Question about RCA Televison & Video
Dim screen Replaced lamp screen is barely visible. Have checked brightness and contrast controls and reset to factory no effect.
It sounds like the inverter fault. What lamp are you talking about,
Posted on Dec 26, 2013
  • 1153 Answers
SOURCE: Dark screen since new
Wow only 10 then major work, hum. First if pic is:Split screen picture with one half darker than the other half. "Deep Field Imager" is set to the demo mode, press the "video" button repeatedly to cycle through the video settings until Deep Field Imager is accessed and then change the setting from demo to "on" or "off" depending on preference. Also u can try:1. Dark blue raster with faint movement in the background, suspect the FMT PCB part # 934C153001 . Also1. May be intermittent. Remove and reseat the DVI cable between the Chassis and Optical engine 2. Removing and reseating the DVI cable does not resolve, replace the Optical Engine part # 938P015020 Hope this helps Tom!!
Posted on Aug 22, 2007
Slapnuts1975
  • 51 Answers
SOURCE: strange phosphorous effect
The problem either lies in the Scaler PWB or in the lcd panel itself. How old is the unit?
Posted on Aug 12, 2008
DrewPalmer04
  • 325 Answers
SOURCE: Hitachi 50V710 The picture is dim,
I've seen this in two scenarios.
First: The housing of the bulb is dirty (the lens the bulb lights onto) and the internal screen is dirty also.
The second: The bulb is wired reversely of the proper way to wire it. This will light the bulb, but will not light as bright as when it is wired correctly!
Thank you and please rate!
Posted on Apr 08, 2011
wn3six
SOURCE: the screen on my Audiovox FP1510 has gone dark
Most likely you have a bad INVERTER module, this module supplies high voltage to the baklight assemble which is likely why you can only see a very dim display on your LCD TV. The inverters are relatively cheap. Hope this helps ! Good luck..
Posted on Oct 18, 2011
SD Tech
  • 14553 Answers
SOURCE: Mitsubishi WD- 73737 73 in. Screen if dim or dark. Changed contrast, brightness, and restored default settings but that didn't work. Help?
I am not sure about your model but a call to Mitsubishi to ask if the set has one or two mirrors would offer a possible explanation---the ones with two mirrors have a small one at the bottom--it gets coated with dust and brightness drops up to 75 percent----other possible reason is the lamp may be nearing the end of its life.
I would have Mitsubishi look to see if this model uses the two mirrors--if that is the case cleaning will cure this--if you find it has two mirrors I can tell you what is involved--on Vacation but do look here--let me know what you find.
Posted on Jun 26, 2012
Dim screen acer 5100-3019
Try going into power option settings and taking the brightness to the max there. Start, control panel, power options, then you should see a setting for battery and for plugin. Hope this helps.
Jun 21, 2014 | Acer Aspire 5100-3019 PC Notebook
Hitachi 50V710 The picture is dim, then the bulb went out. I replaced the bulb. all works but the picture is still dim. You can barely see the screen durring the day. And can only use it in a dark room...
Apr 08, 2011 | Hitachi Televison & Video
Dim display on laptop LCD screen
The part you need is called a CCFL Backlight. Basically, there are lights in the screen that back-light/illuminate the display. Over time it burns out and you are left with a dim and completely dull display. These are a pain to replace and expensive when bought from the manufacturer. But this site has a break down with dis-assembly instructions...if you want to try it.
Mar 10, 2010 | HP OmniBook XE3 Notebook
I have an HP Pavilion DV2000 The screen suddenly went black The drive was removed and scanned for viruses then replaced When the system was restarted the screen seems to work but only very dimly....
sure the screen is bad.
internal.
the DV2000 runs CCFL back lamps,
all go dim with age, and yellow. all do.
so can be only this.
bad CCFL lamps or the CCFL inverter driving it.
vast PCs like this are in the recycle centers. now.
endless.....
goodwill has them in piles..
http://pcdied.com/cheaper.html
Jul 26, 2017 | HP Pavilion dv9000z Notebook
The screen on my Audiovox FP1510 has gone dark
Yes, there are 4 backlight lamps but it seems you have a problem with the circuit, called inverter, that controls those lamps. m@nt
Mar 15, 2009 | Audiovox FP1520 15 in. LCD Television
GPS screen no longer lights up
If you can't control it with the controls, then most likely the backlight has died. The entire LCD display will need to be replaced as the backlight is integrated into the LCD display.
- Jim
SHARCNET-USA
Dec 09, 2008 | Garmin Nuvi 350 Car GPS Receiver
Squares visible in bright colors
Turn down the contrast to about 55-65% of maximum. Also turn down sharpness to about 10-20% of maximum.
If ther is a Contrast Plus option, or digital contrast, turn to minimum or off. (Dependant on TV)
This is a common side effect with digital television.
Jan 23, 2008 | Philips Magnavox 42MF521D/37 Television
Screen went full bright one day.
Hello, please check the 10uf/200V capacitor around flyback transformer. Best regards, Arpi
Jul 17, 2007 | JVC AV-27230 27" TV
Televison & Video Logo
24 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
