Question about Cameras
Vivitar Travel Scanner Pro
How do you open scanner to insert battery?
SOURCE: mustek a3 usb 1200 pro scanner problem
I bought one a couple of years ago. After plenty of hit-miss after trying to get it to work on my fresh XP installations, I have a solution. Installing it the normal way simply doesn't work.
First, go to 'start', 'control panel' then 'system'. Click the 'hardware tab' then press 'device manager'. You'll see a list of hardware.
If your scanner is already plugged in, find it (it could be listed under 'imaging' or under 'other devices'. You should see a yellow exclamation point indicating it's there but not working.
If you go to 'control panel... system' first, and then plug in your scanner, it will pop up automatically.
Now, right click on it, select 'update driver'. A window pops up. Insert the CD, then select 'have disk' and install normally.
Installing the remaining software is optional (acrobat 4.05 and so on)
I've used the "Panel" to scan my pics. Working like a charm.
Posted on Mar 02, 2008
SOURCE: realistic pro 2010 scanner
to program
turn on unit, press program button, key in frequency ###.### press enter. keep advancing thru the channels with the program button until finished
Posted on Aug 03, 2008
smartr10U
  • 1305 Answers
SOURCE: PRO-60 RADIO SHACK SCANNER
Here is the lin to the manual download... CLICK HERE
Posted on May 31, 2009
BillB-SA
  • 2761 Answers
SOURCE: programming pro 106 scanner
Your scanner covers conventional frequencies as well as a variety of trunking systems. Programming steps can be detailed, and they vary according to the system being worked, so it's not practical to attempt a full programming tutorial in this short response. Your best bet is to review the operating manual for the scanner, and then follow the steps for the system(s) that you want to program. If you run into a specific problem, let us know and we'll do our best to work through it with you.
Need the manual? You can download/print it here:
http://www.radioshack.com/graphics/uc/rsk/Support/ProductManuals/2000106_PM_EN.pdf
For a comprehensive database of active frequencies and systems in your area, visit:
www.RadioReference.com
Posted on Dec 24, 2009
  • 13 Answers
SOURCE: clearing out old channels on a radio shack pro 95 scanner
Turn it on, and when "Welcome" appears, press zero, then press one. It will display a message indicating it is initializing to the factory state.
Posted on May 08, 2010
How to save applications on SD memory card
<p>You can 'root' your phone, using the Superuser. After it use the application "app2sd" or "link2sd" to move it<br>
please visit my site!!!<br>
<a href="http://inovapos.com" title="Program Kasir, Software Kasir, Aplikasi Kasir, Software Pos" rel="nofollow">Program Kasir, Software Kasir, Aplikasi Kasir, Software Pos</a><span></span><br>
<a href="http://cintarasultravel.com" title="Travel, Travel Haji, Travel Umroh, Travel Umroh Murah" rel="nofollow">Travel, Travel Haji, Travel Umroh, Travel Umroh Murah</a><span></span><br>
<a href="http://lapakbarcode.com" title="Jual Barcode Murah, Jual Barcode Jakarta, Barcode Scanner, Barcode Scanner Murah, Barcode Scanner Jakarta, Barcode Scanner Murah Jakarta" rel="nofollow" target="_blank">Jual Barcode Murah, Jual Barcode Jakarta, Barcode Scanner, Barcode Scanner Murah, Barcode Scanner Jakarta, Barcode Scanner Murah Jakarta</a><span></span><br>
Thank You!</p>
Nov 29, 2016 | Cell Phones
It is for a 2004 trailblazer
<p>Hmmm I feel i know it, maybe i'll share it to my friends :)<br>
Thank You!</p>
Nov 29, 2016 | Cars & Trucks
Scanner stuck at 000.0000 keys don't work
You may benefit by performing a reset or initialization of the scanner. The manual describes the procedure at the bottom of page 38.
You may lose previously stored frequencies if you reset or initialize the radio.
RESET
1. Turn off the scanner, then turn
it on again.
2. Insert a pointed object, such
as a straightened paper clip,
into the reset opening on the
side of the scanner. Then
gently press the reset button
inside the opening.
Initialize
it on again.
