Question about Sony Televison & Video
Sony v333es remote control code
Remote control
038,028,057,014 are the common setup codes for Sony television. If you want to get more details about setup codes and setup proceedings to different other brand remote controls, check this link. Look for codes to Sony. In most of the remote controls will have setup codes for Sony. Before selecting a remote control, check the digit number of code that your Sony Tv accepts. some of them accecpt 3-digits codes, others accept 4 digit, 5 digit and so on. You can get details to all by this site. Search it patiently.
Feb 25, 2013 | Sony KLV-S32A10 32 in. HD-Ready LCD...
Mediacom 1056B03 remote control code to program a sony blu ray player
Thanks! Code 1516 worked to program my sony bdp :)
Feb 11, 2013 | Televison & Video
Lg tv code for sony RM-V310A
Remote control codes to check with LG TVs are : 0004 0050 0009 0005 0227 0338 0012 0057 0080 0156. If you wish to get more setup codes to different other brands of remote controls, check this link.
Feb 02, 2013 | Sony RM-V310 Remote Control
Lost remote for sony model KV13M20
You can buy its original remote control from the any authorized service center for sony. If you wish buy one universal remote control, check the following codes is listed with its code list. Code list will be accompanied to every universal remote control. Setup codes codes for Sony brand TVs with GE universal remote control are; 0128 0013 0002 0071 0380. If you wish to know more codes and details to other brand remote controls, check these sites.
Jan 24, 2013 | Sony KV-13M20 13" TV
Can not get the directv universal remote to work with my older
I can help you with your Sony TV & DirecTV remote control.
This is a list of all the Sony TV control codes for DIrecTV remote controls:
10000, 10810, 10010, 10011,
10080, 10111, 10834, 11317,
11685, 11904, 11925, & 10505.
There are so many codes to try for Sony TVs and DirecTV, you might want to go ahead and do a DirecTV Remote Control Code Search.
I hope that helps.
_________________________________________
DirecTV Remote Control Code List Download
DirecTV Remote Control Manual Download
DirecTV Remote Control Code Entry
DirecTV Remote Control Onscreen Setup
May 26, 2010 | Emerson EWF2703 27" TV
Program sony remote to operate dish vip722
The Sony RM-YD029 Remote control will work with the Dish Network VIP722 DVR HD Satellite Receiver, but the Dish Network VIP722's Primary remote address must be set to 1.
The procedure below will allow Sony RM-YD029 remote control to operate Dish VIP722.
Using the Dish Network Remote Control -
1. Press menu 2 times to get to system info page
2. In the system info page the primary remote address is in a white box (bubble) followed by a Green TV (1)symbol that says IR and indicates you the channel your remote control one is configured. The Sony RM-YD029 will work when this primary remote address number (in the white box) is set to 1.
If the Primary Remote Address of your VIP722 Remote control 1 is not set to channel 1, here is how to change it:
1. While displaying the system info page, press and hold the SAT button on your dish network remote until all other modes are flashing, about 3 seconds.
2. then press the '1' button on the numeric pad of your dish remote
3. then press the '#' button on the numeric pad of the dish remote
4. then press the 'record' button (red dot button - stores setting)
5. At this point you should see a number 1 in front of the primary remote address on the dish system info page
Ensure you enter the corresponding IR code into your Sony remote control per the instructions in the manual or Sony's web site. My 722 works with Sony IR code - 01775.
Sep 08, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
NEED CODE FOR SETTING GE UNIVERSAL REMOTE FOR SONY TV
I HAVE A GE UNIVERSAL REMOTE AND I NEED THE CODE TO PROGRAM A SONY TV
May 10, 2009 | Universal Remote Control GE174Universal...
My sony v333es say protection panel power off
Follow the steps below to troubleshoot if the word PROTECT or PROTECTOR is flashing on the A/V receivers display.
  1. Check the speaker wires and speakers for proper connections.
  2. Reduce the volume level. IMPORTANT: If the receiver is played back at maximum volume level it may enter the protect mode. Maximum volume listening will cause the receiver to run very hot and may drain the output capacitors.
  3. Disable the surround sound option if both the A and B speakers are being used simultaneously.
  4. Ensure the top of the receiver has proper ventilation to keep it from overheating.
  5. If the message only occurs when using a DVD player, the sampling frequency may be set too high. IMPORTANT: Some receivers provide compatibility with the higher sampling frequencies through alternate connections. Consult the owners manual for specific information.
  6. Unplug the AC power cord for about 1 to 2 hours to reset the output transformers.
If the issue is still unresolved, service may be required. The Sony® eService Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer.
Dec 03, 2008 | Sony STR-V333ES 5.1 Channels Receiver
Sony STR-V333ES repeatedly clicks when i try to power it up. is there an internal fuse???
You most likely have a short in one of your speaker wires (+ and - are touching somewhere) causing the receiver to enter a protect mode "Click!". Disconnect all speaker wires then connect and test each one at a time to find the culprit. I've seen this happen with speaker wire or a subwoofer cable that is too small of a gauge. Hope that helps.
Feb 19, 2008 | Sony STR-V333ES 5.1 Channels Receiver
Televison & Video Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
