Question about LG 47LX9500 47 in 3D HDTVReady LCD TV
Would like to use headphones plug to headphone jack without it going on mute. Company says no way to do this. Anybody know of a work around on this?
Since only one of my wife and me has bad hearing, we only have one set of headphones.
SOURCE: WHERE TO PLUG IN HEADPHONES
I GOT IT FREE FROM LG TECH SUPPORT. NOT $19.99, OR 29.99 FREE!!!!!
Posted on Feb 18, 2008
  • 7 Answers
SOURCE: LG 42PX4DV - HDMI Audio / PC Audio IN problem
one quick fix you can try. plug in the HDMI cable, slect a digital audio sound output from the sound settings on your machine, then leave it connected and restart it. It just might work.
Posted on Aug 05, 2009
  • 476 Answers
SOURCE: can I connect headphones to variable audio out
Although it is a variable out i don't think the audio level would be high enough to get a fair audible signal, here is something youcan try: if you have a small portable radio(like kids use sometimes with the cd/cassette/radio)with external or aux input, you can hook up the variable out from the tv to these inputs on your radio then hookup your headphones to the radio(most port. radios have headphone jacks) but with out an amplifier you will not get a lot of level out of the tv.
Posted on Oct 13, 2009
budmrtn
  • 11361 Answers
SOURCE: my plasma TV has no
The only way to do it (unless you go inside the TV and modify the TV) is to use a small headphone amplifier (or powered PC speaker system with out headphone jack) and connect it to the AUDIO line out (Red and White RCA jacks) on the back of the TV.
Posted on Jun 13, 2011
  • 118 Answers
SOURCE: When I disconnected my Headphones
Usually there is a nut on the back that hold it in place. If you can solider replace the jack. There are three contacts on the jack, one is ground, one is audio and the other is the speaker. If you know your way around tyou can jump the audio and speaker wire together and sound that way.
Tom Miller
Posted on Sep 08, 2011
Pioneer VSX-456 headphone jack problem
No the headphone jack doesn't disable the speakers. There are two switches in the lower middle of the receiver that are labeled speaker A and B. Pushing one of these should disconnect the speakers from the receiver.
Feb 16, 2014 | Audio Players & Recorders
Headphone not working
Try the headphones on another computer. Maybe the headphones are broken. If not, make sure you have the volume turned up and not on mute. And make sure you plug the headphone into the Headphone Jack not the Microphone Jack.
May 08, 2012 | eMachines Computers & Internet
Does this model have a headphone jack? If not, is there some way to rig headphones?
most televisions have a headphone jack on the side now if not then you can ge a RCA to 3.5mm stero headphone jack plug from radioshack or almost any other electronics store then plug it into the output on the back of the television. you may need to get headphones that have an amplifier built in for this to work, also if you want the sound off on the tv when using them just turn the volume all the way down because htting the mute button will also mute the output.
Jul 01, 2011 | Televison & Video
I have a LG 19LE3300 television and i whant to be able to connect an Infra red headphone while being able to listen by the speakers at the same time. actually when i connect the hearphone it disconnect...
First you need to make a test to adjust your headphones wireless system..
.pls follow the step below:
  • "Connect the headphone base" TO " headphones output of TV" with 3.5mm stereo headphone jack cable (than Tv should mute ) Infra red headphone pilot lamp should flicker in parallel to voice coming from TV
  • Infra red headphone should have a rotary adjustment on it.. "Volume" adjustment
  • while TV talking , when you sit in front of the Infra red headphone (it works point-to-point ) you will hear the voice of TV, than adjust volume properly...Thats it..now lets go to second step..
  • Your headphone's Base should either "3.5mm stereo headphone jack" or "RCA Stereo jacks" or "bot"h..After completion of this test ,I recommend you to switch / use "RCA Audio output plugs-white/Red cable " on the back of TV instead of TV's headphone output ,since it mutes the whole sound..RCA output plugs of TV work independently from the TV's master volume control..of course you need RCA cable to connect this..
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 30, 2011 | Televison & Video
Adding remote control activated ''mute'' to TV headphone jack
Generally when the head phone jack is inserted the speakers will get disconnected automatically.
If you are going to use external amplifier you can try the AV sockets. Opening the TV you may require the special screw drivers some times.
Jul 07, 2010 | Televison & Video
Sony Bravia 40" LCD, not getting any audio out of the headphone jack. Have tried different types of headphones. When I plug my headphones in to the side headphone jack I'm not getting any sound. The tv...
go to your remote contol ( menu )
then you go to the option set up.
then you go to headphones and you can set the volume louder.
You will see that it works fine.
Greetings from Holland Gesinus
Jan 14, 2010 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Headphone jack on 22 inch flat panel tv
You are on the wrong website for this type of inquiry. This is a self help website for the repair and use of manufactured products made for consumer use
Jun 27, 2017 | Televison & Video
Mic not working when headphone plugged in
Try changing the Windows Default Audio devices
  1. Go to control Panel
  2. Sounds and audio devices
  3. The Audio tab
  4. Then change the Sound Recording Device to Logitech Headphone INPUT
Hopefully this will work
Apr 07, 2009 | Logitech Premium Headset
No sound through the headphones
The way the headphone jack works is:
plug your headphones in and then mute the television using the remote.
While the TV is muted you can still use the volume up and down controls to adjust the volume through the headphones. I find that having the volume at 60-75% is more than loud enough on the headphones.
Just be careful when you unplug the headphones and take the TV off of mute, if your volume levels are still turned up you will be in for a jolt :)
Jan 10, 2009 | Dynex DX-LCD37 TV
Headphone Jack on Envision LCD TV
just bought a coby tf-tv2617 our cable company uses a unilersal remote ur2-cbl-cv02 where can i find the code to make them work
Dec 26, 2008 | Televison & Video
LG 47LX9500 47 in 3D HDTVReady LCD TV Logo
29 people viewed this question
Computer Repairing
Computer Repairing
