How to connect 4ife smart stick to tv - Computers & Internet
Network issues with Samsung Smart TV UN60JU6500FXZA
You mention two separate issues, WiFi and smart hub. As you know Samsung built in manual is the worst idea ever. There is no picture of the complete rear panel connection for example.
If the smart hub is the actual WiFi antenna then if your system doesn't recognize Smart Hub then you have a bad smart hub.
to test smart hub plug something into hub ( DVD HDMI, video game) If your remote has smart hub button press and see what appears. Otherwise select source on remote see if your attached item appears. (That would indicate smart hub does talk to TV)!
Since you can access your network when hard wired your network password is stored.
Once you have verified Smart Hub is functional then work on WiFi.
i will say my Samsung is 3 ft from my router and hard wired for better streaming speed.
I use Bluetooth access to share photos from IPads.
I would leave TV hard wired.
Sep 20, 2016 | Samsung Televison & Video
Hi, I purchased a firetvstick but it does not respond after plugged into my smart tv. help
Check list:
1) Do you have your fire stick powered?
Connected via usb cable to a power adapter
plugged into a power strip that has the power on,
power switch is off....so on.
2) Do you have your TV input set to the correct HDMI input?
Depending on the model you may have 2 to 4 HDMI inputs.
This is the most common error.
Please make sure the input is set to the correct input
of where your fire stick is plugged in to.
3) If you have power and the input in your TV is set.
And you still have nothing.
Then your firestick might be defective.
4) If it is working, read the instructions carefully.
connect your fire stick to your wi fi and register your fire stick.
Then enjoy!!
Aug 30, 2016 | Amazon Fire TV Stick
I have an old tv with comcast cable. I want to switch to a smart tv that has only been used with netflix. how do i connect smart tv to my comcast cable
Adding a smart tv just requires adding an ethernet cable to your internet connection to the ethernet port on the set. The smart services on the set us a broadband internet connection to work.
Jun 18, 2016 | Vizio 42 in. LCD TV
How to activate ROKU STREAMING stick with SAMSUNG SMART TV
Here are some websites you can use:
There's a Better Way to Build a Smart TV ' The Official Roku Blog
https://blog.roku.com > blog > 2012/01/04
Jan 4, 2012 - Imagine Smart TVs with "Roku Inside" delivered via a replaceable Streaming Stick. Insignia will be ...
Roku Streaming Stick Review: A $50 Wonder and Your TV's New ...
gizmodo.com > roku-streaming-stick-rev...
Mar 28, 2014 - Roku's New HDMI Streaming Stick: $50 and More Than ... So you want to stream stuff to your TV. ... From there, you pretty much just go to the activation pages for .... , molasses-slowSamsung Smart TV interface ...
Dec 04, 2015 | Roku Streaming Stick
What special equipment do I need to watch Netflix
All you need is a computer and a connection to the internet and you can watch it directly on Netflix.com. In addition you can download the free Netflix app onto your smart TV, game console, streaming player, phone or tablet.
If what you are really asking is how do you watch it on your digital TV (not smart TV) then you will need a wireless home network and a streaming internet player such as Amazon Stick, Roku or Chromecast. Your digital TV will need an HDMI input connection. Most players are also powered through a USB port so it would be helpful to have a USB port on the TV but it can be powered with a transformer at a normal AC plugin.
Mar 10, 2015 | Netflix
How do i connect my wireless Internet router to my proscan Smart TV
Go into settings on your tv & activate the wireless mode
Feb 11, 2015 | Computers & Internet
Can I add a roku streaming stick to my samsung mod hl61a650
Yes you can the streaming stick uses HDMI and usb for power.
Jan 27, 2015 | Roku Streaming Stick
Can I hook up a rabbit tv to my smart tv
I think the only way it works with a smart TV is if you have it on your laptop and connect wirelessly or through HDMI cord. You're not actually able to (as far as I'm aware) stick their USB in the back of the TV. But they are working on new devices this year like a set top box, similar to the chromecast and Roku.
Jan 07, 2015 | Televison & Video
What do I need to do in order to connect the Roku streaming stick to the internet?
Why do you need a roku if you have a smart TV?
Anyways, if you plug the connector into the TV via your HDMI port, it should power on. switch your tv to that input, and then use the remote to scroll through the setup options and find your wifi and set it up. it is a farily simple process
Jul 28, 2014 | Roku Streaming Stick
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
