Question about Freezers
Replacing a heating element in the bottom of a fridge freezer
Hi there
I have a 25 year old kelvinator fridge/freezer (upright) side-by-side model no N610FM. The element in the bottom of the freezer has died and I need to replace it (part no PJ297) - I have the part but am unsure what to do - do you know ?
    Guru:
  • 1,524 Answers
Look at the old heater. There should be clips holding it to the evaporator coil. Also follow the wires and disconnect them. You may want to unplug the unit first.
Posted on May 18, 2009
Kelvinator opal upright freezer is over freezing..is there a temperature control somewhere or what could be the problem?
the problem could be the heater element, bimetal, thermostat, fuse.must open freezer cover and check.
Nov 14, 2016 | Kelvinator Freezers
My 20 cubic foot fridge dairy upright freezer has started leaking small puddles of water underneath it is only 3 months old
Contact shop, less than a year old they are responsible for repairs / replacement. Have you read instructions to make sure that you have done all that you should regarding any draining of system thet is required.
Feb 22, 2016 | Freezers
I have a Kelvinator upright freezer model k330uf the bottom section does not work
Sounds like its got blockage.
There is a channel that allows cold air to "fall" into the bottom chamber. There is also a return. Typically the "fall" chamber is choked with either something that fell in and was trapped, frozen solid with ice or algie has grown and closed the hole.
The best thing to do is empty it completely and inspect the drop channel.
Put all your frozen goods in ice chests to keep them from thawing out.
Good Luck.
Jan 08, 2015 | Kelvinator Freezers
Ice on back wall of freezer, food not staying completely frozen
Do you have the complete model number from the tag on the freezer, it should be either on the bottom rail visible with the door open or on the side wall near the front. I am trying to look this up to see if it is an automatic defrost model, if so you may need to do more than just unthaw and adjust
Thanks
Apr 25, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Old Kelvinator Cyclic 340. Freezer is Ice cold
Read the below :-
http://www.fixya.com/support/r3886637-refrigerator_not_cooling_enough_or_not
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 16, 2010 | Kelvinator 12 cu. ft. / 340 liter Chest...
My Kenmore freezer, model #253.9280212 runs but will not cool below 40 degrees. It runs all the time but I do not hear anything cut on and off. The freezer is 10 years old but looks brand new.
The first thing to check is door gasket< bad corners,gap in side,bottom or top. Close door on a dollar bill and try to slide it top to bottom side to side and if it slides fairly easy then seal is not doing good. If you find dirty area clean it off along with the cabinet side as well.If you find the side is leaking then heat gasket with hair dryer and apply vasoline to gasket to help it move freely. If you find tear or hole then replace it.
Apr 22, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kelvinator fridge
The freezer defrosts every day. the puddle is from that. It is supposed to go into a pan at the bottom and evaporate. You need to look at the pan and determine if it has a hole or the drain hose is leaking somewhere.
Feb 09, 2008 | Kelvinator 12 cu. ft. / 340 liter Chest...
Indesit fridge freezer (2 years old) not getting cold
if compressor is running, then you are correct in saying no point in replacing stat. by sounds of it you have a faulty compressor fault or a syatem fault - impossible to dignose by remotely. this is not a diy job i'm afraid
Jul 14, 2007 | Engel Freezer 22 Qt. Fridge/Freezer
Freezers Logo
465 people viewed this question
Top Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
