Question about Yamaha CDC-565 5-Disc CD Changer
YAMAHA CD PLAYER WON'T PLAY
I HAVE A YAMAHA STEREO SYSTEM AT HOME.  RECENTLY WE HAD NEW FLOORING INSTALLED.  THE ENTERTAIMENT CENTER WHERE MY SYSTEM IS HOUSED WAS MOVED AND AFTER THE FLOOR INSTALATION WAS COMPLETED THE UNIT WAS PLACED BACK.  I DISCOVERED THAT THE CD PLAYER DOES NOT PLAY.  WHEN I PLACE CD'S IN THE CARRIAGE THE UNIT CLOSES AND SEEMS LIKE IT DOES  NOT READ THE CD, ACTUALLY IT DOESN'T DO ANYTHING THEN THE UNIT OPENS UP.  WHATS UP WITH MY CD PLAYER.
THANKS GG
GG  My kids had a PlayStation 2 that did this and so did my AIWA 3 CD player.  The solution for the PlayStation was to remove the cover use alcohol and clean the lens of the laser reader.  They get dust on them and simply cannot read.  The AIWA required replacement of the laser which cost almost as much as the unit and didn't last 6 months.
Posted on Oct 22, 2007
I have a Yamaha CD changer 815RS whose door will not open so that I can change the discs.  The discs play and the turntable turns, but I can't open the door to change the discs.  Any suggest- ions?
Posted on Jan 07, 2008
SOURCE:
BMW X5 Rear Entertainment System, center screen, player on center console floor. DVD discs cannot be read. CD's play fine. What is wrong?
A. Did you try a second disk to make sure the disk isn't bad?
B. Is the DVD a new format like HD, 3D or Blu-ray? if so it won't work.
Oct 06, 2014 | 2008 BMW X5
RCA rs2130i won't play MP3 or WMA anymore
first the laser may be dirty. you can find lens cleaning disks at any cd store. But have you recently bought a new pack of cds? Sometimes certain CDs just simply dont work with some players. No reason for it they jsut dont work. You could also be using the wrong type of cd, CD+R vs CD-R
Feb 06, 2012 | RCA RS2130i Shelf System
Why does Burn't Audio CD not play on some CD Players
because the codec's are different, if you have ever burned a avi file and it didnt play till you added say divx ir xivd to get it to play tech leaves out alot of the codec's so there system will work on most but not all cd's dvd's the only way around it is to find out which codec will work for that player to test what I have just told you take the cd to the store and try it on a different mechine and see if it works
Jan 14, 2010 | Teac AD-600 3-Disc CD Changer
Jvc kd-sx770 car stereo--radio works, but cd player doesn't
Hello beeswing70,
The player is recognizing that a CD has been inserted but is not able to read it.
Sometimes the lens assembly becomes contaminated and obscures the laser. I'd try using a commercial "lens cleaning CD" two or three times and then try a CD again. These lens cleaning CD's are widely available. If cleaning does not help, the player need professional service.
Hope this helps.
May 25, 2009 | JVC KD-SX770 CD Player
CD's won't play on Home & Car stereo after Burning
I may add alot of times older equipment has a hard time reading burned cd's because when ever burning cd's the pits that are burnt into the cd are shallow. The faster the cd burns the more shallow it is... one thing you can try to do is burn at 2x in the WAV format cause it most diffenately will not read mp3 format being that old equipment. You may get lucky burning at 2x because the pits that it burns in the cdrom will be deeper. As the clarification said do use CD-R's. If this doesn't work at 2x chances are that equipment is just not going to be able to read a burnt cd period. Good Luck!!! I hope this works for you!!!
Sincerely,
cdixon18
The Man Inside the Machine
May 19, 2009 | Dell Dimension 3100 PC Desktop
CD's play in Media Player but not Home/Car CD player ?
If you are using windows Media Player to burn the cd you have to burn to an audio cd. You can only burn to mp3 cd if your car or home system canread them. Wma audio cannot normally be read by car or home audio. The file format is called WAV
May 14, 2009 | Dell Dimension 3100 PC Desktop
HOME STEREO SYSTEM CD PLAYER
I WOULD LIKE TO KNOW WHY AFTER PAYING WHAT I DID FOR YOUR ENTERTAINMENT CENTER THAT I WOULD HAVE TO PAY FOR THE REPAIR SERVICE PLAN?????? THAT JUST DOESN'T SEEM FAIR AT ALL TO THE CONSUMER. I WOULD LIKE THE EMAIL ADDRESS TO SOMEONE OF SUPVISOR POSITION. THANK YOU
INSTEAD OF CLOSING THE CD LOADER WITH THE OPEN/CLOSE BUTTON SIMPLY CLOSED IT BY CHOOSING THE TRACT NUMBER WANTING TO PLAY. SO FAR IT HAS WORKED. BUT WILL NOT WORK AUTOMATICALLY WILL TRY PROGM. THE REMOTE NEXT SEE IF THERE IS ANY LUCK WITH THAT PART.
THANK YOU
Jul 06, 2008 | Aiwa NSX-A115 Shelf System
Center Channel Audio
There are probably several sound settings on the receiver :
Dolby surround , stereo, theater, SACD etc.
Try another setting other than the one you have
Dec 16, 2007 | Yamaha RX-V661 Receiver
Yamaha CDC-565 5-Disc CD Changer Logo
622 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
