Question about Whirlpool duet Washing Machines
Whirlpool Duet turn sound off - duet Whirlpool Washing Machines
Whirlpool duet wfw9640xw00 won't turn on
my whirlpool aquasetam washer get fault code f23?
Apr 01, 2012 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet washer make a loud banging sound during spin - louder when it goes into super spin
It sounds like the spider or support arms that hold the wash drum have failed and the drum is hitting the wash tub when it is spinning. Try spinning the inner drum by hand and listen for any thumping sounds as it turns. Also examine how it turns, if you notice that is wobbles as it turns, it also means that the supports are failing.
It can be fixed but it might be expensive. Get a few estimates before deciding to repair or replace. Hope this helps you.
Dec 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool duet front load mod#wfw8300sw00 washer and it makes a horrible sound when spinning almost a grinding sound is it done? or could it be something minor?
i have wfw8300sw00 whirlpool duet sport, i start de machine it's turn ons side (right to left) and abour 3 minutes it stop off no message.
Apr 29, 2010 | Whirlpool WFW8300SW
Whirlpool duet washer, inner stainless drum rubs
This sounds like a worn bearing housing or the bearing itself has packed up,either way you would have to strip and check these and replace what is broken
Dec 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet f28 code
Turn off the power. Remove the detergent tray. Reach in the slot where the detergent tray fits and look for a lever. Pull it and replace the detergent tray. Turn power on. Good luck.
Oct 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Gurgling sound from Whirlpool Duet washer when not in use
Check your drain line. You may have a siphoning condition. The following link explains:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
If you have the water source turned off, the only other way water gets into the washer is through the drainage system. If you do not have the proper air gap or placement on the drain line, it can create a vacuum and allow water to siphon back into the washer.
NOTE: Some residual water in the drain line is normal.
If you have any questions, please let me know. I hope this helps you.
Oct 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Duet Washing machine... Sounds like metal loose
you will have to lvel the machine,cause when its not balanced it will do that,so under the machine there are 4 plastic that hold machine u can turn each one which way u need and make sure its leveled
Sep 13, 2009 | Whirlpool GHW9150 Duet Washer
Whirlpool duet electric dryer - drum turns; no heat
Turn off the breaker and check the heating element.
for more help go to live chat.
hope this helps
len west
Jan 30, 2009 | Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super...
Whirlpool Duet washer fills with water by itself
sounds like a faulty water inlet valve, not seating properly after closing the valve.replacing the valve is the only solution to this problem, in the meantime you can turn off your water supply in between doing loads.
not a bad habit to get into!!!!
Mar 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
116 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
