Question about Magellan Meridian Gold GPS Receiver
Four wires inside my Meridain Gold have came loose I need to know where they go on the board.
If you're talking about the multi-colored wires that connect to the board:
E - blue
G - white
T - orange
R - yellow
You'll probably have to do some soldering.
Posted on Jun 03, 2009
  • 30 Answers
No the problem has not been fixed. I thought you would let me know if you knew how to fix it but all you want is money sorry not biting. now blocking you as JUNK MAIL.
Posted on May 18, 2009
Acer Predator G3620 beeps four times when started. Screen no signal, keyboard and mouse no lights. ? Anyone knows please ?
Four beeps indicates that something isn't right inside the case. It may be as simple as the video board coming unplugged or something like that. It may be that the memory card has come out, I think that may be the beeps are saying. Open the case and check for loose stuff.
Oct 13, 2015 | Acer Computers & Internet
When both single lines are plugged into the splitter and then into port 1/2 the lines do not work. If I unplug one of the lines from the splitter line 1 will work.
Hi Amy,
I have two of these phones. The feature set is really good. The only thing missing is a "Voice Mail" indicator light. You have to pick up the line and listen for the intermittent dial tone.
The other problem is that they are not very reliable. Both of my originals developed problems with the answering machine portion, but were replaced under warranty. Have had issues with one of the replacements also and now use it with an external two-line answering machine.
Regarding your problem, there are a few possibilities. Not all phone cords are created equal. The cord that goes from the wall to the phone uses a plug/jack called RJ-11. An RJ-11 connector has room for four contacts. The contacts themselves are just gold-plated wires.
Take a very close look at all of the cords you are using, as there are two different types that look nearly identical. A single line cord will only have two wires inside, and the RJ-11 connector will only have the two center pins filled with the gold contacts. A two-line cord has four wires and the RJ-11 connectors will have four gold contacts at each end.
Once you are sure that your cords are all two-line (four gold contacts on the RJ-11 connectors), the next thing is to understand how two different lines are put into one cord.
The first (main) line will occupy the two center contacts. To add a second line, they need to connect to the two outer contacts. It may be that you need to re-wire the wall jack on one of the lines.
If they are both wired to the two center contacts, the splitter cannot do its job. The way to tell this is to make sure that each wall receptacle will give a dial tone when plugged into a single line telephone. If that is the case you will need to re-wire one of the wall outlets.
You would need to remove the wires from the center two slots on one line and insert them into the outer two slots. Take a look at what you have with regards to cords and the results of your tests with a single line phone. If you need to rewire a wall outlet, I can walk you through that.
Apr 27, 2015 | Office Equipment & Supplies
Four prong cord three prong outlet
Ok this is how you will wire the three prong to the dryer.
You have 2 wires that are gold/brass in color, those are the hot wires.
You have 1 wire that is crome/silver in color, that is the neutral
On back of fryer where you wire it you put the wires on like this right to left Gold/brass hot, silver/nuetral, then the other hot wire.
On back of dryer you will have screws from right to left this color gold/brass, silver/crome, then gold/brass again.
If you do have a 4 wire cord the extra wire is ground and you screw that to the machine body.
Mar 14, 2010 | Roper RGS7646KQ Gas Dryer
I recieved a ds lite with water damage and the four odd wires on my ds lite motherboard all come off does any one have a diagram of where the wires might go thanks please help
from the tom screen there should only be 2 wires 1 black and 1 white. The white wire is the mic that plugs straight onto the board, and the black wire which plugs onto the wirless insert which attaches onto the board. the other 2 wires could be loose speaker wires if there is another black and a red wire, other than that could you explain a bit further what the wires actually look like.
Jan 16, 2010 | Nintendo DS Lite Console
Ricoh Aficio 2018D
This could be a very bad code its "main motor lock", either you have too much load on the drive unit ( paper stuck, locked up pcu or fuser ) and maybe bad BICU board.
-Carl, please let me know if this helps.
Jun 26, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
Tote n Go laptop, mouse click not recognized
It is very likely one of the wires came loose inside the mouse itself. There are 4 black foot pads on the bottom of the mouse. With the batteries removed, pry off the four feet and remove those four screws. You will see two tiny brown wires that correspond to the mouse button.
Examine these two smaller brown wires and ensure they are not loose or have become disconnected from the small computer chip inside. The two smaller brown wires are on the interior of the chip and should be soldered to the board, opposite a larger brown wire and a larger white wire. The two larger wires, brown and white go back into the main cable that connects inside the laptop.
If these four wires appear to be intact, the next step would be to remove the two larger screws in the central blue piece with two larger holes on either side. This will release the mouse from the base. Examine the two solder points where the two brown wires are connected for any breaks. If these look good, there are two more screws that hold this chip in place. remove them and examine the button of the mouse.
Many others have found the actual push button under the mouse fails. This blog entry explains how he fixed the mouse button: fangletronics.blogspot.com
If you need further help, send a request to: kjhenseler [at] gmail [dot] com
Jun 18, 2009 | Vtech Tote n Go Laptop Plus
Wont power up
This may help. I have had the same problem from time to time. I took the back off ( slowly don't break the four wires connected to the back) then I cleaned the connections where the battery pins press to the main board.
Jun 12, 2009 | Magellan Meridian Gold GPS Receiver
Mouse stopped working
My daughter's Vtec laptop had the same problem. The black wire in the base of the mouse had broken off and had to be re soldered. To open the mouse pad remove the four rubber feet under the mouse pad. Use a small screwdriver to remove the four small screws and then lift off the cover. Check all the wires to see if any are loose or broken. There are two small circuit boards inside. The black wire I mentioned connects to the smallest circuit board and the solder connection is on the underside of the board.
Dec 27, 2008 | Vtech Tote n Go Laptop Plus
No serial output suddenly from my Gold
If i remember right you can test the GPS units serial port at power up.
1. Press and Hold "OUT" button then press "PWR"
2. Follow units onscreen directions.
you may need to have serial cable connected to COM port to verify transmission
good luck
Oct 10, 2008 | Magellan Meridian Gold GPS Receiver
Capacitor locations
yes all wires need to be removed that run from the metal encased chassis the four boards that have bad caps are all located in that metal encased chassis. The FMT, DM, Singal and Power PCBs
Jun 23, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Magellan Meridian Gold GPS Receiver Logo
111 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
