbon deposit in combustion chamber.
4. Ignition timing retarded.
5. Normal engine oil tempurature 180-220 degrees.
6. No oil cooler.
Good luck
Aug 29, 2013 | 2008 Harley Davidson FLHX Street Glide
My 2003 kia spectra comes up with P116 and P128 error messages. What do I need
p0116 is-- engine coolant tempurature ckt/range performance----- p0 128 is--coolant temp below thermostat regulating temperature. to fix these 2 codes are similar, change coolant tempurature sensor and thermotat all should be ok. make sure coolant in radiater is full. hope this helps you.
A code P0128 may mean that one or more of the following has happened:
  • Low engine coolant level
  • Leaking or stuck open thermostat
  • Faulty cooling fan (running too much)
  • Faulty coolant temperature (ECT) sensor
  • Faulty intake air temperature (IAT) sensor
Feb 07, 2011 | 2003 Kia Spectra
Is it possible to program my 99 lincoln continental to run at a cooler temperature?i just want it to get barely hot enuff to blow warm air
Depends on where you are ... You can not make it run cooler ... what you might do is remove the thermostat which will let the water circulate all the time which might be a little cooler. BUT - If you do this, you will toss out the profile your car uses to run at its best economical and polution free settings. It will cost you more to operate and it will not run as good.
Please dont do it ...
Thanks for your visit today.
Jan 12, 2011 | Vehicle Parts & Accessories
My son was burndt with the scalding hot water that comes out, 3rd degree took his skin right off his legs and feet and ankles, had to go to hospital, there is no tempurature gage on cooler , what is my...
There may be a thermostat to adjust the water temperature; look for it in the back.You can disable the heater by disconnecting the heating element.. Just use the cold water
Dec 16, 2010 | Refrigerators
What oil is best for a 2007 suzuki boulevard?
Use only JASO MA rated oil. Either 10w-40 or 20w-50 depending on temperature.Do not use any oil with Energy Conserving on the label it will shorten the wet clutch and gear life. Consider using synthetic oil your bike will run smoother,cooler, and shift easier. Also synthetic Hypoid gear oil will make your final drive run cooler also.
May 12, 2010 | Motorcycles
Water temperature rising cooling fan not coming on
You need to check the thermal switch for the fan which is located on the radiator or on the intake manifolds. If the switch works fine when it reaches operating tempuratures, then you need to temporarily hot wire the fan by bypassing the thermal switch to see if the fan runs.
Dec 11, 2009 | 1999 Nissan Quest
Marvel 30WC Wine Cooler Logo
29 people viewed this question
Top Marvel Furniture Experts
Sal DeAngelo
Joseph Hoffmann
Shehu Pro
Shehu Pro
Are you a Marvel Furniture Expert? Answer questions, earn points and help others