2. Hold down TUNE/CLEAR.
3. While holding down TUNE/
CLEAR, insert a pointed object
(such as a straightened paper
clip) into the reset opening on
the side of the scanner, then
inside the opening. The
display should turn off.
4. When the display turns on
again, release TUNE/CLEAR.
I hope this helps & good luck!
Feb 04, 2013 | Radio Shack Pro-82 200 Channel...
Need code for a memorex
Setup codes for Memorex TV are
0004 0009 0049 0051 0135 0031 0000 0268 0310 0001
Apr 25, 2012 | One For All URC-3300 Remote Control
My Radio Shack Pro-82 Scanner batt. went dead , now I have no sound
That means you have to put new batteries in your scanner... or recharge your rechargable batteries but if you use rechargable batteries use your yellow battery cradle for rechargeable batteries and your black cradle for alakline batteries....foe pro 82...
Feb 28, 2011 | Radio Shack Pro-82 Scanner
How to re-set to original programming ?
To RESET your PRO-2096:
- Power the scanner OFF.
- Power the scanner back ON.
- Insert a pointed object (paper clip end, ballpoint tip, etc.) into the RESET opening on the back of the scanner and gently press the button inside.
If the RESET does not clear your problems you may need to INITIALIZE the scanner. Instructions for this procedure are on page 77 of the scanner operating manual. If you need a copy of the manual, you can download and print it, at no cost, here:
http://support.radioshack.com/manuals/ome20-496.pdf
Bill B.
Listening in since the 60's
Jan 25, 2011 | Radio Shack Pro-2096 Base Scanner
I cleared my pro-82 scanner. Program button is not working to let me reprogram. Help.
As long as all frequencies have been cleared, try initializing the scanner. This will return everything to the original factory settings.
To INITIALIZE:
- Turn the scanner OFF, then switch it back ON.
- Hold down the TUNE/CLEAR button.
- While continuing to hold the TUNE/CLEAR button down, insert a pointed object such as a paperclip or the tip of a pen into the RESET opening on the side of the scanner, and press the RESET button inside the opening. The display should go blank.
- When the display comes back on, press the TUNE/CLEAR button again. The scanner should now be ready to accept programming.
Need the manual for your scanner? You can download/print it here:
http://support.radioshack.com/support_electronics/doc69/69887.pdf
For a comprehensive database of active frequencies in your area, visit:
Bill B
May 08, 2010 | Radio Shack Pro-82 Scanner
I have had my pro-95 for 8 years with no problems...now the trunking will not work...please advise
Your scanner may have had a logic "hiccup" for any one of many reasons, and a simple RESET may restore the trunking function.
RESET (will not wipe out frequencies or other programmed data):
- Turn the scanner OFF, and then then ON again.
- Insert a pointed object (paper clip, pen point, etc.) into the RESET opening on the side of the scanner, then gently press and release the RESET button inside the opening.
If the RESET doesn't solve the problem, you may need to INITIALIZ the scanner.
INITIALIZE (this action WILL delete all programmed data)
Welcome To Dual Trunking appears.
- Press 0 then 1 while Welcome to Dual Trunking is displayed. Initializing Please Wait appears for about 2 seconds.
Do not turn off the scanner until the initializing process is complete. When complete M000 will appear on the top line of the display, and Bank 0 Ch 0 will appear on the bottom line.
Hopefully one of these steps will restore the trunking. If not, the scanner may need professional help.
Bill B
Feb 18, 2010 | Radio Shack Pro-95 Handheld Scanner
How do I do a master reset on the pro 83 scanner
To reset the scanner (clear a problem or keyboard lockup):
- Tune the power OFF and then back ON.
- Insert a pointed object (paper clip, ballpoint pen tip, etc) into the RESET opening on the side of the scanner and gently press the button inside.
If the RESET does not clear the problem you can INITIALIZE the scanner, but this procedure will clear/erase all information that you have programmed into the scanner.
- Power the scanner OFF and then ON.
- Press and hold the TUNE/CLEAR button while pressing the reset button as above. The display will momentarily blank.
- When the display resumes, press TUNE/CLEAR again.
BillB
Feb 08, 2010 | Radio Shack Pro-83 Scanner
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
