Question about Kenmore Ovens
F 10 code when I try using oven
Trouble code f 10 when I use kenmore oven 790.78573400
  • tom2536 May 21, 2009
    I checked the oven temperture probe and had the correct resistance so I replaced the EOC twice and still same problem
  • 6,784 Answers
The "F10" error code caused by the runaway temperature.
The first thing I would check is the resistance across the oven temperature probe (oven temperature sensor) terminals at the EOC (electronic oven control) plug.
It will be about 1100 Ohms at the room temperature.
If the resistance at the EOC plug is wrong, then measure the oven temperature probe resistance at the probe plug.
If it's wrong - replace the oven temperature probe. It's better to hardwire it, using a high temperature ceramic wire nuts.
If the readings at the EOC and at the oven temperature probe plug are different - check the wire harness between the oven temperature probe and the EOC.
If there is nothing wrong with the oven temperature probe resistance - replace the EOC.
Please rate and have a great day:)
Posted on May 20, 2009
  • Michael Masters
    Michael Masters May 21, 2009
    I see. this leads me to believe that this oven is defective. replacing two EOC boards and you still receive a F-10. this is very strange. i would contact the manufacture for a replacement ticket. this is a defective design(oven).
    I will continue to do more research in this issue and i will return with more advice and information.
2 Suggested Answers
  • 89 Answers
SOURCE: Kenmore oven error code f10
on that type of range F10 indicates a problem within the electronic control, but it could possible be caused by a faulty temperature sensor.
I would recommend service from a technician
Posted on May 27, 2009
Trouble code F1 F5
go on google give product name and model # then code errors. it will come up with solution.
Jul 17, 2014 | Kenmore Ovens
Hi, The door of the oven of my kenmore cooker locked itself and the code 'F9' flashes alternatively with the code 'dr' can you please give me some help to fix this issue? Thanks
Hi, the F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Oct 08, 2010 | Kenmore 47732 / 47734 / 47739 Electric...
40494 / 40495 / 40499 Electric Single Oven: have a kenmore self cleaning electric range it was...
The F9 code indicates there is a problem with the door lock.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 16, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Cleaning Kenmore double ovens back to back. During second cleaning got F9 code and the bottom oven is locked. Cleared the F9 will the bottom oven unlock when it cools down?
Jan 10, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
TRYING TO CLEAN KENMORE SELF CLEANING OVEN DISPLAY SAYS F9 HELP WHAT DOES THAT MEAN?? CAN'T FIND THE MANUAL OF COURSE.
Jan 01, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Exactly the same problem. My oven is 11 yrs old instead of 10
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Jul 28, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore double oven flashing "door locked"
Jul 16, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Beeping F 10
Hello
Welcome to fixya.com
You r answer to the F10 code is:
The F10 error code indicates a runaway oven temperature. This would indicate that the oven temperature sensor or the electronic control has failed. According to the service manual you need to unplug the range & after restoring power the oven continues to overheat you will need to replace the electronic oven control.
This a job for a hands on tech!
Thank you for trusting us with your questions.
Please remember to leave a solved rating before you sign out!
Thank You
Dec 25, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
F10 code
actually F-10 was not listed on the error code list,
do you see any other malfunctions in the display???
Mar 12, 2008 | Kenmore 41389 Electric Double Oven
Problem with Kenmore Electric stove
I have kenmore stove mod.790-95660103 you turn on any top burner . T he small one inside the big burner comes on Roy
Nov 24, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
327 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
